Дополнение.
Status & Log - System Log:
Jan 1 02:00:04 syslogd started: BusyBox v1.01 (2005.09.20-17:47+0000)
Jan 1 02:00:04 kernel: Setting the PFC value as 0x15
Jan 1 02:00:04 kernel: Determined physical RAM map:
Jan 1 02:00:04 kernel: memory: 02000000 @ 00000000 (usable)
Jan 1 02:00:04 kernel: On node 0 totalpages: 8192
Jan 1 02:00:04 kernel: zone(0): 8192 pages.
Jan 1 02:00:04 kernel: zone(1): 0 pages.
Jan 1 02:00:04 kernel: zone(2): 0 pages.
Jan 1 02:00:04 kernel: Kernel command line: root=/dev/mtdblock2 noinitrd init=/linuxrc console=ttyS0,115200
Jan 1 02:00:04 kernel: CPU: BCM5365 rev 1 at 200 MHz
Jan 1 02:00:04 kernel: Calibrating delay loop... 199.47 BogoMIPS
Jan 1 02:00:04 kernel: Memory: 30076k/32768k available (1767k kernel code, 2692k reserved, 248k data, 72k init, 0k highmem)
Jan 1 02:00:04 kernel: Dentry cache hash table entries: 4096 (order: 3, 32768 bytes)
Jan 1 02:00:04 kernel: Inode cache hash table entries: 2048 (order: 2, 16384 bytes)
Jan 1 02:00:04 kernel: Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Jan 1 02:00:04 kernel: Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 02:00:04 kernel: Page-cache hash table entries: 8192 (order: 3, 32768 bytes)
Jan 1 02:00:04 kernel: Checking for 'wait' instruction... unavailable.
Jan 1 02:00:04 kernel: POSIX conformance testing by UNIFIX
Jan 1 02:00:04 kernel: PCI: Fixing up bus 0
Jan 1 02:00:04 kernel: PCI: Fixing up bridge
Jan 1 02:00:04 kernel: PCI: Fixing up bus 1
Jan 1 02:00:04 kernel: Linux NET4.0 for Linux 2.4
Jan 1 02:00:04 kernel: Based upon Swansea University Computer Society NET3.039
Jan 1 02:00:04 kernel: Initializing RT netlink socket
Jan 1 02:00:04 kernel: Starting kswapd
Jan 1 02:00:04 kernel: Journalled Block Device driver loaded
Jan 1 02:00:04 kernel: devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
Jan 1 02:00:04 kernel: devfs: boot_options: 0x1
Jan 1 02:00:04 kernel: NTFS driver v1.1.22 [Flags: R/O]
Jan 1 02:00:04 kernel: pty: 256 Unix98 ptys configured
Jan 1 02:00:04 kernel: Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI enabled
Jan 1 02:00:04 kernel: ttyS00 at 0xb8000300 (irq = 3) is a 16550A
Jan 1 02:00:04 kernel: ttyS01 at 0xb8000400 (irq = 0) is a 16550A
Jan 1 02:00:04 kernel: loop: loaded (max 8 devices)
Jan 1 02:00:04 kernel: PPP generic driver version 2.4.2
Jan 1 02:00:04 kernel: PPP Deflate Compression module registered
Jan 1 02:00:04 kernel: PPP BSD Compression module registered
Jan 1 02:00:04 kernel: MPPE/MPPC encryption/compression module registered
Jan 1 02:00:04 kernel: Amd/Fujitsu Extended Query Table v1.1 at 0x0040
Jan 1 02:00:04 kernel: number of CFI chips: 1
Jan 1 02:00:04 kernel: Flash device: 0x400000 at 0x1c000000
Jan 1 02:00:04 kernel: Physically mapped flash: squashfs filesystem found at block 942
Jan 1 02:00:04 kernel: Creating 5 MTD partitions on "Physically mapped flash":
