Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
Thread: Compiling [need HowTo]
    JF, I'm now working on 1.9.2.7-6c. Perhaps there would be 1.9.5.0-1 or something, which would be 1.9.2.7 based (but includes 1.9.5.0 fixes), as moving to 1.9.5.0 is a big pain...
    JF, actually you should consider switching to OpenWRT, as it has web interface now.
    created a toolchain for native compilation use:
    ipkg install optware-devel
    as advised by al37919
    running
    /opt/broadcom/opt/brcm/hndtools-mipsel-uclibc-0.9.19/bin/mipsel-uclibc-gcc
    i get the following errors
    [admin@oo /opt]$ mipsel-uclibc-gcc -o helloworld
    -sh: mipsel-uclibc-gcc: not found
    [admin@oo /opt]$ /opt/broadcom/opt/brcm/hndtools-mipsel-uclibc-0.9.19/bin/mipsel-uclibc-gcc
    /opt/broadcom/opt/brcm/hndtools-mipsel-uclibc-0.9.19/bin/mipsel-uclibc-gcc: /opt/broadcom/opt/brcm/hndtools-mipsel-uclibc-0.9.19/bin/mipsel-uclibc-gcc: 1: Syntax error: "(" unexpected
    [admin@oo /opt]$ /opt/broadcom/opt/brcm/hndtools-mipsel-uclibc-0.9.19/bin/mipsel-uclibc-gcc --help
    [admin@oo /opt]$
    Any sollution for syntax error "(" ?
    And what directory is/was correct to save optware-devel
    and how to make
    running as
    mipsel-uclibc-gcc
    only ?
    What is your solution ?
    Tried to install
    mkdir /opt
    cd /opt < enter >
    wget http://www.asuscom.de/pub/ASUS/wirel...3/GPL_1927.zip < enter >
    tar zxf ./GPL_1927.zip < enter >
    cp -R /opt/broadcom/opt/brcm /opt < enter >
    cd /var/tmp
    wget http://oleg.wl500g.info/1.9.2.7-6b/w...2.7-6b.tar.bz2
    tar xjf wl500g-1.9.2.7-6b.tar.bz2
    cd wl500g-1.9.2.7-6b
    make uClibc
    but was low on memory (2GB pendrive)
    and -j option didn't work.
    Today
    mipsel-uclibc-gcc
    generates syntax error.
    I need Linux dialog to test some shell scripts.
    What's wrong, any help ?
    Darius
    Strange problem!!
    I did many and many test looking at your guides and tutorial... I waste a lot of time but... the situation is that:
    1) Compiling helloworld.c with mipsel-uclibc-gcc -o hello hello.c
    I can obtain hello executable.
    If I run hello on the router I get
    "./hello: can't load library 'AP'"
    2) If after compiling I write mipsel-uclibc-ld hello
    I can obtain an a.out executable that works on the router.
    If I rename the file a.out -> hello on my PC then I go back to error shown on point 1.
    If I copy a.out to the router and then rename it as hello all works well!
    3) Compiling helloworld.c with mipsel-uclibc-gcc -static -o hello hello.c
    I can get hello executable but when I run it on the router I get segmentation fault...
    Please help! I'm becoming mad!
    Hi everyone,
    I tried already native compilation, but I didn't succed, so I gave cross compiling a try. I've booted my laptop with ubuntu intrepid and I followed Jean-Fabrice's tutorial, but it doesn't seem to be complete. I noticed, that on oleg.wl500g.info Oleg posted a new toolchain (uClibc 0.9.19), so I installed it as well. What I have so far is the following:
    1. The following extracted directories under /opt
    hndtools-mipsel-linux
    hndtools-mipsel-linux3
    hndtools-mipsel-uClibc
    hndtools-mipsel-uClibc (this one is created by the new toolchain)
    2. The following extracted directories under /var/tmp
    uClibc-0.9.19
    wl50g-1.9.2.7.6b
    I have a feeling that after the command "make uClibc" there are still things to do before we execute "mipsel-uclibc-gcc -o helloworld helloworld.c".
    When I ran the command "make uClibc", I got these errors:
    PHP Code:
    dp79@Perro:/var/tmp/wl500g-1.9.2.7-6bsudo make uClibc
    tar xjf uClibc
    -0.9.19.tar.bz2 -/var/tmp
    Looking
    for last applied patch
    ./patch.shline 19patchcommand not found
    Patching
    /var/tmp/uClibc-0.9.19 with  uClibc-0.9.19-trunc64.patch uClibc-0.9.19-timezones.patch uClibc-0.9.19-dn_expand.patch uClibc-0.9.19-resolv.patch uClibc-0.9.19.diff
    ./patch.shline 33patchcommand not found
    ./patch.shline 37patchcommand not found
    Can not apply uClibc
    -0.9.19.diff cleanly
    make
    : *** [/var/tmp/uClibcError 1
    This "make" command created the "uClibc-0.9.19" directory, but nothing has been installed, because the system doesn't recognize the "mipsel-uclibc-gcc" command.
    Could somebody finish this tutorial and show us how to compile helloworld from the beginning to the end?
    Thanks!
    dp79
    Waoh...Fast answer...
    I've seen this site, but it is a tutorial for custom firmware and not a tutorial for installing software from source for the existing firmware...
    Or you meant, that the process is the same, but instead of the firmware tarball, I use the tarball of the target software?
    dp79
    Yes
    It would really help if there was some updated easy-to-understand how-to for cross-compiling own software.
    All of the current how-to instructions seem to be outdated or not complete.
  1. Compiling 1.9.2.7-6b firmware
    By unaiur in forum WL-500g Q&A
    Last Post: 30-09-2005, 10:24
  2. Compiling MusicPD
    By muffl0n in forum WL-500g Q&A
    Last Post: 20-07-2005, 21:03
  3. Compiling ggrab...
    By gwl in forum WL-500g Custom Development
    Last Post: 19-03-2005, 22:45
  4. Error while compiling ppp in 1.9.2.7-3
    By Ifaistos in forum WL-500g Custom Development
    Last Post: 12-01-2005, 18:03
  5. Compiling on/for the WL-500g
    By dsf260 in forum WL-500g Q&A
    Last Post: 12-12-2004, 11:54
