The following code is from uClibc-0.9.28/libc/sysdeps/linux/common/setrlimit.c
PHP Code:
/* vi: set sw=4 ts=4: */
* setrlimit() for uClibc
* Copyright (C) 2000-2004 by Erik Andersen <andersen@codepoet.org>
* GNU Library General Public License (LGPL) version 2 or later.
#include "syscalls.h"
#ifndef __NR_ugetrlimit
/* Only wrap setrlimit if the new ugetrlimit is not present */
#define __NR___setrlimit __NR_setrlimit
#include <unistd.h>
#include <sys/resource.h>
#define RMIN(x, y) ((x) < (y) ? (x) : (y))
_syscall2(int, __setrlimit, int, resource, const struct rlimit *, rlim);
int setrlimit(__rlimit_resource_t resource, const struct rlimit *rlimits)
struct rlimit rlimits_small;
/* We might have to correct the limits values. Since the old values
* were signed the new values might be too large. */
rlimits_small.rlim_cur = RMIN((unsigned long int) rlimits->rlim_cur,
RLIM_INFINITY >> 1);
rlimits_small.rlim_max = RMIN((unsigned long int) rlimits->rlim_max,
return (__setrlimit(resource, &rlimits_small));
#undef RMIN
#else /* We don't need to wrap setrlimit */
#include <unistd.h>
struct rlimit;
_syscall2(int, setrlimit, unsigned int, resource,
#endif
that explaing why you get 1GB FSIZE limit. RLIM_INFINITY is defined as 0x7fffffff
. Shifting it one bit to the right produces what we get when issuing kernel syscall2. So everything looks OK. See newer version http://www.uclibc.org/cgi-bin/viewcv...21&view=markup
I suggest to fix amule code to mask SIGXFSZ signal or undefine calls to resource limits.
