# esniper
# You must replace "esniper" and "ESNIPER" with the lower case name and
# upper case name of your new package. Some places below will say
# "Do not change this" - that does not include this global change,
# which must always be done to ensure we have unique names.
# ESNIPER_VERSION, ESNIPER_SITE and ESNIPER_SOURCE define
# the upstream location of the source code for the package.
# ESNIPER_DIR is the directory which is created when the source
# archive is unpacked.
# ESNIPER_UNZIP is the command used to unzip the source.
# It is usually "zcat" (for .gz) or "bzcat" (for .bz2)
# You should change all these variables to suit your package.
# Please make sure that you add a description, and that you
# list all your packages' dependencies, seperated by commas.
# If you list yourself as MAINTAINER, please give a valid email
# address, and indicate your irc nick if it cannot be easily deduced
# from your name or email address. If you leave MAINTAINER set to
# "NSLU2 Linux" other developers will feel free to edit.
ESNIPER_SITE=http://$(SOURCEFORGE_MIRROR)/sourceforge/esniper
ESNIPER_VERSION=2-15-0
ESNIPER_SOURCE=esniper-$(ESNIPER_VERSION).tgz
ESNIPER_DIR=esniper-$(ESNIPER_VERSION)
ESNIPER_UNZIP=zcat
ESNIPER_MAINTAINER=NSLU2 Linux <nslu2-linux@yahoogroups.com>
ESNIPER_DESCRIPTION=Describe esniper here.
ESNIPER_SECTION=
ESNIPER_PRIORITY=optional
ESNIPER_DEPENDS=
ESNIPER_SUGGESTS=
ESNIPER_CONFLICTS=
# ESNIPER_IPK_VERSION should be incremented when the ipk changes.
ESNIPER_IPK_VERSION=1
# ESNIPER_CONFFILES should be a list of user-editable files
###ESNIPER_CONFFILES=/opt/etc/esniper.conf /opt/etc/init.d/SXXesniper
# ESNIPER_PATCHES should list any patches, in the the order in
# which they should be applied to the source code.
### ESNIPER_PATCHES=$(ESNIPER_SOURCE_DIR)/configure.patch
# If the compilation of the package requires additional
# compilation or linking flags, then list them here.
ESNIPER_CPPFLAGS=
ESNIPER_LDFLAGS=
# ESNIPER_BUILD_DIR is the directory in which the build is done.
# ESNIPER_SOURCE_DIR is the directory which holds all the
# patches and ipkg control files.
# ESNIPER_IPK_DIR is the directory in which the ipk is built.
# ESNIPER_IPK is the name of the resulting ipk files.
# You should not change any of these variables.
ESNIPER_BUILD_DIR=$(BUILD_DIR)/esniper
ESNIPER_SOURCE_DIR=$(SOURCE_DIR)/esniper
ESNIPER_IPK_DIR=$(BUILD_DIR)/esniper-$(ESNIPER_VERSION)-ipk
ESNIPER_IPK=$(BUILD_DIR)/esniper_$(ESNIPER_VERSION)-$(ESNIPER_IPK_VERSION)_$(TARGET_ARCH).ipk
.PHONY: esniper-source esniper-unpack esniper esniper-stage esniper-ipk esniper-clean esniper-dirclean esniper-check
# This is the dependency on the source code. If the source is missing,
# then it will be fetched from the site using wget.
$(DL_DIR)/$(ESNIPER_SOURCE):
$(WGET) -P $(DL_DIR) $(ESNIPER_SITE)/$(ESNIPER_SOURCE)
# The source code depends on it existing within the download directory.
# This target will be called by the top level Makefile to download the
# source code's archive (.tar.gz, .bz2, etc.)
esniper-source: $(DL_DIR)/$(ESNIPER_SOURCE) $(ESNIPER_PATCHES)