Jan 1 02:00:04 kernel: 0x00000000-0x00040000 : "pmon"
Jan 1 02:00:04 kernel: 0x00040000-0x003e0000 : "linux"
Jan 1 02:00:04 kernel: 0x000eba70-0x003e0000 : "rootfs"
Jan 1 02:00:04 kernel: 0x003f0000-0x00400000 : "nvram"
Jan 1 02:00:04 kernel: 0x003e0000-0x003f0000 : "config"
Jan 1 02:00:04 kernel: sflash: found no supported devices
Jan 1 02:00:04 kernel: NET4: Linux TCP/IP 1.0 for NET4.0
Jan 1 02:00:04 kernel: IP Protocols: ICMP, UDP, TCP
Jan 1 02:00:04 kernel: IP: routing cache hash table of 512 buckets, 4Kbytes
Jan 1 02:00:04 kernel: TCP: Hash tables configured (established 2048 bind 4096)
Jan 1 02:00:04 kernel: ip_conntrack version 2.1 (256 buckets, 2048 max) - 344 bytes per conntrack
Jan 1 02:00:04 kernel: ip_conntrack_pptp version 1.9 loaded
Jan 1 02:00:04 kernel: ip_nat_pptp version 1.5 loaded
Jan 1 02:00:04 kernel: ip_tables: (C) 2000-2002 Netfilter core team
Jan 1 02:00:04 kernel: ipt_time loading
Jan 1 02:00:04 kernel: NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
Jan 1 02:00:04 kernel: IPv6 v0.8 for NET4.0
Jan 1 02:00:04 kernel: IPv6 over IPv4 tunneling driver
Jan 1 02:00:04 kernel: NET4: Ethernet Bridge 008 for NET4.0
Jan 1 02:00:04 kernel: 802.1Q VLAN Support v1.7 Ben Greear <greearb@candelatech.com>
Jan 1 02:00:04 kernel: All bugs added by David S. Miller <davem@redhat.com>
Jan 1 02:00:04 kernel: FAT: bogus logical sector size 24576
Jan 1 02:00:04 kernel: NTFS: Unable to set blocksize 512.
Jan 1 02:00:04 kernel: VFS: Mounted root (squashfs filesystem) readonly.
Jan 1 02:00:04 kernel: Mounted devfs on /dev
Jan 1 02:00:04 kernel: Freeing unused kernel memory: 72k freed
Jan 1 02:00:04 kernel: Algorithmics/MIPS FPU Emulator v1.5
Jan 1 02:00:04 kernel: eth0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 3.90.7.0
Jan 1 02:00:04 kernel: PCI: Enabling device 01:03.0 (0004 -> 0006)
Jan 1 02:00:04 kernel: Controller 3.90.23.0
Jan 1 02:00:04 kernel: vlan0: add 33:33:00:00:00:01 mcast address to master interface
Jan 1 02:00:04 kernel: vlan0: add 33:33:ff:da:66:0b mcast address to master interface
Jan 1 02:00:04 kernel: vlan0: dev_set_promiscuity(master, 1)
Jan 1 02:00:04 kernel: device eth0 entered promiscuous mode
Jan 1 02:00:04 kernel: device vlan0 entered promiscuous mode
Jan 1 02:00:04 kernel: device eth1 entered promiscuous mode
Jan 1 02:00:04 kernel: br0: port 2(eth1) entering listening state
Jan 1 02:00:04 kernel: br0: port 1(vlan0) entering listening state
Jan 1 02:00:04 kernel: br0: port 2(eth1) entering learning state
Jan 1 02:00:05 kernel: br0: port 2(eth1) entering forwarding state
Jan 1 02:00:05 kernel: br0: topology change detected, propagating
Jan 1 02:00:05 kernel: br0: port 1(vlan0) entering learning state
Jan 1 02:00:05 kernel: br0: port 1(vlan0) entering forwarding state
Jan 1 02:00:05 kernel: usb.c: registered new driver usbdevfs
Jan 1 02:00:05 kernel: usb.c: registered new driver hub
