Yes, I found the reason. It's multicast routing. Disable it, if you don't need it!
BR
Robert
BR
Robert
ISP: TV Cable 50/5 Mbit
@admins
Will the firmware be added to the wizzard?
wengi
Huh i still have problems with ppp0 interface on *g* version [wan is not flashing]. Tho its working like its should on f one. So i don't have a clue whats going on :/
When i:
[admin@asus root] flashfs save
tar: Removing leading '/' from member names
tmp/local/
tmp/local/local/root/
-rw-r--r-- 1 root root 116 Jun 28 03:56 /tmp/flash.tar.gz
Check saved image and type "/sbin/flashfs commit" to commit changes
[admin@asus root]$ cat /.version
1.9.2.7-7g
who can help me solve this problem ,tks!
Thats normal. Whats your problem?Code:[admin@blechbuechse root]$ flashfs save tar: Removing leading '/' from member names tmp/local/ tmp/local/sbin/ tmp/local/sbin/post-boot tmp/local/sbin/post-firewall tmp/local/sbin/post-mount tmp/local/sbin/pre-shutdown tmp/local/etc/ tmp/local/etc/dropbear/ tmp/local/etc/dropbear/dropbear_dss_host_key tmp/local/etc/dropbear/dropbear_rsa_host_key tmp/local/etc/profile tmp/local/samba/ tmp/local/samba/private/ tmp/local/root/ tmp/local/root/.mc/ tmp/local/root/.mc/Tree tmp/local/root/.mc/history tmp/local/root/.mc/ini tmp/local/root/.lesshst tmp/local/root/.toprc tmp/local/root/.elinks/ tmp/local/root/.elinks/bookmarks tmp/local/root/.elinks/globhist tmp/local/root/.ssh/ tmp/local/root/.ssh/authorized_keys tmp/local/root/logger -rw-r--r-- 1 admin root 5059 Jun 28 08:37 /tmp/flash.tar.gz Check saved image and type "/sbin/flashfs commit" to commit changes [admin@blechbuechse root]$
wengi
PS: There is no reason to panic and write a pm.... keep cool
[QUOTE=wengi;57946]Thats normal. Whats your problem?Code:[admin@blechbuechse root]$ flashfs save tar: Removing leading '/' from member names tmp/local/ tmp/local/sbin/ tmp/local/sbin/post-boot tmp/local/sbin/post-firewall tmp/local/sbin/post-mount tmp/local/sbin/pre-shutdown tmp/local/etc/ tmp/local/etc/dropbear/ tmp/local/etc/dropbear/dropbear_dss_host_key tmp/local/etc/dropbear/dropbear_rsa_host_key tmp/local/etc/profile tmp/local/samba/ tmp/local/samba/private/ tmp/local/root/ tmp/local/root/.mc/ tmp/local/root/.mc/Tree tmp/local/root/.mc/history tmp/local/root/.mc/ini tmp/local/root/.lesshst tmp/local/root/.toprc tmp/local/root/.elinks/ tmp/local/root/.elinks/bookmarks tmp/local/root/.elinks/globhist tmp/local/root/.ssh/ tmp/local/root/.ssh/authorized_keys tmp/local/root/logger -rw-r--r-- 1 admin root 5059 Jun 28 08:37 /tmp/flash.tar.gz Check saved image and type "/sbin/flashfs commit" to commit changes [admin@blechbuechse root]$
wengi
is it normal?! it look like that it don't save successfully?i think it have some trouble.
tmp/local/ seems to be empty. Take a look if this is right.
tmp/local/local/root/ should not exist. maybe you have copied some things the wrong way... There should be a tmp/local/root....
You have a problem with the files themselves, but not with "flashfs save"
Is this a clean install of oleg firmware???
wengi
when i:
use the command as following:
ipkg install apache
there some problems appear as follow:
collected errors:
package apache md5sum mismatch,either the ipkg or the package index are corrupt.try 'ipkg update'
what is it's problem?can you tell me how to do it?
What about telling us what you installed until now.....
which uClib do you use?
which ipkg do you use?
which repository do you use?
post the results of "ipkd update" and "ipkg list_installed".
Sorry, my glass sphere seems to be broken..
wengi
$ipkg update
download http://ipkg.nslu2-linux.org/feeds/op...table/packages
$ipkg list_installed
apr
apr-util
bzip2
cyrus-sasl-libs
e2fsprogs
eaccelerator
expat
gdbm
ipkg-opt
libdb
libxm12
libxslt
lynx
ncftp
ncurses
openldap-libs
openssl
pcre
php-appache
readline
sqlite
termcap
uclibc-opt
zlib
ok, your ipkg feed is the right one.
normaly there are version numbers of the packages.
i guess you are not copying, but typing all that stuff.
You know you can copy all this using e.g. putty and copy/paste?
But thats not the point...
You have installed many things so you shoul have files in your /tmp/local folder.
It is very strange you dont! Did you delete any files or copy anything in /usr/local/.....?
wengi
