Thanks Oleg for the new firmware, but i wanna ask you if its possible to do loadbalancing with the wl500g with two internetproviders?
Thanks,
Still my router out of nowhere when it's downloading 8 torrents or so. Resized my swapsize to 256 mb becouse the 60 mb's was too small..
The only other things that are running are the httpd server, stupid-ftpd and dropbear. Does anyone has a clue what it can be? Should I just stop downloading so many torrents?
[update]
Reinstalled everything. Still wondering what it is as the only thing that could bring it down is enhanced-ctorrent. Mine is a premium btw.
How can I turn the automounting off? I want my ipkg to use the /opt/tmp/ipkg folder, the rest is not writeable..
USB storage: ext3 fs mounted to /tmp/harddisk
i have been looking around and carnt seem to find any firmwares for the WL-500g that have bandwith management that is IP based for uploading just like it is for downloading
is there any way that you could put this in?
i know port based is good BUT here in OZ all the main ISP's suck and only give us small U/L bandwith (i am on cable 10Mb down 128Kb up) and when the others in the house start any form of P2P the net stops i tryed to use the port shapeing but they just change the ports there useing and restart i dont mind them downloading but when it kills the connection because there is no U/L it sucks big time
i have allready set it up so there IP's are set from there MAC address so the IP shapeing would be grate
i know you do all of this work for free Oleg and it fantastic (been useing your firmware since you started doing it for wl500g) i amd i am sure that most of us here thank you grately
Adverse Effects
Hi Oleg,
thx for your great work - the firmware is running very well since 15 days - without reboot or reconfig ...
But i think, there is one little prob in dhcp:
I'm using my clients with time to lease by 10800 - so the client should check dhcp every 3 h (= 3*60*60 =3*3600).
But the client check it every 1h30min (=5400 =10800/2 = 1.5*3600)
... or I'm wrong ???
cu
exdlinker
old: DI-624
new: WL500gP
after upgradeing to firmware -7f im having trouble to instal the network printer. trying to add printer in printer wizard and i got error: The printer name is invalid.
printer worked fine in previous firmware. any comment?
&f is working very stable, no problems, even ntp is working bij me.
I see in the ChangeLog that the "URL Filter" (page) is removed.
Is there still a way in version 7f to block URL's, or is this not possible anymore?
I want to use this firmware, have some issues with my present one, but need to block out certain URL's.
Regards,
Molski
It doesn't work in this firmware. Therefore it has been removed.
