Results 1 to 2 of 2
Thread: Increase cpu speed
    Increase cpu speed
    I saw that the cpu that's inside this router is rated as 300MHz, however, in this router it is working only at 266MHz...
    So, I guess that it's underclocked....
    Isn't there a way to make it work at his rated speed: 300MHz?
    Thankx
    Exclamation
    Yes, it can be done with the commandline configurator by setting other NVRAM values.
    On the forum you can find people who did this...they did not enjoy it.
  1. USB serial high speed patch
    By drazvan in forum WL-500g Q&A
    Last Post: 09-09-2009, 21:59
  2. Noticeable cpu load increase if using as switch?
    By Chellenger in forum WL-500g Q&A
    Last Post: 19-03-2006, 19:48
  3. Replies: 0
    Last Post: 25-02-2006, 03:21
  4. Increase WLAN speed
    By Thisisnotme in forum WL-500g Q&A
    Last Post: 06-08-2005, 09:21
  5. WL-HDD disk transfer speed
    By gerardwr in forum WL-HDD Q&A
    Last Post: 31-10-2004, 16:32
