Results 1 to 15 of 27
Thread: WL500g Premium beta firmware removed
    Exclamation WL500g Premium beta firmware removed
    Removed from my site, due to number of dead router reports. I would check on this.
    Please flash original ASUS firmware to avoid problems.
    Feb 2005
    Germany - Frankfurt a.M.
    Any suggestions why they died?
    Not yet.
    Recovery is possible by wiping current settings: just ground flash pin #9 and turn the device on.
    Thank you very much, Oleg! Pin 9 did the trick, I tried pin 10 and 12 before with no luck. How did you know it was pin 9??? I could not figure that out from the flash's manual
    In the german forum, we have several reports about dead routers, too. It seems like all had the samba demo stuff activated, maybe that helps in finding the cause of this problem...
    regards,
    sMiLe
    Samba could not cause any problems.
    Do you've dyndns service active? Which connection type do you use?
    i had dyndns active, but only with the original firmware. Then I changed to your firmware, reset the whole config but didn't configure dyndns again.
    What do you mean, which connection type? For WAN? PPPoE...
    Are you sure about samba? maybe large file transfers could do any harm when using too much memory? Anyhow, I have no clue about this busybox stuff...
    Quote Originally Posted by sMiLe
    Well, try to kill it again then, to check if this is samba...
    The problem seems to be is that some nvram variable was invalid, so it was unable to configure LAN interface for recovery. Samba does not do any modifications to nvram and it does not commit it.
    The thing which is looking strange to me is slow flash write/erase compared to other routers. But it is the same for both asus/openwrt/my firmware. Seems to be flash chip feature...
    Well, nice try I'm happy it's working again, I dunno if I should risk another death, maybe the router has 9 lives like a cat?
    On the other hand, the new router is already on its way ...
    BTW: Oleg, could you explain shortly how you figured out that Pin 9 has to be used? I'm curious and would like to know more about this stuff
    Edit: Ok I've pre4 running again, Samba activated, no problems so far, but I didnt transfer anything via samba yet, I'll try this tomorrow...
    my WL500gP is also died! Without any reason! The unit dies over night!
    But the PIN 9 - shortcut works fine! You can also use the solder tack near the PIN 9 (I have marked it on the pic) for nervous hands
    Name:  Hardware-Recover WL500gP.jpg
    what is the procudure exactly
    how long must i hold pin 9 to ground for restore
    You have to do it while pluggin the power in. If I remember this correctly, the power LED stays off when everything is OK. Then unplug the power, remove the grounding from Pin 9 and press the restore button while plugging the power cord back in. A slowly blinking power LED should signal that the device is in the restore mode...
    This is just the highest address bit... Grounding causes nvram to fail during CRC.
    Jun 2005
    Slovenia
    Another way to cause CRC without opening a box is to press Cancel during upload with firmware restoration tool.
    Quote Originally Posted by oleo
    yeah, but if the restoration mode is not working... Thanks for this explanation!
    Jul 2006
    Slovakia
    i have started upload Oleg firm. again and then I have unplag power cable. then plug cable on to device and router is in "crash" mode :-)And recowery is working. Sorry for English
  1. Router doesn't see USB disk anymore
    By Styno in forum WL-500g Q&A
    Last Post: 15-08-2006, 08:37
  2. Firmware v1.7.5.6 CR5 [Oleg]
    Last Post: 14-07-2004, 21:54
  3. Total crash every day
    By Djuri in forum WL-500g Q&A
    Last Post: 09-06-2004, 09:05
  4. Usb hdd problem
    By djbokkeman in forum WL-500g Q&A
    Last Post: 01-06-2004, 00:32
  5. Replies: 6
    Last Post: 26-05-2004, 17:00
