Page 5 of 6 FirstFirst ... 3456 LastLast
Results 61 to 75 of 81
Thread: HP LaserJet 1000/1005/1020 not working: sort of solution
  1. #61
    Sorry, forgot about logs:
    Sep 17 22:44:09 kernel: printer.c: usblp0: removed
    Sep 17 22:44:12 kernel: hub.c: new USB device 00:03.1-1.2, assigned address 6
    Sep 17 22:44:12 kernel: printer.c: usblp0: USB Bidirectional printer dev 6 if 0 alt 0 proto 2 vid 0x03F0 pid 0x3D17
    Sep 17 22:44:12 kernel: printer.c: usblp0 Device ID string [86]='MFG:Hewlett-Packard;MDL:HP LaserJet P1005;CMD:ACL;CLS:PRINTER;DES:HP LaserJet P1005;'
    Sep 17 22:45:51 udhcpc[129]: Lease of 109.86.153.206 obtained, lease time 3600
  2. #62
    Windows 7 solve problem :-)
    Now i dont must load drivers on router.
  3. #63
    Please help with p1005
    Quote Originally Posted by ENDer2000 View Post
    It's working now and if you telnet the router, ou can copy & paste the commands from here:
    http://www.bogdangheorghe.ro/2008/12...0100510181020/
    Hi guys!
    Please help. If I follow this tutorial and run
    [admin@WL-001E8CE634DF sbin]$ echo ./usr/local/sbin/usb_printerid /dev/usb/lp0 | grep -q FWVER || cat /usr/local/sbin/sihp1005.dl > /dev/usb/lp0. >> hotplug.sh
    -sh: cannot create /dev/usb/lp0.: Permission denied
    What could this be?????
    Thanks
  4. #64
    Feb 2007
    the dot is superflous
    /dev/usb/lp0.
  5. #65
    Thank youuuuuu! A simple solution for my "big" problem...
    It works now, but in windows 7 ( I haven't tried in xp/vista) the printer looses bidirectional support. Therefore I have to activate it before every print. Does it happen to somebody else? Is there a simple solution, as well?
    Thanks.
    P.S. Thanks Oleg for the great firmware!
  6. #66
    Can these scripts be loaded to WL-520gu? Can't find WL-500gP anywhere and I have HP P1006...
    Thanks
  7. #67
    Feb 2007
    yes, but you will need external storage for the firmware. There isn't enough space inside.
  8. #68
    Hmm, well I have successfully uploaded files to router (WL-520ug) (flashed with oleg's of course) but now I have another problem...
    It seems that hotplug still doesnot work, every time I turn-off and turn-on the printer, I have to type cat "/usr/local/sbin/sihpP1006.dl" > /dev/usb/lp0
    I cannot access /proc/sys/kernel/hotplug to add the nesecary line... I've added pre-boot, post-boot and done the chmod +x and all the flashfs and reboot command...
    Please help...
  9. #69
    I want to connect my HP LJ 1020 on my Asus WL-500g Premium. I use the following walktrough: http://www.bogdangheorghe.ro/2008/12...0100510181020/
    But I get an error:
    Here is my telnet session:
    WL-001731B42998 login: admin
    Password:
    [admin@WL-001731B42998 root]$ mkdir /usr/local/sbin
    [admin@WL-001731B42998 root]$ cd /usr/local/sbin
    [admin@WL-001731B42998 sbin]$ wget http://oleg.wl500g.info/hplj/usb_printerid
    Connecting to oleg.wl500g.info[158.250.11.254]:80
    usb_printerid        100% |*****************************|  5800       00:00 ETA
    [admin@WL-001731B42998 sbin]$ wget http://oleg.wl500g.info/hplj/sihp1020.dl
    Connecting to oleg.wl500g.info[212.192.248.17]:80
    sihp1020.dl          100% |*****************************|   123 KB    00:00 ETA
    [admin@WL-001731B42998 sbin]$ chmod +x usb_printerid
    [admin@WL-001731B42998 sbin]$ ./usb_printerid /dev/usb/lp0 | grep -q FWVER || ca
    t sihp1020.dl > /dev/usb/lp0
    Error: No such file or directory: can't open '/dev/usb/lp0'
    -sh: cannot create /dev/usb/lp0: Permission denied
    I did command ./usb_printerid /dev/usb/lp0 | grep -q FWVER || ca
    t sihp1020.dl > /dev/usb/lp0 twice but I get two errors.
