Проблема с внешним винтом. Винт отформатирован в ext3fs на компе, при подключении к компу отлично виден, прошивка видит через раз, когда не видит в логе пишется следующее
Dec 25 22:16:24 kernel: usb.c: USB disconnect on device 01:03.2-2 address 2
Dec 25 22:16:26 kernel: hub.c: new USB device 01:03.2-1, assigned address 3
Dec 25 22:16:32 kernel: VFS: Can't find ext3 filesystem on dev sd(8,0).
Dec 25 22:16:32 kernel: MSDOS FS: Using codepage 950
Dec 25 22:16:32 kernel: MSDOS FS: IO charset cp950
Dec 25 22:16:32 kernel: FAT: bogus logical sector size 64543
Dec 25 22:16:32 kernel: VFS: Can't find a valid FAT filesystem on dev 08:00.
Dec 25 22:16:32 kernel: FAT: freeing iocharset=cp950
Dec 25 22:16:32 kernel: attempt to access beyond end of device
Dec 25 22:16:32 kernel: 08:01: rw=0, want=2, limit=1
Dec 25 22:16:32 kernel: EXT3-fs: unable to read superblock
Dec 25 22:16:32 kernel: FAT: bogus logical sector size 0
Dec 25 22:16:32 kernel: VFS: Can't find a valid FAT filesystem on dev 08:01.
Dec 25 22:16:32 kernel: kjournald starting. Commit interval 5 seconds
Dec 25 22:16:32 kernel: EXT3-fs warning: mounting unchecked fs, running e2fsck is recommended
Dec 25 22:16:32 kernel: EXT3 FS 2.4-0.9.19, 19 August 2002 on sd(8,5), internal journal
Dec 25 22:16:32 kernel: EXT3-fs: mounted filesystem with ordered data mode.
Dec 25 22:16:32 USB storage: ext3 fs mounted to /tmp/harddisk
Dec 25 22:16:32 kernel: VFS: Can't find ext3 filesystem on dev sd(8,16).
Dec 25 22:16:32 kernel: VFS: Can't find a valid FAT filesystem on dev 08:10.
Dec 25 22:16:32 kernel: 08:11: rw=0, want=2, limit=1
Dec 25 22:16:32 kernel: VFS: Can't find a valid FAT filesystem on dev 08:11.
Полностью лог в аттаче. В чем может быть проблема?
