Results 1 to 5 of 5
Thread: asus firmware 1.2.3.9
    hi there,
    it looks like the asus-guys produced a new fw version 1.2.3.9
    1. update stupid-ftpd
    2. remove Ad Hoc mode support
    3. DHCP client pool sync with LAN IP settings
    4. WPA-PSK/Firmware upgrade are ok
    5. Shutdown page is ok
    Jan 2005
    konstanz, germany
    Angry ... not able to "disable radio"
    Hi ...
    anybody any experiences with new firmware?
    I try to upgrade and savely restore factory settings ... but now I'm not able to "disable radio" ... setting is saved but has no effect :-(
    Thanks
    Martin
    Jan 2005
    konstanz, germany
    Question searching for asus gpl source 1.2.3.9
    Hi ...
    Does anybody know when the sourcecode of asus firmware will be released? Maybe a patch of source code (diff file) ... from last official GPL source code release?
    I want to recompile for changing the default settings pemanent.
    Thanks
    Martin
    Asus 1.2.3.9 with ipkg support
    Its a wish. Or may be someone has already created a Custom firware. If a Linux expert in the forum has done this, could you pls share ...
    Actually I am looking for functionalities of 1.2.3.9 (Specifically the "become AP when AP not available" feature in the stock firmware) with Ipkg system capabilities to run media server or capabilities to enable audio/video streaming on the wl-hdd. Any pointers in this direction much appreciated
    Thanks
    Jan 2005
    konstanz, germany
    Hi ...
    I also like to have a custom firmware ... I need to modify the factory (default) setting for my custom firmware, but there is no source code available :-(
    Only older version of source and no diff to upgrade source code to 1.2.3.9 ...
    Asking ASUS support for GPL source code ... no reply :-(
    Good luck
    Martin
  1. 1.9.5.0 Firmware on asus site
    By sandoval in forum WL-500gx Firmware Releases
    Last Post: 12-04-2006, 14:27
  2. Firmware 1.9.4.6 Asus
    By piwi in forum WL-500gx Firmware Releases
    Last Post: 31-08-2005, 21:05
  3. Firmware received from asus ?
    Last Post: 01-07-2004, 00:12
  4. New firmware at Asus site
    By RCR in forum WL-500g Custom Development
    Last Post: 24-03-2004, 07:19
