Asus has posted a new version of "Asus utility". There is no history file in the package, thus i do not know what is new, but it is worth a try.
you should recover it then: press the restore button, then connect power to the device. after doing that the Power led begins to flash, start the recovery procedure from your pc and everything should be fine after finishingOriginally Posted by MrBean
My last thread seemed to disappear, maybe it was because of a misunderstanding and som whine from my side.
Back to what was in it.
Changed some settings in my wl500g from the web interface and it died. The lights are lit and so on but I can't connect to it anymore.
I started with just trying to reset settings to default with the button on the back. Without any success. From what I understood from the manual I was going to hold it in for 5 seconds until pwr started flashing. Then it was restored. Well it didn't help me.
So I tried to restore it with firmware restoration, but I can't, until I hold the reset button so pwr starts flashing. I restored with several firmwares, but still can't reach it.
Interesting is that when I use a static ip for pinging it, I sent 130 pings to it and 4 of them got reply! So strange, why just 4 of them? When I hold the reset button until pwr starts flashing I can ping it without any problems, but no webinterface and so on.
What am I doing wrong, and why did it die, I just changed some settings in the webinterface?
I can't tell which settings it were though, cause it was a friend of mine who played around with it.![]()
ehm no.. troubles with the thread table at the database.. vbulletin3 does not seem to be stable enoughi'll fix soon a cron that will check everyday and fixes the database, so those errors would not appear anymore (hopefully)
sorry for the troubles..
anyway.. try downgrading to a lower firmware.. try 1.6.5.3 for example that one did the trick for me a while ago
older firmwares can be found at http://files.wl500g.info/asus/wl500g/firmware
Already tried that one :/
What can have happened, and how should I fix it? It's very strange.
Went and bought an used ap+802.11a pci card for 30€ supporting a/b/g so I got some wlan at least.
have you tried version 1.1.3.3 too?
maybe we should have a firmware which only restores nvram at time of booting back to safe values.
maybe someone has time to fix this
Yes, seems nvram settings are bad. I will try prepare minimal firmware which just brings up LAN & starts telnet...
Try this firmware. Once started it's ifups wired LAN iface, set it to 192.168.1.1/255.255.255.0 and launchs telnetd. No password required to access it. You need to setup your PC with static address, something like 192.168.1.2. Try to telnet to wl500g, to check it's booted. After that you could examine your nvram using "nvram show".
I will try it now, thank you all for being so helpful.
I tried now, the router boots and I can telnet to it. When I write nvram show I see a lot of settings for the router. Don't really know what to look for. Tried to install a newer firmware after this without success.
Ok. At least it's alive. ;-) You need to look thru it to find something unusual using
or try this one to reset to defaults:Code:nvram show|more
after that you should be able (i've not verified this) to install regular firmwaresCode:nvram_x default
I'll try that one then.
IT WORKS IT WORKS.
I don't know how to thank you. But I really appreciated this.
Thank You
Maybe we should add the restoration firmware to the others.
//Adam.
So, nvram_x default did the trick?
