Page 3 of 15 FirstFirst 1234513 ... LastLast
Results 31 to 45 of 218
Thread: Прошивка Олега и обновление на WL-500gP
    Похоже что не работает Dns.
    По Ip пингуется везде и на роутере и на Pc. По имени только на роутере. В чем причина? Скрины во вложениях.
    May 2006
    Москва
    Operation Mode > Home gateway установлен? И лог бы поглядеть.
    У меня тоже есть роутер!
    Home GateWay установлен.
    Log
    Jan 1 03:00:02 syslogd started: BusyBox v1.1.3
    Jan 1 03:00:02 kernel: Starting kswapd
    Jan 1 03:00:02 kernel: Journalled Block Device driver loaded
    Jan 1 03:00:02 kernel: devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
    Jan 1 03:00:02 kernel: devfs: boot_options: 0x1
    Jan 1 03:00:02 kernel: NTFS driver v1.1.22 [Flags: R/O]
    Jan 1 03:00:02 kernel: pty: 256 Unix98 ptys configured
    Jan 1 03:00:02 kernel: Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI enabled
    Jan 1 03:00:02 kernel: ttyS00 at 0xb8000300 (irq = 3) is a 16550A
    Jan 1 03:00:02 kernel: ttyS01 at 0xb8000400 (irq = 3) is a 16550A
    Jan 1 03:00:02 kernel: HDLC line discipline: version $Revision$, maxframe=4096
    Jan 1 03:00:02 kernel: N_HDLC line discipline registered.
    Jan 1 03:00:02 kernel: loop: loaded (max 8 devices)
    Jan 1 03:00:02 kernel: PPP generic driver version 2.4.2
    Jan 1 03:00:02 kernel: PPP Deflate Compression module registered
    Jan 1 03:00:02 kernel: PPP BSD Compression module registered
    Jan 1 03:00:02 kernel: MPPE/MPPC encryption/compression module registered
    Jan 1 03:00:02 kernel: Amd/Fujitsu Extended Query Table v1.3 at 0x0040
    Jan 1 03:00:02 kernel: number of CFI chips: 1
    Jan 1 03:00:02 kernel: Flash device: 0x800000 at 0x1c000000
    Jan 1 03:00:02 kernel: Physically mapped flash: squashfs filesystem found at block 945
    Jan 1 03:00:02 kernel: Creating 5 MTD partitions on "Physically mapped flash":
    Jan 1 03:00:02 kernel: 0x00000000-0x00040000 : "pmon"
    Jan 1 03:00:02 kernel: 0x00040000-0x007f0000 : "linux"
    Jan 1 03:00:02 kernel: 0x000ec4e4-0x007f0000 : "rootfs"
    Jan 1 03:00:02 kernel: 0x007f0000-0x00800000 : "nvram"
    Jan 1 03:00:02 kernel: 0x003e0000-0x007f0000 : "flashfs"
    Jan 1 03:00:02 kernel: sflash: found no supported devices
    Jan 1 03:00:02 kernel: NET4: Linux TCP/IP 1.0 for NET4.0
    Jan 1 03:00:02 kernel: IP Protocols: ICMP, UDP, TCP
    Jan 1 03:00:02 kernel: IP: routing cache hash table of 512 buckets, 4Kbytes
    Jan 1 03:00:02 kernel: TCP: Hash tables configured (established 2048 bind 4096)
    Jan 1 03:00:02 kernel: ip_conntrack version 2.1 (256 buckets, 2048 max) - 344 bytes per conntrack
    Jan 1 03:00:02 kernel: ip_conntrack_pptp version 1.9 loaded
    Jan 1 03:00:02 kernel: ip_nat_pptp version 1.5 loaded
    Jan 1 03:00:02 kernel: ip_tables: (C) 2000-2002 Netfilter core team
    Jan 1 03:00:02 kernel: ipt_time loading
    Jan 1 03:00:02 kernel: NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
    Jan 1 03:00:02 kernel: IPv6 v0.8 for NET4.0
    Jan 1 03:00:02 kernel: IPv6 over IPv4 tunneling driver
    Jan 1 03:00:02 kernel: NET4: Ethernet Bridge 008 for NET4.0
    Jan 1 03:00:02 kernel: 802.1Q VLAN Support v1.7 Ben Greear <greearb@candelatech.com>
    Jan 1 03:00:02 kernel: All bugs added by David S. Miller <davem@redhat.com>
    Jan 1 03:00:02 kernel: FAT: bogus logical sector size 2816
    Jan 1 03:00:02 kernel: NTFS: Unable to set blocksize 512.
