Jan 14 20:39:03 udhcpc[164]: Lease of 10.0.10.225 obtained, lease time 3600
Jan 14 21:09:03 udhcpc[164]: Lease of 10.0.10.225 obtained, lease time 3600
Jan 14 21:35:13 pppd[95]: Modem hangup
Jan 14 21:35:13 pppd[95]: Connection terminated.
Jan 14 21:35:13 pppd[95]: Connect time 18954395.1 minutes.
Jan 14 21:35:13 pppd[95]: Sent 66980093 bytes, received 2205563286 bytes.
Jan 14 21:35:13 dnsmasq[70]: read /etc/hosts - 4 addresses
Jan 14 21:35:13 dnsmasq[70]: read /etc/ethers - 1 addresses
Jan 14 21:35:13 dnsmasq[70]: reading /tmp/resolv.conf
Jan 14 21:35:13 dnsmasq[70]: using nameserver 10.0.0.2#53
Jan 14 21:35:13 dnsmasq[70]: using nameserver 10.0.0.1#53
Jan 14 21:35:13 L2TP: Disconnected
Jan 14 21:35:13 pppd[95]: Child process /tmp/ppp/ip-down (pid 276) terminated with signal 11
Jan 14 21:35:13 pppd[95]: Exit.
Jan 14 21:39:03 udhcpc[164]: Lease of 10.0.10.225 obtained, lease time 3600
Jan 14 21:56:47 udhcpc[283]: udhcpc (v0.9.9-pre) started
Jan 14 21:56:47 udhcpc[283]: Lease of 10.0.10.225 obtained, lease time 3600
Jan 14 21:57:46 wan: connected manually
Jan 14 21:57:46 udhcpc[164]: Unicasting a release of 10.0.10.225 to 10.0.0.1
Jan 14 21:57:47 udhcpc[164]: Entering released state
Jan 14 21:57:47 udhcpc[287]: Unicasting a release of 10.0.10.225 to 10.0.0.1
Jan 14 21:57:47 udhcpc[287]: Entering released state
Jan 14 21:57:47 udhcpc[164]: Received SIGTERM
Jan 14 21:57:47 udhcpc[287]: Received SIGTERM
Jan 14 21:57:47 kernel: vlan1: del 01:00:5e:00:00:01 mcast address from master interface
Jan 14 21:57:47 kernel: vlan1: del 01:00:5e:00:00:01 mcast address from vlan interface
Jan 14 21:57:47 kernel: vlan1: del 33:33:ff:97:df:97 mcast address from master interface
Jan 14 21:57:47 kernel: vlan1: del 33:33:ff:97:df:97 mcast address from vlan interface
Jan 14 21:57:47 kernel: vlan1: del 33:33:00:00:00:01 mcast address from master interface
Jan 14 21:57:47 kernel: vlan1: del 33:33:00:00:00:01 mcast address from vlan interface
Jan 14 21:57:52 kernel: vlan1: Setting MAC address to 00 11 d8 97 df 97.
Jan 14 21:57:52 kernel: VLAN (vlan1): Underlying device (eth0) has same MAC, not checking promiscious mode.
Jan 14 21:57:52 kernel: vlan1: add 01:00:5e:00:00:01 mcast address to master interface
Jan 14 21:57:52 kernel: vlan1: add 33:33:00:00:00:01 mcast address to master interface
Jan 14 21:57:52 kernel: vlan1: add 33:33:ff:97:df:97 mcast address to master interface
Jan 14 21:57:52 pppd[308]: pppd 2.4.2 started by avmishin, uid 0
Jan 14 21:57:52 pppd[308]: Using interface ppp0
Jan 14 21:57:52 pppd[308]: Connect: ppp0 <--> /dev/pts/0
Jan 14 21:57:52 pppd[308]: CHAP authentication succeeded
Jan 14 21:57:52 pppd[308]: local IP address 213.248.16.43
Jan 14 21:57:52 pppd[308]: remote IP address 213.248.0.4
Jan 14 21:57:52 dnsmasq[70]: read /etc/hosts - 4 addresses
Jan 14 21:57:52 dnsmasq[70]: read /etc/ethers - 1 addresses
Jan 14 21:57:52 dnsmasq[70]: reading /tmp/resolv.conf
Jan 14 21:57:52 dnsmasq[70]: using nameserver 10.0.0.2#53
Jan 14 21:57:52 dnsmasq[70]: using nameserver 10.0.0.1#53
Jan 14 21:57:52 L2TP: connect to ISP
Jan 14 21:57:53 ddns update: connected to members.dyndns.org (63.208.196.95) on port 80.
Jan 14 21:57:53 ddns update: request successful
Jan 14 21:57:55 ddns: ddns update ok
