a lightning strike fried our telephone line and somehow damaged the router:
When connecting modem and wan-port, the modem and router report "no cable attached". But when I connect modem and lan1 both show the green LEDs and signal that the cable is working. With that setup I am even able to establish a direct dial-up connection from my PC via the router to my adsl provider and access the internet.
Anything else also still works: printing, wlan, i just did a firmware upgrade, syslog seems to be normal, ...
Is it possible to tell the router to use lan1 for pppoe connections?
Is it possible to swap wan and lan1 internally? So router uses lan1 as wan and vice versa?
Do you have any other suggestions?
Router: WL500g
Firmware: 1.9.2.7-7e
Internet: adsl, pppoe
Do you need any other information?
Thanks for your help,
Blue
