Results 1 to 15 of 17
Thread: 1.9.2.7-7f firmware
    1.9.2.7-7f firmware
    Please read this post http://wl500g.info/showthread.php?t=4145 for download link.
    Final 1.9.2.7-7f firmware solves Premium box problems. The firmware itself is just a WL500g Deluxe firmware packaged for the WL500g Premium, so it has slightly different web iface and misses some features, such as Download manager, fancy samba config, etc. It's designed mostly for "do it yourself" persons and features ipkg support, etc + everything we've in my firmwares.
    Please note: my mission is not the tons of features, but router stability.
    do i miss features in comparison to the normal firmware of wl-500gp or in comparison to your latest 500g firmware?
    is it possible to get a list of features of your firmware? i am new here, and i cannot get an overview over all the firmwares *confused*
    yesterday i tried your latest on my 500gp but reverted to original firmware because of missing samba and no idea how to get ipkg to run. do i have to install all these packages on the external harddrive, or is there a way to use the internal flash? all tutorials here told me to mount the harddrive at another point than the standard mountpoint. can i use fat32 for the optware drive? i am a little bit confused about it all.
    at all i know linux very well and i like the linux features of your firmware, but cannot decide if it is better to use the original one or yours.
    thanks in advance, _H_o_L_E_
    Quote Originally Posted by _H_o_L_E_ View Post
    Compared to original firmware.
    Perhaps... One day...
    Just use search, use macsat tutorials, etc.
    Consider using OpenWRT instead, it has tons of features, but requires Linux knowledge.
    thank you very much
    i dont like openwrt because of the missing webinterface which i like because it is easy with it to change settings quickly
    Maybe you should try OpenWRT together with http://xwrt.berlios.de/xwrt.asp
    WRT54GS v1.1: DD-WRT v23 SP2 (09/15/06) std (DSL 16K ROUTER)
    WRT54G v5.0: DD-WRT v23 SP1 Final (05/16/06) micro (WLAN CLIENT)
    ASUS WL-500gP: oleg WL500gp-1.9.2.7-7f-pre7 (AP + WEBCAM)
    ASUS WL-500gP: oleg WL500gp-1.9.2.7-7f-pre7 (TESTING BLINKENCUBE)
    WRT54G v2.2: DD-WRT v23 SP2 (09/04/06) mini (WDS MASTER)
    WRT54GL v1.1: DD-WRT v23 SP2 (09/04/06) mini (WDS NODE)
    WRT54G v5.0: DD-WRT v23 SP2 (09/15/06) micro (SPARE + TESTING)
    Jul 2006
    Nijmegen, The Netherlands
    OpenWRT has a fully featured web-interface out of the box. You can go completely without ever login into the console even once and still use all features of this distro.
    There is no need to install the additional XWRT if you don't want any fancy graphs of your network traffic etc.
    ASUS wl500g Deluxe: OpenWRT RC5 White Russian
    ASUS wl500g Premium: OpenWRT RC6 Kamikazee / White Russian?
    Use WL500gp-1.9.2.7-7f, can not mount usb disk on /OPT with post-boot
    Dear Oleg,
    I use the Oleg firmware WL500gp-1.9.2.7-7f. It is realy a good stuf. But, I got some problems. First, if I disable the studip-ftp in WEBIF, then I can catch the USB disk when I telnet to the router. Then, I write the post-boot, but cannot automount USB disk on /opt no matter whether I disable studip-ftp or not. Could you give me some suggestion. Thanks.
    sincerely,
    Jungsheng
    That happens to me as well. If the FTP option is disabled in the web interface then the USB HDD won't mount as there's no /dev/discs. If I re-enable it and reboot all is fine.
    I'm not sure what the FTP option is supposed to do, it doesn't seem to start a FTP for me. I have to start stupid-ftpd in post-boot.
    I hawe problem with oleg's last firmware 1.9.2.7-7f:
    1. My USB stick in oficial firmware funkcionaly correct, bud in this firmware system log type:
    kernel: VFS: Can't find a valid FAT filesystem on dev 08:00.
    kernel: VFS: Can't find ext3 filesystem on dev sd(8,1).
    this stick is format to FAT32, FAT16.
    2. In my lan can't find shared folder on USB disk in my router (in official firmware is correct).
    3. Where is in web config page run download service for download master ?
    4. Why look actual down/up rate and all down/up MB data?
    5. Where is admin page for torrent file acess from web?
    Sorry my English is bad (i living in Czech Republic).
    Thansk for your answer.
    Quote Originally Posted by HFX9 View Post
    this is normal, if you don't use the ftp-server. In this great stable and better secure firmware the ftp-server-deamon starts the handling (loading driver into kernel) of the usb-sticks.
