just noticed that my dynamic ip function will not work. I configured everything according to the manual. But somehow it wont work.
Do you have any idea what might be the problem
Thanks for your help
Torsten
Torsten
What does the system log say?
LK
now the login works. I entered the e-mail adress in stead of the user name. web interface of the wl700 is confusing telling to enter eather one of the information. Onle the username seems to work.
However now it's registering my local IP 192.168.1.249 at dyndns. Does anybody how to tell the router that this is not the IP distributed by my ISP???
I have typed an verified the same login data as I use at www.dyndns.org
Any ideas?
bye
antoschka