    I have tried to find to solution for this problem.
    [admin@WL-001731B42998 sbin]$ ls -la /dev/usb
    drwxr-xr-x 1 admin root 0 Jan 1 1970 .
    drwxr-xr-x 1 admin root 0 Jan 1 1970 ..
    I have no lp0. And that's why , I think, I get the error: -sh: cannot create /dev/usb/lp0: Permission denied
    wilfred@wilfred-laptop:~$ telnet
    telnet> open 192.168.1.1
    Trying 192.168.1.1...
    Connected to 192.168.1.1.
    Escape character is '^]'.
    Password:
    [admin@WL-001731B42998 root]$ la /dev/usb
    -sh: la: not found
    [admin@WL-001731B42998 root]$ ls -la /dev/usb
    -sh: cd: can't cd to /usr/local/sbin
    [admin@WL-001731B42998 sbin]$ ./usb_printerid /dev/usb/lp0 | grep -q FWVER || cat sihp1020.dl > /dev/usb/lp0
    drwxr-xr-x    1 admin    root          118 Mar 14  2008 ..
    crw-------    1 admin    root       8,   0 Jan  1  1970 .devfsd
    crw-------    1 admin    root       5,   1 Jan  1  1970 console
    drwxr-xr-x    1 admin    root            0 Jan  1  1970 cua
    crw-rw-rw-    1 admin    root       1,   7 Jan  1  1970 full
    drwxr-xr-x    1 admin    root            0 Jan  1  1970 gpio
    crw-r-----    1 admin    root       1,   2 Jan  1  1970 kmem
    srw-rw-rw-    1 admin    root            0 Jan  1  1970 log
    drwxr-xr-x    1 admin    root            0 Jan  1  1970 loop
    crw-r-----    1 admin    root       1,   1 Jan  1  1970 mem
    drwxr-xr-x    1 admin    root            0 Jan  1  1970 mtd
    drwxr-xr-x    1 admin    root            0 Jan  1  1970 mtdblock
    crw-rw-rw-    1 admin    root       1,   3 Jan  1  1970 null
    crw-r-----    1 admin    root     253,   0 Jan  1  1970 nvram
    crw-r-----    1 admin    root       1,   4 Jan  1  1970 port
    crw-------    1 admin    root     108,   0 Jan  1  1970 ppp
    crw-rw-rw-    1 admin    root       5,   2 Nov 17 16:10 ptmx
    drwxr-xr-x    1 admin    root            0 Jan  1  1970 pts
    drwxr-xr-x    1 admin    root            0 Jan  1  1970 pty
    crw-r--r--    1 admin    root       1,   8 Jan  1  1970 random
    lr-xr-xr-x    1 admin    root           10 Jan  1  2000 root -> mtdblock/2
    drwxr-xr-x    1 admin    root            0 Jan  1  1970 scsi
    drwxr-xr-x    1 admin    root            0 Jan  1  1970 sound
    drwxr-xr-x    1 admin    root            0 Jan  1  1970 tts
    crw-rw-rw-    1 admin    root       5,   0 Jan  1  1970 tty
    crw-r--r--    1 admin    root       1,   9 Jan  1  1970 urandom
    drwxr-xr-x    1 admin    root            0 Jan  1  1970 usb
    lr-xr-xr-x    1 admin    root           15 Jan  1  1970 video -> /dev/v4l/video0
    crw-rw-rw-    1 admin    root       1,   5 Jan  1  1970 zero
    Form the log of the router
     ov 17 16:06:09 login[409]: root login  on `pts/0'
    Nov 17 16:06:50 kernel: hub.c: new USB device 01:03.2-1, assigned address 2
    Nov 17 16:06:50 kernel: usb.c: invalid descriptor length of 1
    Nov 17 16:06:50 kernel: usb.c: unable to get device 2 configuration (error=-22)
    Nov 17 16:06:50 kernel: hub.c: new USB device 01:03.2-1, assigned address 3
    Nov 17 16:06:50 kernel: usb.c: not enough configurations
    Nov 17 16:06:50 kernel: usb.c: unable to get device 3 configuration (error=-22)
    Can somebody help me with this problem?