    ... look at this thread, how to make the sticks useable without starting ftp-server-deamon ...
    cu
    exdlinker
    old: DI-624
    new: WL500gP
    Angry
    Furthermore on strange behaviour of the WL500gP with Olegs 1.9.2.7f firmware for the WL500gP
    Case 1:
    FTP-Server AND/OR LPR-Printing Service in WebIf ENABLED, mounting USB-HD via script in /usr/local/sbin/post-boot
    # Start SSH service
    dropbear
    # test if USB disc has been attached
    # if not - then insert needed modules
    if [ ! -d /dev/discs ]
    then
    insmod scsi_mod && insmod sd_mod && insmod usb-storage && sleep 5s
    # Wait for /opt to mount
    mount /dev/discs/disc0/part2 /opt
    mount /dev/discs/disc0/part3 /tmp/harddisk
    i=0
    while [ $i -le 30 ]
    do
    if [ -d /opt/etc ]
    then
    break
    sleep 1
    i=`expr $i + 1`
    done
    # Activate swap
    swapon /dev/discs/disc0/part1
    is correct, swap is used. mount gives:
    [admin@ASUS root]$ mount
    none on /dev type devfs (rw)
    proc on /proc type proc (rw)
    ramfs on /tmp type ramfs (rw)
    /dev/discs/disc0/part2 on /opt type ext3 (rw)
    /dev/discs/disc0/part3 on /tmp/harddisk type ext3 (rw)
    With enabled NFS service and setting exports in /etc/exports:
    /tmp/harddisk/ 192.168.1.0/24(rw,async,no_root_squash)
    results in no connecting from other devices (iMac, Linux, dbox2)
    exportfs gives
    [admin@ASUS root]$ exportfs
    /tmp/harddisk 192.168.1.0/24
    but showmount -e inside the router or from other devices leads to
    [admin@ASUS root]$ showmount -e
    Export list for ASUS:
    So permission denied for the other devices, rpcinfo -p from iMac shows no probs with ports, nfs and mountd are ok. Setting for rw-access are correct, so no idea what´s going on.
    Case 2
    FTP service AND LPR service disabled, same files as above (exports, post-boot) following results after booting:
    mount:
    /dev/discs/disc0/part2 on /tmp/harddisk type ext3 (rw,noatime)
    /dev/discs/disc0/part3 on /tmp/harddisk/part1 type ext3 (rw,noatime)
    part2 and part3 are routed to mounting points I never specified.
    exportfs:
    -> same as in case 1
    showmount -e
    -> Consequently NFS drives can be mount on the dbox2, iMac an Linux-PC with exactly the same command mount - t nfs -o rw,udp,soft,async 192.168.1.1:/tmp/harddisk /mountingpoint
    Even if you umount part2 and part3 and mount the partitions as wished to /opt and /tmp/harddisk NFS works very well!!
    As my result: With activated FTP or LPR, NFS is working no more, with both deactivated services NFS is ok but post-boot is not executed.
    Bug or Feature? Any comments or suggestions? Thanks for reading this extra-long post.
    Regards
    Harald
    Problem Flashing
    i have asus wl500GP and i tryed to flash with new 1.9.7.2 but i have a static IP adres like 212.110.74.129 , and i loged in my router, upload file and then restart to set up my new flash , and than i no have nothing , i cannot login to my router, i cannot restore, i cannot flash a cannot nothing, steel IP on the router is 212.110.74.129 and the power buton is flashing slow , i cannot do nothing ,i send to service cose router is new, not more abaut 1 month , and thay told me to u dont hawe waranty for these and bla bla bla..
    CAN SOMEONE HELP ME HOW I CAN RASTORE ORE HOW I CAN BACK WORKING MY WL500 G PREMIUM
    THANK YOU
    Nov 2006
    Lisbon@Portugal
    @fejzulla, pls read following post, it may help you
    http://www.wl500g.info/showthread.php?t=1329
    ihave buy een asus wl-500 gP whit this firmware 1.9.7.4
    this firmware can not finding on a asus website
    i want to try the oleg firmware but i want go back to 1.9.7.4 as oleg not good work on my asus where can find this firmware
    (sorry for my englis i speak dutch)
    i want backup this firmware i have no idee
    how works this ????
  1. WDS Problem bei Firmware 1.9.2.7 endlich gelöst
    By Wisi in forum German Discussion - Deutsch (DE)
    Last Post: 10-12-2009, 15:51
  2. Firmware upgrading HOWTO
    Last Post: 30-07-2008, 21:00
  3. Upgraden naar nieuwe firmware mislukt steeds
    By Weiry© in forum Dutch Discussion - Nederlands
    Last Post: 28-09-2006, 22:29
  4. twonky media server, network drive with oleg firmware
    Last Post: 22-03-2006, 07:15
    Last Post: 21-10-2004, 14:55
