Results 1 to 5 of 5
Thread: Oleg's Firmware Wireless Driver Problem
    Exclamation Oleg's Firmware Wireless Driver Problem
    I'm using Oleg's 1.9.2.7-7c.
    Whenever I connect to wl500g wire-less, the signal-quality is excelent but the performance when accessing the internet (wan port) is very poor. For example, a download that runs at ~200kb/s on the wired lan, runs at -20kb/s on wireless connection - All wired internet access is working well! - except wireless.
    I tried different Asus firmwares (inc. latest version, 1.9.5.0) and the problem disappears.
    Anyone solved this problem already?
    Is there any way to use Asus's original wireless driver on Oleg's 1.9.2.7-7c?
    Thanks in advance
    you can try this page with firmware 1.61, it is very fast and it suppport cdma
    http://koppel.cz/cdmawifi/download/
    The firmware is in english
    I need to run OpenVPN and some extra applications on the wl500g.
    Only with OIeg's firmware I can do this.
    Any other solution?
    This is oleg's firmware with several patches.
    Cannot get comunication beetween two wireless connected machines
    Hi all
    My router is a WL500g Deluxe and I'm using WL500gx-1.9.2.7-6b-CDMA-1.61 firmware because of CDMA support.
    I'm having some trouble with wifi. I can't comunicate beetween two machines that are both connected through wifi, not even ping. However, I can get communication beetween the same two machine if at least one connected through wired lan. I also can communicate with the router from any machine (wired or wireless). However I think that this wasn't happening in the past.
    Any ideas?
    Thanks in advance
  1. firmware of Wl-hdd on yakumo wireless Storage 60
    By surfingrace in forum WL-HDD Firmware Releases
    Last Post: 15-11-2010, 09:11
  2. oleg 1.9.2.7-7c with Asus Wireless driver
    By njosef in forum WL-500g Custom Development
    Last Post: 11-04-2006, 09:27
  3. No wireless with recent firmware versions
    By lantao in forum WL-500g Q&A
    Last Post: 12-06-2005, 15:14
  4. Trying to get IDE working on Oleg's Firmware
    By hugo in forum WL-HDD Q&A
    Last Post: 01-11-2004, 18:06
    Last Post: 21-10-2004, 14:55
