in the paper chip (12/06) is written, that the wl-700g needs 10,7 watt in standby...
grat182
Hi --
I noticed that WL-700gE is always running because of the internal HD and didnt found in the records how much does it consume in terms of energy (Watts) ... any ideas where to look ?
Thanks
grat182
In the Dutch C't issue 11-2006 I have read that this unit consumes almost 5 Watt if it's switched off. That's the reason I always remove the plug from the outlet after switching it off. What it uses when switched on I don't know, but I bet it's someting like 20 W.
Marc
I've checked my box last month with a Watt-Meter.
The german model i have, consumes 10,5 - 11,0 Watt in standard use. (Read or write on Harddisk). Only surfing and Wlan-use doesn't spin up my harddisk.
With a modified firmware and the harddisk is spin down it consumes 5,5Watt. So my internetsite is always online and only when someone gets data the harddisk is spinning.
