USE THIS FIRMWARE AT YOUR OWN RISK!
Compatible with:
Changelog:WL-500gD
Download files here:WL-500gD English Firmware Version , version 1.9.6.0
fix: PPTP with DHCP Client
http://website.wl500g.info/beta/wiza...firmware&id=51
Compatible with:
Changelog:WL-500gD
Updated my box 2 times, both resulted in a dead router.. Used PIN 10 trick to get it back. BEWARE!!
@sandoval: it seems you have a problem with your unit, because i flashed my unit with 1.9.6.0 with the new firmware ... and the only problem that occured was that my computer couldn't connect anymore to my webhosting ftp server ... but i think this problem occured because i didn;t restore factory settings and reconfigure the unit.
Updated to 1.9.6.0
No problems...
this is a known problem:
http://vip.asus.com/forum/view.aspx?...Language=en-us
I have the same problem with ftp after upgrading to 1.9.6 on my WL-500g deluxe
Ftp connection to remote host is established, passive mode entered but response on LIST command is never received by ftp program (filezilla). All works fine when I bypass my Asus AP and connect PC directly to my ADSL modem. All used to work fine with my previous firmware.
Did not restore factory settings before upgrade always upgraded succesfully without doing so before.