    Jan 1 03:00:02 kernel: VFS: Mounted root (squashfs filesystem) readonly.
    Jan 1 03:00:02 kernel: Mounted devfs on /dev
    Jan 1 03:00:02 kernel: Freeing unused kernel memory: 72k freed
    Jan 1 03:00:02 kernel: Algorithmics/MIPS FPU Emulator v1.5
    Jan 1 03:00:02 kernel: eth0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 3.90.37.0
    Jan 1 03:00:02 kernel: PCI: Enabling device 01:02.0 (0004 -> 0006)
    Jan 1 03:00:02 kernel: eth1: Broadcom BCM4318 802.11 Wireless Controller 3.90.37.0
    Jan 1 03:00:02 kernel: vlan0: add 33:33:00:00:00:01 mcast address to master interface
    Jan 1 03:00:02 kernel: aster interface
    Jan 1 03:00:02 kernel: vlan0: dev_set_promiscuity(master, 1)
    Jan 1 03:00:02 kernel: device eth0 entered promiscuous mode
    Jan 1 03:00:02 kernel: device vlan0 entered promiscuous mode
    Jan 1 03:00:02 kernel: device eth1 entered promiscuous mode
    Jan 1 03:00:02 kernel: br0: port 2(eth1) entering listening state
    Jan 1 03:00:02 kernel: br0: port 1(vlan0) entering listening state
    Jan 1 03:00:02 kernel: br0: port 2(eth1) entering learning state
    Jan 1 03:00:02 kernel: br0: port 1(vlan0) entering learning state
    Jan 1 03:00:02 kernel: br0: port 2(eth1) entering forwarding state
    Jan 1 03:00:02 kernel: br0: topology change detected, propagating
    Jan 1 03:00:02 kernel: br0: port 1(vlan0) entering forwarding state
    Jan 1 03:00:02 dnsmasq[68]: started, version 2.22 cachesize 150
    Jan 1 03:00:02 dnsmasq[68]: read /etc/hosts - 4 addresses
    Jan 1 03:00:02 dnsmasq[68]: reading /tmp/resolv.conf
    Jan 1 03:00:02 dnsmasq[68]: using nameserver 217.117.113.1#53
    Jan 1 03:00:02 dnsmasq[68]: using nameserver 217.117.112.1#53
    Jan 1 03:00:02 kernel: usb.c: registered new driver usbdevfs
    Jan 1 03:00:02 kernel: usb.c: registered new driver hub
    Jan 1 03:00:03 kernel: usb-uhci.c: $Revision: 1.275 $ time 10:25:12 Jun 17 2006
    Jan 1 03:00:03 kernel: usb-uhci.c: High bandwidth mode enabled
    Jan 1 03:00:03 kernel: PCI: Enabling device 01:03.0 (0000 -> 0001)
    Jan 1 03:00:03 kernel: ECHI PCI device 30381106 found.
    Jan 1 03:00:03 kernel: UCHI reg 0x41 = 10
    Jan 1 03:00:03 kernel: UCHI reg 0x41 changed to = 0
    Jan 1 03:00:03 kernel: usb-uhci.c: USB UHCI at I/O 0x100, IRQ 2
    Jan 1 03:00:03 kernel: usb-uhci.c: Detected 2 ports
    Jan 1 03:00:03 kernel: usb.c: new USB bus registered, assigned bus number 1
    Jan 1 03:00:03 kernel: hub.c: USB hub found
    Jan 1 03:00:03 kernel: hub.c: 2 ports detected
    Jan 1 03:00:03 kernel: PCI: Enabling device 01:03.1 (0000 -> 0001)
    Jan 1 03:00:03 kernel: usb-uhci.c: USB UHCI at I/O 0x120, IRQ 2
    Jan 1 03:00:03 kernel: usb.c: new USB bus registered, assigned bus number 2
    Jan 1 03:00:03 kernel: usb-uhci.c: v1.275:USB Universal Host Controller Interface driver
    Jan 1 03:00:03 kernel: PCI: Enabling device 01:03.2 (0000 -> 0002)
    Jan 1 03:00:03 kernel: ehci_hcd 01:03.2: PCI device 1106:3104
    Jan 1 03:00:03 kernel: ehci_hcd 01:03.2: irq 2, pci mem c00a7000
    Jan 1 03:00:03 kernel: usb.c: new USB bus registered, assigned bus number 3
    Jan 1 03:00:03 kernel: ECHI PCI device 31041106 found.
