I did a lot of stuff with my WL-Hdd to get it running. Now, I think I've did something very wrong:
It doesn't mount anything anymore.
I tried
nvram-clear and recover, tried different firmware versions (Oleg and Asus original), but cannot get it working again.
What have I got to do?
What content of which files or commands do you need to provide further help?
Please help
Brennivin
After reboot, the following commands are showing the results:
df:
[admin@(none) root]$ df
/dev/root 2816 2816 0 100% /
flashfs list:
[admin@(none) root]$ flashfs list
tmp/local
tmp/local/root
fdisk -l:
[admin@(none) root]$ fdisk -l
Disk /dev/ide/host0/bus0/target0/lun0/disc: 80.0 GB, 80060424192 bytes
255 heads, 63 sectors/track, 9733 cylinders
/dev/ide/host0/bus0/target0/lun0/part1 1 9501 76316751 83 Linux
/dev/ide/host0/bus0/target0/lun0/part2 9502 9733 1863540 82 Linux swap
[admin@(none) root]$ mount /dev/ide/host0/bus0/target0/lun0/part1 /opt
mount: Mounting /dev/ide/host0/bus0/target0/lun0/part1 on /opt failed: Invalid argument
nvram show | sort:
audio_enable=0
autofw_desc_x=
autofw_enable_x=0
autofw_inport_x=
autofw_inproto_x=
autofw_num_x=0
autofw_outport_x=
autofw_outproto_x=
autofw_port0=
boardnum=asusX
boardtype=bcm94710dev
boot_wait=on
clkfreq=125
console_loglevel=0
ddns_enable_x=0
ddns_hostname_x=
ddns_passwd_x=
ddns_server_x=
ddns_status_t=
ddns_username_x=
ddns_wildcard_x=0
dhcp_dns1_x=
dhcp_domain=wan
dhcp_enable_x=1
dhcp_end=192.168.1.254
dhcp_gateway_x=
dhcp_lease=86400
dhcp_start=192.168.1.2
dhcp_static_x=0
dhcp_staticip_x=
dhcp_staticmac_x=
dhcp_staticnum_x=0
dhcp_wins=wan
dhcp_wins_x=
dl_ram_addr=a0001000
dmz_ip=
dmz_ipaddr=
dr_default_x=1
dr_static_matric_x=1
dr_static_rip_x=0
dr_staticgateway_x=
dr_staticipaddr_x=
dr_staticnetmask_x=0
dr_staticnum_x=0
et0macaddr=xx:xx:xx:xx:xx:xx
et0mdcport=0
et0phyaddr=0
et1macaddr=xx:xx:xx:xx:xx:xx
et1mdcport=1
et1phyaddr=01
ezc_enable=1
ezc_version=2
filter_client0=
filter_lw_date_x=1111111
filter_lw_default_x=ACCEPT
filter_lw_dstip_x=
filter_lw_dstport_x=
filter_lw_icmp_x=
filter_lw_num_x=0
filter_lw_proto_x=
filter_lw_srcip_x=
filter_lw_srcport_x=
filter_lw_time_x=00002359
filter_maclist=
filter_macmode=deny
filter_wl_date_x=1111111
filter_wl_default_x=ACCEPT
filter_wl_dstip_x=
filter_wl_dstport_x=
filter_wl_icmp_x=
filter_wl_num_x=0
filter_wl_proto_x=
filter_wl_srcip_x=
filter_wl_srcport_x=
filter_wl_time_x=00002359
firmver=1.9.2.7
forward_port0=
fw_disable=0
fw_enable_x=1
fw_log_x=none
fw_lw_enable_x=0
fw_wl_enable_x=0
hardware_version=WL300-02-03-01-20
http_lanport=80
http_passwd=xxxxxxxxxxxxxx
http_username=xxxxxxxxxxxx
http_wanport=
infosvr_enable=0
is_default=1
is_modified=0
lan_dhcp=0
lan_dns_t=192.168.0.1
lan_domain=
lan_gateway=
lan_gateway_t=192.168.0.1
lan_hostname=
lan_hwaddr=xx:xx:xx:xx:xx:xx
lan_hwnames=
lan_ifname=br0
lan_ifnames=eth2
lan_ifnames_t=eth2 eth1
lan_ipaddr=192.168.1.1
lan_ipaddr_t=192.168.0.106
lan_lease=86400
lan_lease_t=604800
lan_netmask=255.255.255.0
lan_netmask_t=255.255.255.0
lan_proto=dhcp
lan_proto_x=1
lan_route=
lan_stp=1
lan_wins=
log_ipaddr=
log_level=0
lpr_enable=0
macfilter_enable_x=disabled
macfilter_list_x=
macfilter_num_x=0
misc_conntrack_x=4096
misc_http_x=0
misc_httpport_x=8080
misc_lpr_x=0
misc_natlog_x=0
misc_ping_x=0
no_br=0
ntp_interval_x=2
ntp_server0=time.nist.gov
ntp_server1=
ntp_server=192.5.41.40 192.5.41.41 133.100.9.2
ntp_servers=time.nist.gov
os_date=Oct 11 2005
os_flash_addr=bfc40000
os_name=linux
os_ram_addr=80001000
os_server=
os_version=3.91.7.0
