Results 16 to 30 of 56
Thread: running php on wl500g
    Feb 2004
    Ok, here is a working minimal build of the PHP4 enabled thhtpd
    The extensions are mostly disabled now, I'll see if I can build one that is more 'feature enabled'
    Yummy. Going to test this... Thanks Erik
    Dec 2004
    Hungary
    THTTPD works fine... :-)
    Which PHP commands are implemented? (The PHP echo is correct! ;-))
    SC
    Soundrel Days
    Most command are working.
    Funnily, preg_replace() doesn't, even if other text replace command do
    Feb 2004
    Ok and here is the (almost)full version.
    For me to sucessfully run it I have to add some swap space
    With this one I sucessfully run some of the nice scripts like Gallery & phpsysinfo
    Good luck
    It is working fully for me. Even without swap space... Thanks for this Erik
    I can run guppy PHP server as frontend on the WL-hhd. Thats cool for testing and debugging.
    Dec 2004
    Hungary
    It works me too. Thanks for creators...
    Soundrel Days
    Here is a modified script to get HD info under phpsysinfo. You must replace the corresponding file in /include/os in your phpsysinfo root
    Dec 2004
    Hungary
    I tried the modified script. Correct!!!
    Soundrel Days
    It seems the more we have, the more we want. I Would like to add some libs. Did you have to modify your source? or was it a makefile optimisation story?
    Would you mind giving here your make info to add our own libs to the process?
    Quote Originally Posted by erik_bies
    I gave it a try and compiled these.
    Here is PHP3 & thttpd (without PHP4). I'll give the thttpd+php4 combi another try later, but sofar that resulted in a long list of errors
    For me it is working on 1.9.2.7-2 software.
    Good luck
    How do I install this?
    I use Firmware v.1.9.2.7 CR3
    copy it to router using ftp, run it using telnet
    something like ./thttpd-php4f_2.21b-2_mipsel -p 81 -d yoursourcefolder
    put some php files in the source folder, give them enough rights (get up stand up!) and learn how to use php.
    Feb 2004
    take the config file out of the PHP3 package
    than take the thhtpd+PHP4 file.
    edit the script with your desired directories. dump some files in the www directory (from config file)
    run
    thttpd -C thttp.conf
    make sure ur running it on a port different from port 80
    there is a small change in the dns.c, and fiddeling with makefiles for the remaining. I'll try to dig up and make a wiki page
    BTW. thanks for the patch of the Linux.inc.php file. Do you maybe know why it does not want to see the 2nd file system?
    It it shown using a mount command?
    Apr 2004
    Netherlands
    Hmm, I'm giving phpsysinfo (2.3) a try and I get the following error:
    Error: Linux is not currently supported
    Any ideas?
  1. Running Giftd on wl500g
    By DeF in forum WL-500g/WL-500gx Tutorials
    Last Post: 17-04-2006, 12:57
  2. samba, ftp, I can`t get it running. PL Help!
    By atomilein in forum WL-500g Q&A
    Last Post: 23-04-2005, 08:51
  3. Samba running
    By erik_bies in forum WL-500g Custom Development
    Last Post: 23-01-2005, 20:16
  4. running a second webserver
    By ronin in forum WL-500g Q&A
    Last Post: 23-08-2004, 04:19