    Jan 1 03:00:03 kernel: ECHI reg 0x49 = 80010f20
    Jan 1 03:00:03 kernel: ECHI reg 0x49 changed to = 80010f00
    Jan 1 03:00:03 kernel: ECHI reg 0x4b = 80010f09
    Jan 1 03:00:03 kernel: ECHI reg 0x4b changed to = 80010f29
    Jan 1 03:00:03 kernel: PCI: 01:03.2 PCI cache line size set incorrectly (0 bytes) by BIOS/FW, correcting to 32
    Jan 1 03:00:03 kernel: ehci_hcd 01:03.2: USB 2.0 enabled, EHCI 1.00, driver 2003-Dec-29/2.4
    Jan 1 03:00:03 kernel: hub.c: 4 ports detected
    Jan 1 03:00:03 kernel: usb.c: registered new driver usblp
    Jan 1 03:00:03 kernel: printer.c: v0.13: USB Printer Device Class driver
    Jan 1 03:00:04 kernel: hub.c: connect-debounce failed, port 1 disabled
    Jan 1 03:00:04 kernel: hub.c: new USB device 01:03.2-1, assigned address 2
    Jan 1 03:00:04 kernel: usb.c: USB device 2 (vend/prod 0x5e3/0x702) is not claimed by any active driver.
    Jan 1 03:00:05 kernel: usb.c: registered new driver audio
    Jan 1 03:00:05 kernel: audio.c: v1.0.0:USB Audio Class driver
    Jan 1 03:00:05 kernel: Linux video capture interface: v1.00
    Jan 1 03:00:05 kernel: SCSI subsystem driver Revision: 1.00
    Jan 1 03:00:05 kernel: Initializing USB Mass Storage driver...
    Jan 1 03:00:05 kernel: usb.c: registered new driver usb-storage
    Jan 1 03:00:05 kernel: scsi0 : SCSI emulation for USB Mass Storage devices
    Jan 1 03:00:05 kernel: Vendor: HDT72251 Model: 6DLAT80 Rev: 0811
    Jan 1 03:00:05 kernel: Type: Direct-Access ANSI SCSI revision: 02
    Jan 1 03:00:05 kernel: Attached scsi disk sda at scsi0, channel 0, id 0, lun 0
    Jan 1 03:00:05 kernel: SCSI device sda: 321672960 512-byte hdwr sectors (164697 MB)
    Jan 1 03:00:05 kernel: Partition check:
    Jan 1 03:00:05 kernel: p1
    Jan 1 03:00:05 kernel: USB Mass Storage support registered.
    Jan 1 03:00:05 kernel: vlan1: Setting MAC address to 00 17 31 42 44 77.
    Jan 1 03:00:05 kernel: vlan1: add 33:33:00:00:00:01 mcast address to master interface
    Jan 1 03:00:05 kernel: vlan1: add 33:33:ff:42:44:77 mcast address to master interface
    Jan 1 03:00:05 kernel: vlan1: add 01:00:5e:00:00:01 mcast address to master interface
    Jan 1 03:00:16 kernel: VFS: Can't find ext3 filesystem on dev sd(8,0).
    Jan 1 03:00:16 kernel: MSDOS FS: Using codepage 950
    Jan 1 03:00:16 kernel: MSDOS FS: IO charset cp950
    Jan 1 03:00:16 kernel: FAT: bogus logical sector size 22278
    Jan 1 03:00:16 kernel: VFS: Can't find a valid FAT filesystem on dev 08:00.
    Jan 1 03:00:16 kernel: FAT: freeing iocharset=cp950
    Jan 1 03:00:16 kernel: kjournald starting. Commit interval 5 seconds
    Jan 1 03:00:16 kernel: EXT3-fs warning: mounting unchecked fs, running e2fsck is recommended
    Jan 1 03:00:16 kernel: EXT3 FS 2.4-0.9.19, 19 August 2002 on sd(8,1), internal journal
    Jan 1 03:00:16 kernel: EXT3-fs: recovery complete.
    Jan 1 03:00:16 kernel: EXT3-fs: mounted filesystem with ordered data mode.
    Jan 1 03:00:16 USB storage: ext3 fs mounted to /tmp/harddisk
    Jan 1 03:00:16 FTP server: daemon is started
    Nov 20 23:30:52 ntp client: Synchronizing time with time.nist.gov ...
