Hallo
I want to update my Yakumo Wireless Storage, but i doesn't work.
Installed is a Yakumo 1.2.3.6 Firmware, and in the first step i want to install the ASUS 1.2.3.9 Firmware.
I have allready read all notes like this one:
It´s a little bit tricky to install - you have to know how. And that´s my way (there was one weekend of trying):
- download last original ASUS firmware from internet, not the other versions from oleg
- assign a fixed IP Adress for Yakumo Wireless Storage 60 in Setuppage, such as 192.168.001.015
- put Yakumo Wireless Storage 60 on LAN (by cable!, wireless doesn´t work)
- press the button on back of device at least 5 seconds until the power lamp turns of, after some seconds all lamps are off: the device is off
- pull the power cable
- press and hold the button an put the power cable in, wait some seconds until the power lamp start to blink, release the button
- device is now in "update"-mode
- start the software "firmware restoration" from Yakumo utility directory
- insert the path to the downloaded asus firmware
- press upload -> the upload should be start
- after this procedure you and rebooting your device you can go the the setup page and you will see the asus wl-hdd setup
- from this point you can install all other firmware versions including the ons from oleg via the setup page
- if you like to use the drive with twonky: it runs, no problem
But, this doesn't work. The Restoration Software doesn't find the Yakumo.
Hardware Situation:
Yakumo IP Static: 192.168.100.20
PC IP: 192.168.100.10
Subnet 255.255.255.0
How can I get the Yakumo in recovery mode, because the software says "No device....in...mode"
I also tried to use a manual string like tftp -i 192.168.100.20 PUT filename
Any ideas? Thanks a lot
