Although this is a A620 forum, I think this question could also belong here
I recently bought a A716 and I can only say "a great macine for a good price"
The only annoyance is that bluetooth and wlan can not be switched on at the same time, the nlue light tells you that one of the two is switched on, but not which one
Anyone out there with a solution for that or is it just an internal hardware limitation ?
Adding a cf-wlan card solved the problem for a while , but not in the long run