  10. #70
    Feb 2007
    your problem is that printer isn't recognized by router. I guess you have wl500gPv2. Try the firmware from http://code.google.com/p/wl500g/ It is known to be more compatible with usb devices.
  11. #71
    I have ASUS WL-500g Premium (firmware: Oleg firmware WL500gp-1.9.2.7-9 )
    I will test the new firmware tonight. I'll keep you updated
  12. #72
    I have flashed my router to firmware: WL500gp-1.9.2.7-d-r740
    systemlog of the router:
    Jan  1 00:01:23 kernel: hub.c: new USB device 01:03.2-2, assigned address 2
    Jan  1 00:01:23 kernel: usb.c: invalid descriptor length of 1
    Jan  1 00:01:23 kernel: usb.c: unable to get device 2 configuration (error=-22)
    Jan  1 00:01:24 kernel: hub.c: new USB device 01:03.2-2, assigned address 3
    Jan  1 00:01:24 kernel: usb.c: not enough configurations
    Jan  1 00:01:24 kernel: usb.c: unable to get device 3 configuration (error=-22)
    I have taken the same steps of the walktrough and I get the same error.
    I have typed ps commando and get the following:
    [admin@WL-001731B42998 root]$ ps commando
    ps: invalid option -- c
    BusyBox v1.15.2 (2009-10-30 20:19:08 MSK) multi-call binary
    Usage: ps
    Report process status
    Options:
            w       Wide output
    [admin@WL-001731B42998 root]$ w
    -sh: w: not found
    [admin@WL-001731B42998 root]$ pc
    -sh: pc: not found
      PID USER       VSZ STAT COMMAND
        1 admin     1312 S    /sbin/init
        2 admin        0 SW   [keventd]
        3 admin        0 SWN  [ksoftirqd_CPU0]
        4 admin        0 SW   [kswapd]
        5 admin        0 SW   [bdflush]
        6 admin        0 SW   [kupdated]
        7 admin        0 SW   [mtdblockd]
       52 admin     1516 S    telnetd
       57 admin     1120 S    httpd vlan1
       59 admin     1516 S    syslogd -m 0 -O /tmp/syslog.log -S -l 7 -b 2
       60 admin     1516 S    klogd
       67 nobody     832 S    dnsmasq
       68 admin        0 SW   [khubd]
       76 admin      756 S    lpd
       78 admin      648 S    p9100d -f /dev/usb/lp0 0
       81 admin     1308 S    waveservermain
       83 admin     1308 S    rcamdmain
       93 admin      888 S    infosvr br0
       94 admin     1312 S    watchdog
      111 admin     1036 S    upnp -D -L br0 -W vlan1
      112 admin     1524 S    udhcpc -i vlan1 -p /var/run/udhcpc0.pid -s /tmp/udhcp
      145 admin     1520 S    -sh
      151 admin     1516 R    ps
    What does this mean to me? 78 admin 648 S p9100d -f /dev/usb/lp0 0
  13. #73
    Feb 2007
    ps output is ok, while syslog looks not very promising.
    Well, first check once again that the printer itself and usb cable are in order by connecting the printer directly to PC. If it works, I really don't know what else you can do.
    The printer is reported to work with Premium v.1, so I believe you should have some hardware problem.
    You connect printer directly (not through usb hub)?
    What if it is connected to another usb port?
    Are another usb devices recognized?
  14. #74
    I can use the printer directly connected to my pc perfectly. I get no errors in Windows XP home and Linux Ubuntu 9.10. The printer works very well.
    The printer is not connected with an usb hub.
    I have tested 3 diverend USB cables: and with every cable I used the two usb ports of the router for the turn.
