Great! Thank you vey much !!
Hi all,
can someone shortly explain, why the esniper sayz "Segmentation fault" and does not run on background?
I already tried to runCode:[admin@wl500g root]$ esniper -c /opt/etc/esniper/config.cfg /opt/etc/esniper/auction.cfg & [admin@wl500g root]$ Auction 345273577745: Very old box of old socks Time remaining: 4 days 6 hours 33 mins (369180 seconds) End time: 15/09/2008 20:14:35 [1] + Segmentation fault esniper -c /opt/etc/esniper/config.cfg /opt/etc/esniper/auction.cfg [admin@wl500g root]$with no effect.Code:e2fsck -y /dev/discs/disc0/part3
I already tried to reinstall the esniper.
What else should I try?
Thanks for hints,
kath
Hi Drchain,
seems there is yet a change/bug that needs the new version 2.19.0
can u help?
tx
root@wiwi:/mnt/mmc/logs# esniper encountered a bug. It looks like your esniper version is not
current. You have version 2.18.1, the newest version is 2.19.0.
Please go to http://esniper.sf.net/ and update your copy of esniper.
If you want to report this bug, please go to:
http://sourceforge.net/tracker/?func...85&atid=442436
paste this into "Detailed Description":
Automated esniper bug report.
esniper version 2.18.1
libcurl/7.17.0 OpenSSL/0.9.7m zlib/1.2.3
Error encountered in function ebayLogin in auction.c line 410
auction = 160292771648, price = 11.87, remain = 0
latency = 0, result = -1, error = 19
buf = 0x46ad00, size = 15247, read = 0x46ad00
time = 1224925869, offset = 0
pagename = "(null)", pageid = "(null)", srcid = "InterrupteByLvis"
unknown pageinfo
version 2.19.0 has been committed to the repository.
So it should soon appear in the feeds.
Hello,
seems there is a new version
current. You have version 2.19.0, the newest version is 2.21.0.
esniper version 2.19.0
Error encountered in function ebayLogin in auction.c line 415
auction = 380173497289, price = 7.8, remain = 0
buf = 0x46ad00, size = 4923, read = 0x46ad00
time = 1257498431, offset = 0
pageinfo is NULL
I hope yo ucan help!
tx
Well, I have compiled the new ipkg for esniper-2-21-0. And it looks like it works. Unfortunately I don't know how to put the new esniper ipkg in the ipkg repository. Erm...Also this means I now have less snipers to contend with...
You might like to compile it yourself. esniper is easy to compile.
1. Just setup a vmware ubutu box and pull the target=oleg development enviroment mentioned in one of the guides in this section.
2. Tip: Make sure you make all the optware libraries that you can - if the target=oleg enviroment is not compiling its because your missing 'essential tools' like bison, flex etc.. which you have to sudo
3. A simple change to the esniper.mk file to the correct version and make esniper.ipkg and then install the ipkg
Hi!
New version is available at http://esniper.sf.net/
Old is not working..
Could someone compile it please?
2.24.0 is out.
Anyone some time to compile?
tx!
