Results 1 to 1 of 1
Thread: [A620] ISSUE - White Screen
    Nov 2003
    Eindhoven
    Exclamation [A620] ISSUE - White Screen
    as i've never found this issue at any forum i'll post it here.
    known possible issue with temporarily and permanent solution:
    PDA gives white screen when turning on
    * fixes which will NOT work:
    soft reset - screen stays white, you'll hear after few minutes a PLING sound for calibrating your screen (but you can't see where to calibrate)
    hard reset - screen stays white, same as above
    firmware upgrade - you will not even see it's upgrading it stays white!
    * temporarily fix:
    remove the battery for 1 second
    note: THIS WILL VOID YOUR WARRANTY AND WILL NOT ENTITLE YOU TO SEND IT IN FOR RMA ANYMORE.
    * fixes which WILL work:
    send in to your reseller which will send it in to Asus for motherboard replacement
    note: this issue has permanently fixed AFTER serial number beginning with 44XXXXXXXX this means when serial numbers is starting with 45XXXXXXXX you can't have the problem.
    note 2: this issue does NOT apply to all serial numbers before 45XXXXXXXX
    if you send in your pocketpc for this issue, and it does not display a white image ASUS will not replace the motherboard for you.
  1. screen
    By juergenb52 in forum WL-HDD Custom Development
    Last Post: 06-06-2006, 06:51
  2. black/white jpg ?
    By ottohans in forum WL-500g Q&A
    Last Post: 08-02-2005, 10:44
  3. [A620] Installation of TomTom Navigator
    By d_day91184 in forum MyPal A620 / A620BT / A716 / A730 / A730W Q&A
    Last Post: 02-02-2005, 11:30
  4. Internet connection issue
    By mabirkinshaw in forum WL-500g Q&A
    Last Post: 02-10-2004, 22:43
  5. [A620(BT)] How to reset
    By Antiloop in forum MyPal A620 / A620BT / A716 / A730 / A730W Q&A
    Last Post: 13-06-2004, 03:54