    USB cable 1:
    Nov 18 18:36:00 kernel: hub.c: new USB device 01:03.2-2, assigned address 32
    Nov 18 18:36:00 kernel: usb.c: not enough configurations
    Nov 18 18:36:00 kernel: usb.c: unable to get device 32 configuration (error=-22)
    Nov 18 18:36:00 kernel: hub.c: new USB device 01:03.2-2, assigned address 33
    Nov 18 18:36:00 kernel: usb.c: unable to get device 33 configuration (error=-22)
    Nov 18 18:44:08 kernel: hub.c: new USB device 01:03.2-1, assigned address 34
    Nov 18 18:44:08 kernel: usb.c: not enough configurations
    Nov 18 18:44:08 kernel: usb.c: unable to get device 34 configuration (error=-22)
    Nov 18 18:44:09 kernel: hub.c: new USB device 01:03.2-1, assigned address 35
    Nov 18 18:44:09 kernel: usb.c: invalid descriptor length of 0
    Nov 18 18:44:09 kernel: usb.c: unable to get device 35 configuration (error=-22)
    USB cable 2:
    Nov 18 18:46:49 kernel: hub.c: new USB device 01:03.2-2, assigned address 38
    Nov 18 18:46:49 kernel: usb.c: invalid descriptor length of 0
    Nov 18 18:46:49 kernel: usb.c: unable to get device 38 configuration (error=-22)
    Nov 18 18:46:49 kernel: hub.c: new USB device 01:03.2-2, assigned address 39
    Nov 18 18:46:49 kernel: usb.c: unable to get device 39 configuration (error=-22)
    Nov 18 18:46:57 kernel: hub.c: new USB device 01:03.2-1, assigned address 40
    Nov 18 18:46:57 kernel: usb.c: not enough configurations
    Nov 18 18:46:57 kernel: usb.c: unable to get device 40 configuration (error=-22)
    Nov 18 18:46:58 kernel: hub.c: new USB device 01:03.2-1, assigned address 41
    Nov 18 18:46:58 kernel: usb.c: invalid descriptor length of 0
    Nov 18 18:46:58 kernel: usb.c: unable to get device 41 configuration (error=-22)
    USB cable 3:
    Nov 18 18:48:04 kernel: hub.c: new USB device 01:03.2-2, assigned address 44
    Nov 18 18:48:04 kernel: usb.c: not enough configurations
    Nov 18 18:48:04 kernel: usb.c: unable to get device 44 configuration (error=-22)
    Nov 18 18:48:05 kernel: hub.c: new USB device 01:03.2-2, assigned address 45
    Nov 18 18:48:05 kernel: hcd.c: bogus endpoint (bad maxpacket)
    Nov 18 18:48:05 kernel: usb.c: unable to get device descriptor (error=-22)
    Nov 18 18:48:34 kernel: hub.c: new USB device 01:03.2-1, assigned address 46
    Nov 18 18:48:34 kernel: usb.c: not enough configurations
    Nov 18 18:48:34 kernel: usb.c: unable to get device 46 configuration (error=-22)
    Nov 18 18:48:35 kernel: hub.c: new USB device 01:03.2-1, assigned address 47
    Nov 18 18:48:35 kernel: usb.c: not enough configurations
    Nov 18 18:48:35 kernel: usb.c: unable to get device 47 configuration (error=-22)
    Nov 18 18:49:18 kernel: hub.c: new USB device 01:03.2-2, assigned address 48
    Nov 18 18:49:18 kernel: usb.c: too many interfaces
    Nov 18 18:49:18 kernel: usb.c: unable to get device 48 configuration (error=-22)
    Nov 18 18:49:18 kernel: hub.c: new USB device 01:03.2-2, assigned address 49
    Nov 18 18:49:18 kernel: usb.c: not enough configurations
    Nov 18 18:49:18 kernel: usb.c: unable to get device 49 configuration (error=-22)
    I have restarted my HP printer and my Asus router:
    Jan  1 00:00:03 syslogd started: BusyBox v1.15.2
    Jan  1 00:00:03 kernel: klogd started: BusyBox v1.15.2 (2009-10-30 20:19:08 MSK)
    Jan  1 00:00:03 kernel: CPU revision is: 00029006
    Jan  1 00:00:03 kernel: Primary instruction cache 16kB, physically tagged, 2-way, linesize 16 bytes.
    Jan  1 00:00:03 kernel: Primary data cache 16kB, 2-way, linesize 16 bytes.