pmon_ver=PMON 3.11.19.0
printer_ifname=usb
printer_model_t=
printer_status_t=
printer_user_t=
productid=WLHDD
qos_enable_x=0
qos_ipaddr_x=
qos_maxbw_x=
qos_minbw_x=
qos_port_x=
qos_rulenum_x=0
qos_umaxbw_x=
qos_uminbw_x=
qos_uport_x=
qos_urulenum_x=0
raw_enable=0
regulation_domain=0x47TW
rescueflag=disable
restore_defaults=0
router_disable=1
scratch=a0180000
sdram_config=0x0000
sdram_init=0x0419
sdram_ncdl=0x00000000
sdram_refresh=0x8040
snmp_community=public
snmp_contact=Administrator
snmp_enable=0
snmp_location=Unknown
sp_battle_ips=1
sr_enable_x=0
sr_gateway_x=
sr_if_x=
sr_ipaddr_x=
sr_matric_x=
sr_netmask_x=
sr_num_x=0
sr_rip_x=0
stats_server=
telnet_enable=1
time_interval=20
time_zone=MEZ-1MESZ
timer_interval=3600
upnp_enable=1
url_date_x=1111111
url_enable_x=0
url_keyword_x=
url_num_x=0
url_time_x=00002359
usb_audio_device=
usb_bannum_x=0
usb_device=1
usb_ftp_device=
usb_ftpanonymous_x=1
usb_ftpbanip_x=
usb_ftpenable_x=1
usb_ftpmax_x=12
usb_ftpmaxuser_x=
usb_ftpnum_x=0
usb_ftppasswd_x=
usb_ftpport_x=21
usb_ftprights_x=
usb_ftpscript_x=
usb_ftpstaytimeout_x=240
usb_ftpsuper_x=0
usb_ftptimeout_x=120
usb_ftpusername_x=
usb_nfsenable_x=0
usb_nfsnum_x=0
usb_smbcpage_x=
usb_smbcset_x=
usb_smbenable_x=1
usb_smbhidden_x=1
usb_smbwrkgrp_x=Workgroup
usb_storage_device=
usb_web_device=5a9/a518/100
usb_web_flag=2
usb_webactivex_x=7777
usb_webattach_x=1
usb_webcaption_x=Web Camera Live Demo!!!
usb_webdriver_x=1
usb_webenable_x=1
usb_webfresh_x=1
usb_webhttpcheck_x=0
usb_webhttpport_x=7776
usb_webimage_x=1
usb_webmode_x=1
usb_webmserver_x=
usb_webrectime_x=0
usb_webremote1_x=
usb_webremote2_x=
usb_webremote3_x=
usb_webremote4_x=
usb_webremote5_x=
usb_webremote6_x=
usb_webremote_x=0
usb_websecurity_date_x=0000000
usb_websecurity_time_x=
usb_websecurity_x=0
usb_websendto_x=
usb_websense_x=1
usb_websubject_x=Motion detection alert!!!
vlan_enable=0
vts_desc_x=
vts_enable_x=1
vts_ipaddr_x=
vts_lport_x=
vts_num_x=0
vts_port_x=
vts_proto_x=
vts_protono_x=
wan0_desc=Default Connection
wan0_dns1_x=
wan0_dns2_x=
wan0_dns_t=
wan0_dnsenable_x=1
wan0_domain=
wan0_etherspeed_x=auto
wan0_gateway=
wan0_gateway_t=
wan0_heartbeat_x=
wan0_hostname=
wan0_hwaddr=
wan0_hwaddr_x=
wan0_hwname=
wan0_ifname=eth1
wan0_ifnames=eth1
wan0_ipaddr=
wan0_ipaddr_t=
wan0_lease=86400
wan0_mode_x=2
wan0_nat_x=0
wan0_netmask=
wan0_netmask_t=
wan0_pppoe_ac=
wan0_pppoe_demand=0
wan0_pppoe_idletime=1800
wan0_pppoe_ifname=
wan0_pppoe_keepalive=0
wan0_pppoe_mru=1492
wan0_pppoe_mtu=1492
wan0_pppoe_options_x=
wan0_pppoe_passwd=
wan0_pppoe_relay_x=0
wan0_pppoe_service=
wan0_pppoe_txonly_x=0
wan0_pppoe_username=
wan0_primary=1
wan0_proto=dhcp
wan0_proto_t=
wan0_route=
wan0_route_x=IP_Bridged
wan0_status_t=Disconnected
wan0_unit=0
wan0_wins=
wan_desc=
wan_dns1_x=
wan_dns2_x=
wan_dns=
wan_dns_t=
wan_dnsenable_x=1
wan_domain=
wan_etherspeed_x=auto
wan_gateway=
wan_gateway_t=
wan_heartbeat_x=
wan_hostname=
wan_hwaddr=
wan_hwaddr_x=
wan_hwname=
wan_ifname=eth1
wan_ifnames=eth1
wan_ipaddr=
wan_ipaddr_t=
wan_lease=86400
wan_mode_x=2
wan_nat_x=0
wan_netmask=
wan_netmask_t=
wan_pppoe_ac=
wan_pppoe_demand=0
wan_pppoe_idletime=1800
wan_pppoe_ifname=
wan_pppoe_keepalive=0
wan_pppoe_mru=1492
wan_pppoe_mtu=1492
wan_pppoe_options_x=
wan_pppoe_passwd=
wan_pppoe_relay_x=0
wan_pppoe_service=
wan_pppoe_txonly_x=0
wan_pppoe_username=
wan_primary=0
wan_proto=dhcp
wan_proto_t=
wan_route=
wan_route_x=IP_Bridged
wan_status_t=Disconnected
wan_unit=0
wan_wins=
watchdog=3000
**snipped the wlan settings**
x_Setting=1
MA, hdb
io
