ftp and usb HUB
i'm french: sorry for bad english.
i have wl-500g, one hub usb 1.1, un quickcam, two USB-stick (128mo + 128mo). I want two ftp servers: how to make?
Jan 1 01:00:05 kernel: usb.c: registered new driver usbdevfs
Jan 1 01:00:05 kernel: usb.c: registered new driver hub
Jan 1 01:00:05 kernel: usb-ohci.c: USB OHCI at membase 0xb8004000, IRQ 2
Jan 1 01:00:05 kernel: usb-ohci.c: usb-00:04.0, PCI device 14e4:4715
Jan 1 01:00:05 kernel: usb.c: new USB bus registered, assigned bus number 1
Jan 1 01:00:05 kernel: hub.c: USB hub found
Jan 1 01:00:05 kernel: hub.c: 2 ports detected
Jan 1 01:00:06 kernel: hub.c: new USB device 00:04.0-1, assigned address 2
Jan 1 01:00:06 kernel: hub.c: USB hub found
Jan 1 01:00:06 kernel: hub.c: 4 ports detected
Jan 1 01:00:06 kernel: lp0: using parport0 (polling).
Jan 1 01:00:06 kernel: usb.c: registered new driver usblp
Jan 1 01:00:06 kernel: printer.c: v0.13: USB Printer Device Class driver
Jan 1 01:00:06 kernel: hub.c: new USB device 00:04.0-1.1, assigned address 3
Jan 1 01:00:06 kernel: usb.c: USB device 3 (vend/prod 0x46d/0x8b2) is not claimed by any active driver.
Jan 1 01:00:06 USB webcam: attached
Jan 1 01:00:07 kernel: hub.c: new USB device 00:04.0-1.2, assigned address 4
Jan 1 01:00:07 kernel: usb.c: USB device 4 (vend/prod 0xea0/0x2168) is not claimed by any active driver.
Jan 1 01:00:08 kernel: hub.c: new USB device 00:04.0-1.4, assigned address 5
Jan 1 01:00:08 kernel: usb.c: USB device 5 (vend/prod 0xd7d/0x120) is not claimed by any active driver.
Jan 1 01:00:08 kernel: usb.c: registered new driver audio
Jan 1 01:00:08 kernel: usbaudio: device 3 audiocontrol interface 1 has 1 input and 0 output AudioStreaming interfaces
Jan 1 01:00:08 kernel: usbaudio: device 3 interface 2 altsetting 1 channels 1 framesize 2 configured
Jan 1 01:00:08 kernel: usbaudio: valid input sample rate 44100
Jan 1 01:00:08 kernel: usbaudio: device 3 interface 2 altsetting 1: format 0x00000010 sratelo 44100 sratehi 44100 attributes 0x00
Jan 1 01:00:08 kernel: usbaudio: device 3 interface 2 altsetting 2 channels 1 framesize 2 configured
Jan 1 01:00:08 kernel: usbaudio: valid input sample rate 22050
Jan 1 01:00:08 kernel: usbaudio: device 3 interface 2 altsetting 2: format 0x00000010 sratelo 22050 sratehi 22050 attributes 0x00
Jan 1 01:00:08 kernel: usbaudio: device 3 interface 2 altsetting 3 channels 1 framesize 2 configured
Jan 1 01:00:08 kernel: usbaudio: valid input sample rate 11025
Jan 1 01:00:08 kernel: usbaudio: device 3 interface 2 altsetting 3: format 0x00000010 sratelo 11025 sratehi 11025 attributes 0x00
Jan 1 01:00:08 kernel: usbaudio: device 3 interface 2 altsetting 4 channels 1 framesize 2 configured
Jan 1 01:00:08 kernel: usbaudio: valid input sample rate 8000
Jan 1 01:00:08 kernel: usbaudio: device 3 interface 2 altsetting 4: format 0x00000010 sratelo 8000 sratehi 8000 attributes 0x00
Jan 1 01:00:08 kernel: usbaudio: registered dsp 14,3
Jan 1 01:00:08 kernel: usbaudio: warning: found 1 of 0 logical channels.
Jan 1 01:00:08 kernel: usbaudio: assuming the channel found is the master channel (got a Philips camera?). Should be fine.
Jan 1 01:00:08 kernel: usbaudio: registered mixer 14,0
Jan 1 01:00:08 kernel: audio.c: v1.0.0:USB Audio Class driver
Jan 1 01:00:09 kernel: Linux video capture interface: v1.00
Jan 1 01:00:09 kernel: pwc Philips PCA645/646 + PCVC675/680/690 + PCVC730/740/750 webcam module version 8.12 loaded.
Jan 1 01:00:09 kernel: pwc Also supports the Askey VC010, various Logitech Quickcams, Samsung MPC-C10 and MPC-C30,
Jan 1 01:00:09 kernel: pwc the Creative WebCam 5, SOTEC Afina Eye and Visionite VCS-UC300 and VCS-UM100.
Jan 1 01:00:09 kernel: usb.c: registered new driver Philips webcam
Jan 1 01:00:09 kernel: pwc Logitech QuickCam 4000 Pro USB webcam detected.
Jan 1 01:00:09 kernel: pwc Registered as /dev/video0.
Jan 1 01:00:09 kernel: SCSI subsystem driver Revision: 1.00
Jan 1 01:00:10 dnsmasq[48]: DHCPREQUEST(br0) 192.168.0.5 00:0e:35:c3:de:f5
Jan 1 01:00:10 dnsmasq[48]: DHCPACK(br0) 192.168.0.5 00:0e:35:c3:de:f5 cr43291
Jan 1 01:00:10 kernel: Initializing USB Mass Storage driver...
Jan 1 01:00:10 kernel: usb.c: registered new driver usb-storage
Jan 1 01:00:10 kernel: pwc This Logitech QuickCam Pro 4000 camera is equipped with a unknown type of sensor (-32).
Jan 1 01:00:11 kernel: pwc Failed to set LED on/off time.
Jan 1 01:00:11 kernel: scsi0 : SCSI emulation for USB Mass Storage devices
Jan 1 01:00:11 kernel: Vendor: Sarotech Model: Flash Disk Rev: 2.00
Jan 1 01:00:11 kernel: Type: Direct-Access ANSI SCSI revision: 02
Jan 1 01:00:11 kernel: Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
Jan 1 01:00:11 kernel: SCSI device sda: 256000 512-byte hdwr sectors (131 MB)
Jan 1 01:00:11 kernel: sda: Write Protect is off
Jan 1 01:00:11 kernel: Partition check:
Jan 1 01:00:11 kernel: p1
Jan 1 01:00:11 kernel: scsi1 : SCSI emulation for USB Mass Storage devices
Jan 1 01:00:11 kernel: Vendor: Model: USB DISK Pro Rev: 1.19
Jan 1 01:00:11 kernel: Attached scsi removable disk sdb at scsi1, channel 0, id 0, lun 0
Jan 1 01:00:11 kernel: Attached scsi removable disk sdc at scsi1, channel 0, id 0, lun 1
Jan 1 01:00:11 kernel: SCSI device sdb: 250880 512-byte hdwr sectors (128 MB)
Jan 1 01:00:11 kernel: sdb: Write Protect is off
Jan 1 01:00:11 kernel: SCSI device sdc: 2880 512-byte hdwr sectors (1 MB)
Jan 1 01:00:11 kernel: sdc: Write Protect is off
Jan 1 01:00:11 kernel: p1 p2 p3 p4
Jan 1 01:00:11 kernel: USB Mass Storage support registered.
- You may not post replies
- You may not edit your posts
Forum Rules