    Jan  1 00:00:03 kernel: Linux version 2.4.37.6 (root@localhost) (gcc version 3.4.6) #9 2009-10-30 20:22:17 MSK
    Jan  1 00:00:03 kernel: Setting the PFC to its default value
    Jan  1 00:00:03 kernel: Determined physical RAM map:
    Jan  1 00:00:03 kernel:  memory: 02000000 @ 00000000 (usable)
    Jan  1 00:00:03 kernel: On node 0 totalpages: 8192
    Jan  1 00:00:03 kernel: zone(0): 8192 pages.
    Jan  1 00:00:03 kernel: zone(1): 0 pages.
    Jan  1 00:00:03 kernel: device eth0 entered promiscuous mode
    Jan  1 00:00:03 kernel: device vlan0 entered promiscuous mode
    Jan  1 00:00:03 kernel: device eth1 entered promiscuous mode
    Jan  1 00:00:03 kernel: eth1: attempt to add interface with same source address.
    Jan  1 00:00:03 kernel: br0: port 2(eth1) entering learning state
    Jan  1 00:00:03 kernel: br0: port 1(vlan0) entering learning state
    Jan  1 00:00:03 kernel: br0: port 2(eth1) entering forwarding state
    Jan  1 00:00:03 kernel: br0: topology change detected, propagating
    Jan  1 00:00:03 kernel: br0: port 1(vlan0) entering forwarding state
    Jan  1 00:00:03 dnsmasq[67]: started, version 2.51 cachesize 512
    Jan  1 00:00:03 dnsmasq[67]: compile time options: no-IPv6 GNU-getopt no-RTC no-DBus no-I18N DHCP no-scripts no-TFTP
    Jan  1 00:00:03 dnsmasq-dhcp[67]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 1d
    Jan  1 00:00:03 dnsmasq[67]: read /etc/hosts - 2 addresses
    Jan  1 00:00:03 kernel: usb.c: registered new driver usbdevfs
    Jan  1 00:00:03 kernel: usb.c: registered new driver hub
    Jan  1 00:00:03 kernel: usb-uhci.c: $Revision: 1.275 $ time 20:19:57 Oct 27 2009
    Jan  1 00:00:03 kernel: usb-uhci.c: High bandwidth mode enabled
    Jan  1 00:00:03 kernel: PCI: Enabling device 01:03.0 (0000 -> 0001)
    Jan  1 00:00:03 kernel: UHCI: Enabling VIA 6212 workarounds
    Jan  1 00:00:03 kernel: usb-uhci.c: USB UHCI at I/O 0x100, IRQ 12
    Jan  1 00:00:03 kernel: usb-uhci.c: Detected 2 ports
    Jan  1 00:00:03 kernel: usb.c: new USB bus registered, assigned bus number 1
    Jan  1 00:00:03 kernel: hub.c: USB hub found
    Jan  1 00:00:03 kernel: hub.c: 2 ports detected
    Jan  1 00:00:03 kernel: PCI: Enabling device 01:03.1 (0000 -> 0001)
    Jan  1 00:00:03 kernel: usb-uhci.c: USB UHCI at I/O 0x120, IRQ 12
    Jan  1 00:00:03 kernel: usb.c: new USB bus registered, assigned bus number 2
    Jan  1 00:00:03 kernel: usb-uhci.c: v1.275:USB Universal Host Controller Interface driver
    Jan  1 00:00:04 kernel: PCI: Enabling device 01:03.2 (0000 -> 0002)
    Jan  1 00:00:04 kernel: ehci_hcd 01:03.2: PCI device 1106:3104
    Jan  1 00:00:04 kernel: ehci_hcd 01:03.2: irq 12, pci mem c019d000
    Jan  1 00:00:04 kernel: usb.c: new USB bus registered, assigned bus number 3
    Jan  1 00:00:04 kernel: EHCI: Enabling VIA 6212 workarounds
    Jan  1 00:00:04 kernel: ehci_hcd 01:03.2: USB 2.0 enabled, EHCI 1.00, driver 10 Dec 2004/2.4
    Jan  1 00:00:04 kernel: hub.c: USB hub found
    Jan  1 00:00:04 kernel: hub.c: 4 ports detected
    Jan  1 00:00:04 kernel: usb.c: registered new driver usblp
    Jan  1 00:00:04 kernel: printer.c: v0.13: USB Printer Device Class driver
    Jan  1 00:00:04 dnsmasq-dhcp[67]: DHCPREQUEST(br0) 192.168.1.205 00:03:0d:38:a0:5f
    Jan  1 00:00:04 dnsmasq-dhcp[67]: DHCPACK(br0) 192.168.1.205 00:03:0d:38:a0:5f wilfred-laptop
    Jan  1 00:00:05 kernel: usb.c: registered new driver audio
    Jan  1 00:00:05 kernel: audio.c: v1.0.1:USB Audio Class driver
    Jan  1 00:00:05 kernel: Linux video capture interface: v1.00
    Jan  1 00:00:05 kernel: SCSI subsystem driver Revision: 1.00
    Jan  1 00:00:05 kernel: Initializing USB Mass Storage driver...
