Hello,
I have a wl-hdd and put this firmware on it. Now i am not able to make shares on de hdd anymore with te webinterface.... someone can tell me how to do this ?
Carlo
Hallo,
Im trying to configure my PDA (HP55xx) after router frmware update from previous OLEG version to current.
(on previous everything works fine)
PDA is working with .11b WPA-PSK/TKIP, but is unable to connect to router. I see in "Status & Log - Wireless" only MAC adress, no "associated" and no "authorized" msg.
Router is set to auto mode, .11g protection as was on previous firmware version. But when I change to "802.11B only" my PDA is successfully connected.
I tryed resets to factory defaults and set completely from "zero point" but still same - no G and B in one moment.
Could someone help me please?
Edit: Asus WL-500g Deluxe, working as home gateway
Hello,
Carlo
It seems to me, as if with the latest firmware version (7e) a post-boot file, which has been copied to the flash, will not be executed properly. When I put the 7c-version on my WL-HDD again, the difficulties were gone.
Would be fine, if Oleg fixed that.
Hello,
I don't know for previous versions, but with 7e with post-boot and post-firewall scripts to open to WAN I can't access ftp until I enable Super user account and then once login with super user. After that I can login with users on user account list from WAN.
And another issue with external USB disk (FAT32). Once per day I have disk disconnection
System log:
Jul 24 22:39:08 kernel: hub.c: already running port 1 disabled by hub (EMI?), re-enabling...
Jul 24 22:39:08 kernel: usb.c: USB disconnect on device 00:04.0-1 address 2
Jul 24 22:39:09 kernel: hub.c: new USB device 00:04.0-1, assigned address 3
Jul 24 22:39:11 USB storage: removed
Regards
Hello I've got a problem with the new 7e release. One of the computers I have stops transferring data packs from or to the router if I'm playing a game (.exe file). Its only with games because when I'm browsing or whatever it doesn't stop transferring data packs. He even looses its IP when I try to /ipconfig lease /ipconfig renew (after I played a game). There is only one way to get the IP back, and that is a reboot. And it is only with one computer (both integrated NIC cards), the other ones just work fine. And I didn't got this problem with the previous releases. And in the log files there is says that there is no request.
The NIC is a Marvell Yukon 88E8053 PCI-E Gigabit Ethernet Controller.
Probably same problem here! Marvell Yukon integrated Gigabit Ethernet card stops sending packets. Renew of IP adress didn't help. Complete reboot of PC helped. I tried to set my Marvell Yukon to 100mbit full duplex (instead of Auto Sense) and it seems to be okay now.
EDIT2: Speed setting didn't helped at all, but I realized, that I can only DISABLE and then REENABLE my Marvel Yukon and it's working again... (for a while)
Is it possible to add a new feature to the next firmware release.
I'm looking for a feature that keeps my adsl2+ line alive. It can be something that pings a server every 15 seconds or something like that.
I test that firmware but the motion detection is still not working with my logitech quickcam 4000.
Is there any explanation about this problem ??
Thanks
same problem here Oleg... :-/ (my driver is 7.21.1.3 digitally signed by Microsoft Windows Hardware Compatibility Publisher)
Thanks the work for Oleg!!!!
This firmware work perfectly for me, but i have got one problem. Webcam drivers update: ov51x-1.65-1.12, pwc 9.0.2 (incl. compression and 640x480). But my newer Logitech sphere (ptz) can't work with this firmware (i buy this cam 130$).
Log: USB device 2 (vend/prod 0x46d/0x8c5) is not claimed by any active driver.
I read: Warning: This driver does not support these newer Logitech webcam:
Product Id Model
0x8C2 Logitech QuickCam PTZ (newer version of the sphere)
But i lokking for a newer driver and i find this: http://developer.berlios.de/projects/linux-uvc and i read the Linux UVC driver and tools know supported devices:
Device ID Name Manufacturer
046d:08c1 Logitech Quickcam Fusion Logitech
046d:08c2 Logitech Quickcam Orbit Logitech and etc....
I can't build-in the new driver in the firmware. And in really good for me this driver? I hope.
Oleg do you know this problem? And have you got any solution?
If you have, eternal thankfulness!!!!
