mk for wxbase is standard. It's in the attachment. It must be polished between lines:[102-105] because I use this step to add missing include files to the source - there are exist in wxgtk sources but are not included in wxbase sources:
Dir:
src/expat
src/xml
include/xml
This should works.
When you try to make wxbase-stage/ipk there are two problems with the makefile of wxbase:
There are no bakefiles because I disabled precompiled headers in configuration's section of .mk (line 115) in order this project to compile. But the makefile try to install them so this line must be deleted:
(cd $(srcdir)/build/bakefiles/wxpresets/presets/ ; $(INSTALL_DATA) wx.bkl wx_unix.bkl wx_win32.bkl $(DESTDIR)$(datadir)/bakefile/presets)
Also I built the simplest version of wxbase but the makefile try to install all of the libraries and the install-strip section of the makefile should look like this
install-strip: install
$(STRIP) $(DESTDIR)$(libdir)/$(DLLPREFIX)$(WXDLLNAMEPREFIXGUI)$(WXUNICODEFLAG)$(WXDEBUGFLAG)$(WX_LIB_FLAVOUR)$(WXCOMPILER)$(VENDORTAG)$(WXDLLVERSIONTAG)$(dll___targetsuf3)
$(STRIP) $(DESTDIR)$(libdir)/$(DLLPREFIX)$(WXDLLNAMEPREFIX)$(WXUNICODEFLAG)$(WXDEBUGFLAG)$(WX_LIB_FLAVOUR)$(WXCOMPILER)$(VENDORTAG)$(WXDLLVERSIONTAG)$(dll___targetsuf3)
$(STRIP) $(DESTDIR)$(libdir)/$(DLLPREFIX)$(WXDLLNAMEPREFIX)$(WXUNICODEFLAG)$(WXDEBUGFLAG)$(WX_LIB_FLAVOUR)_net$(WXCOMPILER)$(VENDORTAG)$(WXDLLVERSIONTAG)$(dll___targetsuf3)
# $(STRIP) $(DESTDIR)$(libdir)/$(DLLPREFIX)$(WXDLLNAMEPREFIXGUI)$(WXUNICODEFLAG)$(WXDEBUGFLAG)$(WX_LIB_FLAVOUR)_core$(WXCOMPILER)$(VENDORTAG)$(WXDLLVERSIONTAG)$(dll___targetsuf3)
# $(STRIP) $(DESTDIR)$(libdir)/$(DLLPREFIX)$(WXDLLNAMEPREFIXGUI)$(WXUNICODEFLAG)$(WXDEBUGFLAG)$(WX_LIB_FLAVOUR)_adv$(WXCOMPILER)$(VENDORTAG)$(WXDLLVERSIONTAG)$(dll___targetsuf3)
# $(STRIP) $(DESTDIR)$(libdir)/$(DLLPREFIX)$(WXDLLNAMEPREFIXGUI)$(WXUNICODEFLAG)$(WXDEBUGFLAG)$(WX_LIB_FLAVOUR)_media$(WXCOMPILER)$(VENDORTAG)$(WXDLLVERSIONTAG)$(dll___targetsuf3)
# $(STRIP) $(DESTDIR)$(libdir)/$(DLLPREFIX)$(WXDLLNAMEPREFIX)$(WXUNICODEFLAG)$(WXDEBUGFLAG)$(WX_LIB_FLAVOUR)_odbc$(WXCOMPILER)$(VENDORTAG)$(WXDLLVERSIONTAG)$(dll___targetsuf3)
# $(STRIP) $(DESTDIR)$(libdir)/$(DLLPREFIX)$(WXDLLNAMEPREFIXGUI)$(WXUNICODEFLAG)$(WXDEBUGFLAG)$(WX_LIB_FLAVOUR)_dbgrid$(WXCOMPILER)$(VENDORTAG)$(WXDLLVERSIONTAG)$(dll___targetsuf3)
# $(STRIP) $(DESTDIR)$(libdir)/$(DLLPREFIX)$(WXDLLNAMEPREFIXGUI)$(WXUNICODEFLAG)$(WXDEBUGFLAG)$(WX_LIB_FLAVOUR)_html$(WXCOMPILER)$(VENDORTAG)$(WXDLLVERSIONTAG)$(dll___targetsuf3)
# $(STRIP) $(DESTDIR)$(libdir)/$(DLLPREFIX)$(WXDLLNAMEPREFIXGUI)$(WXUNICODEFLAG)$(WXDEBUGFLAG)$(WX_LIB_FLAVOUR)_qa$(WXCOMPILER)$(VENDORTAG)$(WXDLLVERSIONTAG)$(dll___targetsuf3)
$(STRIP) $(DESTDIR)$(libdir)/$(DLLPREFIX)$(WXDLLNAMEPREFIX)$(WXUNICODEFLAG)$(WXDEBUGFLAG)$(WX_LIB_FLAVOUR)_xml$(WXCOMPILER)$(VENDORTAG)$(WXDLLVERSIONTAG)$(dll___targetsuf3)
# $(STRIP) $(DESTDIR)$(libdir)/$(DLLPREFIX)$(WXDLLNAMEPREFIXGUI)$(WXUNICODEFLAG)$(WXDEBUGFLAG)$(WX_LIB_FLAVOUR)_xrc$(WXCOMPILER)$(VENDORTAG)$(WXDLLVERSIONTAG)$(dll___targetsuf3)
# $(STRIP) $(DESTDIR)$(libdir)/$(DLLPREFIX)$(WXDLLNAMEPREFIXGUI)$(WXUNICODEFLAG)$(WXDEBUGFLAG)$(WX_LIB_FLAVOUR)_aui$(WXCOMPILER)$(VENDORTAG)$(WXDLLVERSIONTAG)$(dll___targetsuf3)
# $(STRIP) $(DESTDIR)$(libdir)/$(DLLPREFIX)$(WXDLLNAMEPREFIXGUI)$(WXUNICODEFLAG)$(WXDEBUGFLAG)$(WX_LIB_FLAVOUR)_richtext$(WXCOMPILER)$(VENDORTAG)$(WXDLLVERSIONTAG)$(dll___targetsuf3)
# $(STRIP) $(DESTDIR)$(libdir)/$(DLLPREFIX)$(WXDLLNAMEPREFIXGUI)$(WXUNICODEFLAG)$(WXDEBUGFLAG)$(WX_LIB_FLAVOUR)_gl$(WXCOMPILER)$(VENDORTAG)$(WXDLLVERSIONTAG)$(dll___targetsuf3)
# $(STRIP) $(DESTDIR)$(PLUGINS_INST_DIR)/$(DLLPREFIX_MODULE)sound_sdl$(PLUGINSUFFIX)$(PLUGVERDELIM)$(PLUGIN_VERSION0)$(WXCOMPILER).$(SO_SUFFIX_MODULE)
As you can see the 2.8.0 wxbase's source is quite buggy and patches must be genereted before this will be included in the official optware... or we wait for 2.8.1 :-)
