about 60 views and no answer??
come on, please help me
i think it is a problem of windows xp because i read that in several other threads in different boards..
I am new here. I bought the ASUS WL500G about 2 weeks ago and everything works properly. Then i upgraded the firmware to 1.7.5.6 CR3 and my problem began: I configured my new server ( connected to the router with a netgear 54Mbit wireless pci card ), configured the router properly but my server cant establish a connection to the router, even worse, he didnt find him at all ( windows xp pro ). so i updated to 1.7.5.6 CR4 but the problem is still there. I tried it with my computer and installed a 11Mbit siemens wireless pcmcia card and it is the same problem like i had with my server.
DHCP is activated, internet connection works fine but only if i connect my pc with a network cable ;-/
i dont know how to solve this problem - i am frustrated because additionally the port triggering for my ftp doesnt work, either. anyone know how does this work?
greetz & thanx for your replies
chillkuegelchen
edit:
i scanned with Netstumbler and i can find my SSID and the signal strength is ok, the siemens tool does find my AP as well, but Windows doesnt find a available wireless network.
i think it's an issue of not setting up correctly
try following this thread first
https://wl500g.info/showthread.php?t=10
do exactly as told there..
hi,
i think it isnt a settings problem, because my card work fine since yesterday 2 am
i recognized only that the computer hangs up sometimes when i am up/down loading something through flash fxp while using emule on the server.
But the other problem with wan ---> lan / ftp server doesnt work like i want to
I put up the Triggerports correctly ( 5656 for ftp and 33000-34000 passive mode ),settings of bulletproof ftp are ok ( passive mode, user name, home dir etc ) but it still doesnt work
Can anybody tell me how i can make the right settings through Telnet - i can establish a connection to my router with HyperTerminal but then ... ??
greetz - thanx for answers
chillkuegelchen