Jan 1 02:00:05 kernel: usb-uhci.c: $Revision: 1.275 $ time 21:43:09 Apr 20 2005
Jan 1 02:00:05 kernel: usb-uhci.c: High bandwidth mode enabled
Jan 1 02:00:05 kernel: PCI: Enabling device 01:02.0 (0000 -> 0001)
Jan 1 02:00:05 kernel: usb-uhci.c: USB UHCI at I/O 0x100, IRQ 2
Jan 1 02:00:05 kernel: usb-uhci.c: Detected 2 ports
Jan 1 02:00:05 kernel: usb.c: new USB bus registered, assigned bus number 1
Jan 1 02:00:05 kernel: hub.c: USB hub found
Jan 1 02:00:05 kernel: hub.c: 2 ports detected
Jan 1 02:00:05 kernel: PCI: Enabling device 01:02.1 (0000 -> 0001)
Jan 1 02:00:05 kernel: usb-uhci.c: USB UHCI at I/O 0x120, IRQ 2
Jan 1 02:00:05 kernel: usb.c: new USB bus registered, assigned bus number 2
Jan 1 02:00:06 kernel: hub.c: USB hub found
Jan 1 02:00:06 kernel: hub.c: 2 ports detected
Jan 1 02:00:06 kernel: usb-uhci.c: v1.275:USB Universal Host Controller Interface driver
Jan 1 02:00:06 kernel: PCI: Enabling device 01:02.2 (0000 -> 0002)
Jan 1 02:00:06 kernel: ehci_hcd 01:02.2: PCI device 1106:3104
Jan 1 02:00:06 kernel: ehci_hcd 01:02.2: irq 2, pci mem c00a2000
Jan 1 02:00:06 kernel: usb.c: new USB bus registered, assigned bus number 3
Jan 1 02:00:06 kernel: PCI: 01:02.2 PCI cache line size set incorrectly (0 bytes) by BIOS/FW, correcting to 32
Jan 1 02:00:06 kernel: ehci_hcd 01:02.2: USB 2.0 enabled, EHCI 1.00, driver 2003-Dec-29/2.4
Jan 1 02:00:06 kernel: hub.c: 4 ports detected
Jan 1 02:00:06 kernel: usb.c: registered new driver usblp
Jan 1 02:00:06 kernel: printer.c: v0.13: USB Printer Device Class driver
Jan 1 02:00:06 kernel: Linux video capture interface: v1.00
Jan 1 02:00:06 kernel: SCSI subsystem driver Revision: 1.00
Jan 1 02:00:07 kernel: Initializing USB Mass Storage driver...
Jan 1 02:00:07 kernel: usb.c: registered new driver usb-storage
Jan 1 02:00:07 kernel: USB Mass Storage support registered.
Jan 1 02:00:07 kernel: vlan1: Setting MAC address to 00 00 XX XX XX XX.
Jan 1 02:00:07 kernel: vlan1: add 33:33:00:00:00:01 mcast address to master interface
Jan 1 02:00:07 kernel: vlan1: add 33:33:XX:XX:XX:XX mcast address to master interface
Jan 1 02:00:07 udhcpc[90]: udhcpc (v0.9.9-pre) started
Jan 1 02:00:07 kernel: vlan1: add 01:00:5e:00:00:01 mcast address to master interface
Jan 1 02:00:08 dnsmasq[69]: read /etc/hosts - 5 addresses
Jan 1 02:00:08 dnsmasq[69]: read /etc/ethers - 2 addresses
Jan 1 02:00:08 dnsmasq[69]: reading /tmp/resolv.conf
Jan 1 02:00:08 dhcp client: deconfig: lease is lost
Jan 1 02:00:08 udhcpc[90]: Lease of 192.168.248.136 obtained, lease time 604800
Jan 1 02:00:08 dnsmasq[69]: using nameserver 192.168.240.3#53
Jan 1 02:00:08 dnsmasq[69]: using nameserver 192.168.240.2#53
Jan 1 02:00:08 dnsmasq[69]: using nameserver 192.168.240.1#53
Jan 1 02:00:09 dhcp client: bound IP : 192.168.248.136 from 192.168.240.1
Nov 10 21:12:38 ntp client: Synchronizing time with pool.ntp.org ...