    Jan  1 00:00:05 kernel: usb.c: registered new driver usb-storage
    Jan  1 00:00:05 kernel: USB Mass Storage support registered.
    Jan  1 00:00:05 kernel: vlan1: Setting MAC address to  00 17 31 b4 29 98.
    Jan  1 00:00:05 kernel: VLAN (vlan1):  Underlying device (eth0) has same MAC, not checking promiscious mode.
    Jan  1 00:00:06 dhcp client: deconfig: lease is lost
    Jan  1 00:00:06 dhcp client: bound IP : XXX.XXX.XXX.XXX from XXX.XXX.XXX.XXX
    Jan  1 00:00:09 dnsmasq-dhcp[67]: DHCPDISCOVER(br0) 00:06:dc:44:1c:7a
    Jan  1 00:00:09 dnsmasq-dhcp[67]: DHCPOFFER(br0) 192.168.1.208 00:06:dc:44:1c:7a
    Jan  1 00:00:09 dnsmasq[67]: read /etc/hosts - 2 addresses
    Jan  1 00:00:09 dnsmasq[67]: using nameserver 145.97.192.174#53
    Jan  1 00:00:09 dnsmasq-dhcp[67]: DHCPREQUEST(br0) 192.168.1.208 00:06:dc:44:1c:7a
    Jan  1 00:00:09 dnsmasq-dhcp[67]: DHCPACK(br0) 192.168.1.208 00:06:dc:44:1c:7a
    Jan  1 00:00:49 kernel: hub.c: new USB device 01:03.2-2, assigned address 2
    Jan  1 00:00:49 kernel: usb.c: invalid descriptor length of 0
    Jan  1 00:00:49 kernel: usb.c: unable to get device 2 configuration (error=-22)
    Jan  1 00:00:49 kernel: hub.c: new USB device 01:03.2-2, assigned address 3
    Jan  1 00:00:49 kernel: usb.c: too many interfaces
    Jan  1 00:00:49 kernel: usb.c: unable to get device 3 configuration (error=-22)
  15. #75
    When I connect an USB drive I get this:
    Nov 18 19:41:10 kernel: hub.c: new USB device 01:03.2-1, assigned address 12
    Nov 18 19:41:10 kernel: hcd.c: bogus endpoint (bad maxpacket)
    Nov 18 19:41:10 kernel: usb.c: unable to get device descriptor (error=-22)
    Nov 18 19:41:11 kernel: hub.c: new USB device 01:03.2-1, assigned address 13
    Nov 18 19:41:11 kernel: usb.c: invalid descriptor length of 1
    Nov 18 19:41:11 kernel: usb.c: unable to get device 13 configuration (error=-22)
  1. Replies: 3
    Last Post: 18-12-2005, 01:07
  2. Solution for: No printer driver with Mac OSX
    By tortuga in forum WL-500g/WL-500gx Tutorials
    Last Post: 16-12-2005, 13:21
  3. Replies: 1
    Last Post: 09-12-2005, 22:29
  4. Problem mit HP LaserJet 1020
    By Gray in forum German Discussion - Deutsch (DE)
    Last Post: 05-12-2005, 17:36
  5. Trying to get IDE working on Oleg's Firmware
    By hugo in forum WL-HDD Q&A
    Last Post: 01-11-2004, 18:06
