I’m connected to internet through Asus router WL 500gx and Motorola Cable Modem. My ISP use pppoe protocol without any problem for me. But ISP has local network with local audio, video, PDF materials which I can share through ftp client. When I want to use local network I have to login with different username without any other change of setup. Problem is that I can’t connect using a router. When I disconnected router I did it using only the cable modem. Probably it is pppoe issue but I have no idea how to fix it. I've tried with pppoe relay option but without any success. I’m using 1.9.6.0 firmware.
Any other Idea ?
