Results 1 to 2 of 2
Thread: router cannot reconnect with PPPoE
    Nov 2006
    Budapest
    I have a strange reconnection issue with my WL500gP running with 1.9.2.7-7f. The WAN port is connected to a DLINK ADSL modem and I use PPPoE. In about every 3-4 hours the WAN connection is terminated. I don't know the reason of disconnection - maybe an ISP issue - the trouble is that after disconnection the router is not able to reconnect itself, even after I reset it through the web interface or through the 'reboot' command. I keep getting:
    Dec 6 18:35:52 pppd[93]: Timeout waiting for PADO packets
    Dec 6 18:35:52 pppd[93]: Unable to complete PPPoE Discovery
    messages indefinately after router reboot. ('maxfail' is 0, it tries forever without success). I have also noticed that when the disconnection happens the windows based PC - which is connected with a LAN cable - shows 'Network cable disconnected' message for a very short period of time then it immediately shows 'Network cable connected' in about 1 second again which shows me that there could be a problem on the LAN side as well.
    The only thing which helps is powering down and up the WL500gP. Then it is able to bring up the PPPoE connection.
    I cannot reproduce the problem at will, if I power down and up the ADSL modem while the router is online, it brings back the WAN connection nicely. From this and from the LAN cable message, I think it may be a router issue.
    It is very annoying to power down and up the router 2-3 times a day. Is there any way to enable more detailed logging of the WAN connection somewhere in the firmware? I really would like to determine the cause of why the router cannot reconnect even after software initiated reboot.
    Regards,
    Gellert
    Nov 2006
    Budapest
    After installing the new 1.9.2.7-7g firmware, the problem does not occur anymore.
  1. Reboot on ISP disconnects ?
    By 7111 in forum WL-500g Q&A
    Last Post: 27-09-2006, 08:18
  2. PPPoE with LAN1 instead of WAN?
    By BlueScreen in forum WL-500g Q&A
    Last Post: 21-07-2006, 10:48
  3. Completely new WL700gE router crashed after firmware update - plz help!
    By ClaudeX in forum WL-700g Firmware Discussion
    Last Post: 20-07-2006, 00:03
  4. Router won't connect via PPPoE
    By Hirni in forum WL-500g Q&A
    Last Post: 08-06-2006, 15:37