# This target unpacks the source code in the build directory.
# If the source archive is not .tar.gz or .tar.bz2, then you will need
# to change the commands here. Patches to the source code are also
# applied in this target as required.
# This target also configures the build within the build directory.
# Flags such as LDFLAGS and CPPFLAGS should be passed into configure
# and NOT $(MAKE) below. Passing it to configure causes configure to
# correctly BUILD the Makefile with the right paths, where passing it
# to Make causes it to override the default search paths of the compiler.
# If the compilation of the package requires other packages to be staged
# first, then do that first (e.g. "$(MAKE) <bar>-stage <baz>-stage").
# If the package uses GNU libtool, you should invoke $(PATCH_LIBTOOL) as
# shown below to make various patches to it.
$(ESNIPER_BUILD_DIR)/.configured: $(DL_DIR)/$(ESNIPER_SOURCE) $(ESNIPER_PATCHES) make/esniper.mk
$(MAKE) openssl-stage libcurl-stage
rm -rf $(BUILD_DIR)/$(ESNIPER_DIR) $(ESNIPER_BUILD_DIR)
$(ESNIPER_UNZIP) $(DL_DIR)/$(ESNIPER_SOURCE) | tar -C $(BUILD_DIR) -xvf -
if test -n "$(ESNIPER_PATCHES)" ; \
then cat $(ESNIPER_PATCHES) | \
patch -d $(BUILD_DIR)/$(ESNIPER_DIR) -p0 ; \
if test "$(BUILD_DIR)/$(ESNIPER_DIR)" != "$(ESNIPER_BUILD_DIR)" ; \
then mv $(BUILD_DIR)/$(ESNIPER_DIR) $(ESNIPER_BUILD_DIR) ; \
(cd $(ESNIPER_BUILD_DIR); \
$(TARGET_CONFIGURE_OPTS) \
CPPFLAGS="$(STAGING_CPPFLAGS) $(ESNIPER_CPPFLAGS)" \
LDFLAGS="$(STAGING_LDFLAGS) $(ESNIPER_LDFLAGS)" \
./configure \
--build=$(GNU_HOST_NAME) \
--host=$(GNU_TARGET_NAME) \
--target=$(GNU_TARGET_NAME) \
--prefix=/opt \
--disable-nls \
--disable-static \
###$(PATCH_LIBTOOL) $(ESNIPER_BUILD_DIR)/libtool
touch $(ESNIPER_BUILD_DIR)/.configured
esniper-unpack: $(ESNIPER_BUILD_DIR)/.configured
# This builds the actual binary.
$(ESNIPER_BUILD_DIR)/.built: $(ESNIPER_BUILD_DIR)/.configured
rm -f $(ESNIPER_BUILD_DIR)/.built
$(MAKE) -C $(ESNIPER_BUILD_DIR)
touch $(ESNIPER_BUILD_DIR)/.built
# This is the build convenience target.
esniper: $(ESNIPER_BUILD_DIR)/.built
# If you are building a library, then you need to stage it too.
###$(ESNIPER_BUILD_DIR)/.staged: $(ESNIPER_BUILD_DIR)/.built
rm -f $(ESNIPER_BUILD_DIR)/.staged
$(MAKE) -C $(ESNIPER_BUILD_DIR) DESTDIR=$(STAGING_DIR) install
touch $(ESNIPER_BUILD_DIR)/.staged
###esniper-stage: $(ESNIPER_BUILD_DIR)/.staged
# This rule creates a control file for ipkg. It is no longer
# necessary to create a seperate control file under sources/esniper
$(ESNIPER_IPK_DIR)/CONTROL/control:
@install -d $(@D)
