Hi
I think the auto search more is a funktion which should be done by the core, not as a add-on to everythink. maybe you can patch something similar to the gift daemon ? i better dont shout too loud, but shouldnt it bee somethink like call the search sources funktions all xx secounds, maybe depending on the currend sources connected ??
Greets, and thx for your work!
