Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 61 to 75 of 108
Thread: WL-500gP with 3G USB Modem and Oleg's Firmware
  1. #61
    Hi guys, I've managed to flip my modem I think but I don't know what to do next!
    I've got this from lsusb:
    P: Vendor=12d1 ProdID=1001 Rev= 0.00
    S: Manufacturer=HUAWEI Technology
    S: Product=HUAWEI Mobile
    C:* #Ifs= 5 Cfg#= 1 Atr=e0 MxPwr=500mA
    I: If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
    E: Ad=81(I) Atr=03(Int.) MxPS= 64 Ivl=5ms
    E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
    E: Ad=01(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
    I: If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
    E: Ad=83(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
    E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
    I: If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
    E: Ad=84(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
    E: Ad=03(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
    I: If#= 3 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
    E: Ad=85(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
    E: Ad=04(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
    I: If#= 4 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
    E: Ad=05(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
    E: Ad=86(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
    T: Bus=01 Lev=02 Prnt=02 Port=01 Cnt=02 Dev#= 3 Spd=12 MxCh= 0
    D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
    And I configured the connection in the router has an GPRS/EDGE/UMTS config, but when I press connect I get this error:
    Jan 1 00:14:16 pppd[1261]: no device specified and stdin is not a tty
    What should I do next???
    Thankx
  2. #62
    Anyone? Please?
  3. #63
    hi have you solved? i have a vodafone e180v and a asus wl500gp v2 . which firmware? how to? could you send me your??
    thnaks
  4. #64
    Hi, I haven't managed to make it work yet ... that's how far I've gotten. Maybe we can help each other.
    What I think I've managed to do is to flip the modem ... but I never made it connect. Are you Portuguese by the way?
  5. #65
    i'm italian.
    My problem is that i can't also install the firmware inside..... how to put in recovery mode? how to install the firmware?
    i have heard to install kopper firmware and the latest should be WL500gp-1.9.2.7-10-USB-1.71.trx . isn't it?
    than what to do?
    thanks
  6. #66
    Hi, please how to install your firmware into router? any guide for mac or windows? with some guides on internet i can't do it.
    how have you done? how to put in recovery mod?
    can i use with this firmware also the huaewi e180?
    thanks
  7. #67
    i have an asus wl500gp v2 with a huawei e180. i can't configure to connect to internet . i use koppel. please help me....
    i am a nebbie
    thanks
  8. #68
    WL500G Delux with Huawei E1750 GPRS UMTS modem, can't connect
    I have followed this guide: http://wl500g.info/showthread.php?t=13480 and installed the frimware WL500gx-1.9.2.7-10-USB-1.71.trx.
    I have an USB GPRS modem, Huawei E1750, but this is not selectable in the USB GPRS settings of this firmware. I have tried to select all the Huawei modems but the connection does not work.
    Is there a firmware, which supports this modem?
    Is there a specific setting of the firmware I am using, whisch makes the connection work?
    Thanks You
  9. #69
    Question WL500g Premium and Huawei E 156G?
    Hello!
    I have WL500g Premium (WL500gpv2, firmware: 1.9.2.7-10-USB-1.71) and Huawei E 156G modem.
    Is it possible to run this modem? I tried many times in many ways but It doesn't work.
    Thank you all in advance for help. Regards from Poland.
  10. #70
    Oct 2009
    Modena - Italy
    Yes you can.
    I have a WL500gP V2 with the last firm Koppel 1.71 and modem Huawei E156G
    I set in the configuration web interface the model E169
    It works perfectly even if it is not the same model
    Have the same VendorID and ModemID
  11. #71
    Great to hear that!
    Thank you very much for replay and solution.
    I'll try it in the evening - I'll hope that I didn't change all other options
    Would you be so kind and write me down all necessary options to run this modem?
    Best Regards,
    Kalixo
  12. #72
    Oct 2009
    Modena - Italy
    Excuse me if I am wrong in previous post.
    The modem that I set in the router is e220.
    Here you find the pictures of how I set the router.
    Best Regards
  13. #73
    Thanks again
    Thaks for screenshots
    Unfortunatly, it didn;t helped... but i found that somenthing's wrong with my soft, becasue my asus also can't recognise any usb device (FAT).
    I'll try tu update firmware and try again. Hope it'll work
    Thanks again.
  14. #74
    I have a Dir-320 and I have successfully installed the latest oleg firmware.
    I want use a 3g modem (Huawei E1692) as Wan connection.
    I try to flash my router with the latest koppel firmware, but after the flashing procedure and 5 minutes, the router seemed dead.
    Is possible use koppel with it?
  15. #75
    Question
    Quote Originally Posted by ecser99 View Post
    Thanks You
    I am still waiting, is there a new firmware? Any solution?
    Thanx
  1. New oleg firmware version
    By Lesiuk in forum WL-500gP Firmware Discussion
    Last Post: 13-05-2016, 04:55
  2. RT-N10U B is supported by oleg firmware?
    By Jeony in forum English Discussion
    Last Post: 10-05-2013, 07:44
  3. Oleg firmware - older version
    By kvr in forum WL-500gP Firmware Discussion
    Last Post: 17-04-2012, 19:04
  4. Real time clock with Oleg's firmware
    Last Post: 21-04-2009, 09:20
    Last Post: 21-10-2004, 14:55