@rm -f $@
@echo "Package: esniper" >>$@
@echo "Architecture: $(TARGET_ARCH)" >>$@
@echo "Priority: $(ESNIPER_PRIORITY)" >>$@
@echo "Section: $(ESNIPER_SECTION)" >>$@
@echo "Version: $(ESNIPER_VERSION)-$(ESNIPER_IPK_VERSION)" >>$@
@echo "Maintainer: $(ESNIPER_MAINTAINER)" >>$@
@echo "Source: $(ESNIPER_SITE)/$(ESNIPER_SOURCE)" >>$@
@echo "Description: $(ESNIPER_DESCRIPTION)" >>$@
@echo "Depends: $(ESNIPER_DEPENDS)" >>$@
@echo "Suggests: $(ESNIPER_SUGGESTS)" >>$@
@echo "Conflicts: $(ESNIPER_CONFLICTS)" >>$@
# This builds the IPK file.
# Binaries should be installed into $(ESNIPER_IPK_DIR)/opt/sbin or $(ESNIPER_IPK_DIR)/opt/bin
# (use the location in a well-known Linux distro as a guide for choosing sbin or bin).
# Libraries and include files should be installed into $(ESNIPER_IPK_DIR)/opt/{lib,include}
# Configuration files should be installed in $(ESNIPER_IPK_DIR)/opt/etc/esniper/...
# Documentation files should be installed in $(ESNIPER_IPK_DIR)/opt/doc/esniper/...
# Daemon startup scripts should be installed in $(ESNIPER_IPK_DIR)/opt/etc/init.d/S??esniper
# You may need to patch your application to make it use these locations.
$(ESNIPER_IPK): $(ESNIPER_BUILD_DIR)/.built
rm -rf $(ESNIPER_IPK_DIR) $(BUILD_DIR)/esniper_*_$(TARGET_ARCH).ipk
$(MAKE) -C $(ESNIPER_BUILD_DIR) DESTDIR=$(ESNIPER_IPK_DIR) install-strip
install -d $(ESNIPER_IPK_DIR)/opt/etc/
install -m 644 $(ESNIPER_SOURCE_DIR)/esniper.conf $(ESNIPER_IPK_DIR)/opt/etc/esniper.conf
install -d $(ESNIPER_IPK_DIR)/opt/etc/init.d
install -m 755 $(ESNIPER_SOURCE_DIR)/rc.esniper $(ESNIPER_IPK_DIR)/opt/etc/init.d/SXXesniper
sed -i -e '/^#!/aOPTWARE_TARGET=${OPTWARE_TARGET}' $(XINETD_IPK_DIR)/opt/etc/init.d/SXXesniper
$(MAKE) $(ESNIPER_IPK_DIR)/CONTROL/control
install -m 755 $(ESNIPER_SOURCE_DIR)/postinst $(ESNIPER_IPK_DIR)/CONTROL/postinst
sed -i -e '/^#!/aOPTWARE_TARGET=${OPTWARE_TARGET}' $(XINETD_IPK_DIR)/CONTROL/postinst
install -m 755 $(ESNIPER_SOURCE_DIR)/prerm $(ESNIPER_IPK_DIR)/CONTROL/prerm
sed -i -e '/^#!/aOPTWARE_TARGET=${OPTWARE_TARGET}' $(XINETD_IPK_DIR)/CONTROL/prerm
echo $(ESNIPER_CONFFILES) | sed -e 's/ /\n/g' > $(ESNIPER_IPK_DIR)/CONTROL/conffiles
cd $(BUILD_DIR); $(IPKG_BUILD) $(ESNIPER_IPK_DIR)
# This is called from the top level makefile to create the IPK file.
esniper-ipk: $(ESNIPER_IPK)
# This is called from the top level makefile to clean all of the built files.
esniper-clean:
-$(MAKE) -C $(ESNIPER_BUILD_DIR) clean
# This is called from the top level makefile to clean all dynamically created
# directories.
esniper-dirclean:
rm -rf $(BUILD_DIR)/$(ESNIPER_DIR) $(ESNIPER_BUILD_DIR) $(ESNIPER_IPK_DIR) $(ESNIPER_IPK)
# Some sanity check for the package.
esniper-check: $(ESNIPER_IPK)
perl scripts/optware-check-package.pl --target=$(OPTWARE_TARGET) $(ESNIPER_IPK)
