i'm trying to setup two wl500g to bridge together.
My scenario is the following:
I have - one wl500g setup as AP only, with DHCP WPA-PSK TKIP, VIRTUAL SERVER, etc.... working fine.
I've bought a second one which i'd like to setup as being an extension to the first one allowing me to place it on my backyard where it will get signal from the first wl500g and also allow clients to connect.
My problem is that i don't know how should i setup this.
I've selected Hybrid on Wireless Bridge config page, configured the channel, SSID, DHCP server, etc.... equal to the first wl500g but it doesn't work.
Even tried to change the "Operation Mode" from "Home Gateway" to "Access Point".
Can you tell me what do i need to configure ?
Can someone help me ?