    А что говорит nslookup www.rbc.ru, запущенный на ПК?
    nslookup www.rbc.ru, запущенный на ПК во вложении.
    В чем же все-таки проблема? Может где-то, что-то нужно прописать?
    Ведь я не меняю вообще никаких настроек. Только перепрошиваю роутер прошивкой OLEG и пинг перестает работать с PC (но из telnet с роутера работает). Возвращаюсь на прошивку ASUS и все прекрасно пингуется.
    Дело в Вашем провайдере. Их ДНС сервера не работают в рекурсивном режиме. У АСУС другой днс-прокси, который это как-то переваривает. Вы можете попробовать прописать эти ДНС прямо ПК.
    А чем же роутер с IP 192.168.1.1 принципиально отличается от PC c IP 192.168.1.2. Он ведь находится в той же сети и выходит в инет такими-же путями как и PC. Или я не прав.
    Софтом, который расчитан на то, что сервер провайдера будет выполнять рекурсивные запросы. А Ваш чудо провайдер на вопрос www.rbc.ru вместо нормального ответа возвращает список с корневыми серверами в зоне .ru, а дальше типа Вы сами думайте. Это неправильно. Спросите у провайдера, зачем он так делает.
    Добрался до роутера. Прописал DNS провайдера на компьютере DNS1=217.117.112.1 и DNS2=217.117.113.1
    Результат работы nslookup изменился, более того он стал такой же как и с прошивкой ASUS, но по имени все равно не пингуется. Где копать? А из telnet с роутера всегда все отлично пингуется.
    Скрины приложены.
    PS. Есть еще компьютер с Linux, там как прописал DNS провайдера, вроде заработало.
    В итоге, проблема где то в DNSMASQ.
    Взял старый, из прошивки ASUS, версии 1.10. Он там похоже вообще не меняется, во всех прошивках одинаковый. Запустил руками. Все комьютеры заработали. Пингуется все с отлично. DNS везде прописан роутеровский 192.168.1.1. Вроде как меня устраивает.
    Посему вопрос, как сделать, чтобы всегда грузился 1.10 вместо 2.17?
    1. В post-boot убивать процесс с DNSMASQ 2.17 и запускать 1.10 (как-то не красиво)
    2. Пересобрать прошивку, включив в нее 1.10. (но тогда при появлении новой придется, если не работает, каждый раз собирать самому.)
    Есть-ли какой-нибудь еще способ заменить DNSMASQ на нужный без сборки новой прошивки?
    PS. В дальнейшем, конечно попробую разобраться чем они так принципиально отличаются (думаю где-то в forward.c), но сейчас надо что-бы интернет на всех компьютерах работал без проблем.
    Спасибо Oleg за наводку на DNS!!!
    Quote Originally Posted by AlexLeb View Post
    killall dnsmasq
    /opt/dnsmasq-1.10 (или как там у вас)
    Sorry for my bad English.
    Как руками сделать это понятно. Вопрос в том, как сделать, чтобы при перезагрузке автоматически стартовала нужная версия Dnsmasq.
    Приобрел на днях 500W. Девайс мне понравился, и не смотря на то, что он моих проблем на данный момент не решает, здавать обратно не собираюсь
    На вскидну что имеем без каких либо настроек:
    Скорость записи на USB и чтения с USB у меня оказалась практически одинаковой, а именно 3.5MB\s
    Проблема с домашними сетями WAN over LAN PPTP так и не решена
    Последние исходники (1.9.7.6 от 20061211) выложены в битом архиве.
    В общем инфа устарела. Сейчас я пишу это сообщение при стандртной прошивке.
    В инет зашел из домашней сети Dhcp+pptp. Локалка пока не работает и ДНС пока тоже не работает (прописал ручками на клиентской машине).
    Не фонтан конечно, все придется руками прописывать, но все таки работает.
    Конфиг во вложении:
  1. Новая прошивка 1.9.2.7-d/-rtn от энтузиастов и Олега
    Last Post: 16-11-2020, 09:31
  2. Обновление CFE на Asus RT-N66U для расширения NVRAM до 64KB
    Last Post: 22-08-2016, 11:01
  3. Прошивка Олега на роутере DIR-320
    By sorine in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 07-08-2011, 22:25
  4. Последняя прошивка от Олега 1.9.2.7-10.7
    Last Post: 17-12-2010, 11:06
  5. Стабильная прошивка от Олега 1.9.2.7-10
    Last Post: 29-03-2008, 19:30
