Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2958
RAM upgrade for wl-500gx - Page 3
Results 31 to 45 of 54
Thread: RAM upgrade for wl-500gx
    Nov 2004
    Sweden
    WL-500g
    Does somebody know if there is some guarantee this is to work on a WL-500g?
    I have taken a look at the schematics of the WL-500GX but I do not find the R68&R69 connected in the same manner in the WL-500G. I do not get continuity between R68&R69 and leg 36.
    Nov 2004
    Sweden
    On WL-500g leg no. 36 (SD_A12) on memory chip is not connected hence memory upgrade is not possible.
    I'm definitely interested in this upgrade. It looks like this module would do the trick for 2 128 MB upgrades. What say ye?
    http://www.newegg.com/Product/Produc...82E16820136009
    I like the idea of buying new chips from Digikey because then you don't have to desolder, but I am pretty good at desoldering, and considering the price difference, the Kingston module seems good.
    Jun 2005
    Slovenia
    Looks OK. Go for IT. Post results.
    how?
    nvram set sdram_init=0x2010
    nvram set sdram_ncdl=0
    nvram commit
    I've 128 MB of ram enabled on the WL500g Premium. It's detected just fine.
    Hi
    How can this be done? Does gp has 128mb on board or a (de)soldering operation is needed?
    Thanks
    Jun 2007
    Poland
    WL-500gp problem with RAM upgrade to 128 MB
    Hi Guys,
    Now I'm using competitive firmware DD-WRT,
    but I tried to upgrade WL-500gp to 128MB RAM according to post http://wl500g.info/showthread.php?t=...ighlight=hynix
    I need more RAM to run asterisk. Now I'm using Torrent client and FTP server with USB disk.
    Unfortunately upgrade failed. Slowly I'm induce to Oleg's firmware, but decision like this required time to configure router once again and familiarize with new firmware.
    I'm not a linux specialist, so this is not easy for me.
    This is quote from DD-WRT forum, but nobody can help me. Maybe somebody of you give me answer.
    [QUOTE]I'm tried failed RAM upgrade (to 128 MB) on the WL-500gp. It was done by follow post from Oleg's forum:
    [URL="http://wl500g.info/showthread.php?t=7048&highlight=hynix (is written in russian language, but I know it a little). Before replacing memory chip from 2x HY5DU281622ETP-5 to 2x HY5DU121622CTP-J, (which should give me 128 MB) I sets NVRAM settings (only 16 MB):
    nvram set sdram_init=0x000b
    nvram set sdram_config=0x0032
    nvram commit
    Desoldering and resoldering was not so easy (I haven't experience with hot air station).
    Finally router doesn't want boot correctly. Power led came on, but router don't respond on ping. So I replace memory chips once again for new one (maybe damaged ? over temperature ?), without new result, and again new chip and again the same. It was possible to put router in firmware restoration state (by pressing together restoration switch with power on), power led start flashing, but putting firware was not possible.
    My questions is:
    DD-WRT can support 128 MB RAM ?
    How works memory detectiom at startup ? Only by NVRAM settings ? CFE ?
    Generally what was wrong ?
    I came back to old one memory chips, work fine.
    sorry for my english[/QUOTE]
    Which setting I have to set before upgrade ?
    Problem was with firmware or not ?
    regards Gidus
    Jun 2007
    Poland
    So, I understand my mistake. Problem probably was with NVRAM settings.
    Module HY5DU121622CTP-J is a DDR333, works only with CL2 or CL2.5
    I try to understand rules for set correct nvram variable settings sdram_config,sdram_init http://wl500g.dyndns.org/sdram.html
    but could you help me and suggest correct one for
    HY5DU121622CTP-J ? http://www.hynix.com/datasheet/pdf/d...TP(Rev1.5).pdf
    regards Gidus
    Have anyone did it success , Pls tell the step in eng.
    Thank you very much..
    Has anyone can tell step for wl500gp.
    wl500gp 128Mb ram updgrade
    Can anyone translate this thread or provide step by step guide?
    Would it be nice to have 128Mb of ram for wl500gp
    Mar 2007
    Budapest / Hungary
    use babelfish it to translate
    George
    Quote Originally Posted by KGy View Post
    George
    Yes I have already tried babelfish and google translate but I'm afraid I'm missing something.
    typically, what are the tools that u will need to do these stuff? .. that is, adding more RAM. from what i gather, we must have excellent de-soldering and soldering skills to do so?
    are there multiple methods to do it? where can I find tutorials on how to solder on new RAMs?
    lastly, i do not understand.. what is the issue that is limiting us from adding alot of memory? why can't the router detect properly / function as it should if the RAM used is too large?
    Apr 2006
    Heesch, Netherlands
    Quote Originally Posted by oleo View Post
    I 've upgraded two Deluxe routers to 64MB with chips from 128MB PC 133 SDRAM module.
    What surprised me is that no NVRAM variables were needed to recognize additional RAM.
    I've also wrote mini howto upgrade for this occasion.
    Oleo, I have a deluxe for testing, and a 4 chip 128MB PC100 sdram package. So, I'm ready for the upgrade, but is there a reason for PC133 instead of PC100?
    In your tutorial, you say that 128mb is the maximum possible configuration. If I find a 4 chip 256MB module, will it bring me 128MB when I use your tutorial?
    Solar inverter monitoring with Asus wl500gx http://solar.reinieren.net (dutch)
    Jun 2005
    Slovenia
    PC133 means 60ns while PC100 means 70ns RAM speed. If you look at schematics you'll see -6 RAM is specified. I could not tell you if PC100 will work, but I assume that it should. If you look at http://wl500g.dyndns.org/sdram.html you will see that there is cas_latency whch is calibrated during boot if sdram_ncdl is reset. So there is a chance that PC100 should work.
    With 256MB 4chip module you could have 128MB router. Oleg reported success on Premium, while I've read that Deluxe had problems with 128MB.
  1. Some questions regarding debricking a 500gx
    By fusterjj in forum WL-500g Q&A
    Last Post: 10-01-2006, 07:52
  2. WL-500g Delux, Nahc Upgrade nur noch ???? am Web-Interface
    By colalight890 in forum German Discussion - Deutsch (DE)
    Last Post: 09-01-2006, 20:50
  3. Nach Firmware Upgrade Kein Wlan
    By ibiza in forum German Discussion - Deutsch (DE)
    Last Post: 08-01-2006, 20:39
  4. Failed to upgrade firmware on WL-500g Deluxe
    By olas in forum WL-500g Q&A
    Last Post: 27-12-2005, 12:17
