Results 16 to 30 of 31
Thread: 1.9.5.0 beta CDMA firmware
    Page Not Found :-|
    Hi guys!
    Can anyone send me the firmware or tell me or I can download it?
    The address provided does not work anymore...:-(
    Thx!
    Jul 2004
    Poeldijk, The Netherlands
    Question
    I'm wondering if more people faced my problem.
    I first worked with the standard asus firmware 1.9.4.0 (I know it's beta)
    I had troubles on 2 machines (different settings, different antivirus, different FTP program, different websites tried) with uploading websites over FTP (timeout appeared with files bigger than 1,3 KB). So the only thing that the computers had both, was the router. So I updated to 1.9.5.0 to see if the problem was gone, but unfortunatly the problem stayed.
    After a new research I came back to the router, as other users on different Inet connection were able to upload files to the website.
    I downgraded my router to Oleg firmware 1.9.2.7 6b and the problem was gone. Now I don't know if it was a bug from of firmware 1.9.4.0 because I didn't had the problem earlier (on older firmware and on firmware 1.9.4.0). It just appeared.
    Quote Originally Posted by engy
    But wasn't supposed to be version 1.9.5.0?
    The one on that site is 1.9.2.7... :-|
    Thx!
    Quote Originally Posted by gothicsoul
    Thx!
    I found it on eMule...:-)
    ed2k://|file|Wl500G%201950%20En%20Cd...J3LUVWHG4ONR|/
    Till now everything works A-OK and very fast! :-)
    Firmware on koppel works faster because it contains some kernel patches to work faster and is based on Oleg's firmware.
    is this firmware in english?
    i dont know anything of polish.
    and has this firmware also samba server?
    and what i have to download on that site?
    It's not Polish but Czech and yes,the firmware is in English. Samba server included. Download the latesr 1.61 version.
    thanks engy, the router is also very fast now.
    Cdma
    Quote Originally Posted by arsvendg
    Thanks!
    Didn't make much sense to me though... I guess it's a kind of new technology or something....
    I use CDMA. Practically I have a CDMA modem (it is similar to GSM which you may know) connected to ASUS 500g and every computer can connect to internet through ASUS. Is it clear now?
    CDMA must be supported by operator, it works on 450 MHz. Average speed is around 300 kbps in Czech rep. I work on cca 150 kbps
    Cdma 2
    I use standard firmware + CDMA upgrade from koppel http://koppel.cz/cdmawifi/download/.
    hi ppl.
    I have a hp5550 printer installed in router. Since i've installed this firmware i can't print anything... I have already check router configurations but seems that everything is ok. can anyone help me?
    Is there a way to get telnet access to the stock Asus firmware? I want to play with pptp/pppd directly, but I need mpee support (added in 1.9.4)
    Telnet port seems to be closed on 1.9.5
    Or do I have to wait for an Oleg release based off 1.9.5?
    Unhappy
    hello,
    I need restore to default my asus ... but it don't want
    When I check " Facory default" it reboot and all my parameters are still here
    please help
    1.9.2.7-6b-CDMA vs 1.9.5.0-CDMA
    Hi all
    What are the beneficts/disadvantages/known bugs of these firmwares?
    Can they be used on wl500g deluxe also?
    Where else can I downlad 1.9.5.0 CDMA, since I'm having difficulties on getting it from eMule
    Thx
  1. Firmware v1.9.4.6 BETA
    Last Post: 07-09-2005, 16:12
  2. Firmware v1.9.3.5 BETA
    Last Post: 11-03-2005, 20:23
  3. Firmware v1.9.3.5 BETA
    By Antiloop in forum WL-500gx Firmware Releases
    Last Post: 24-02-2005, 21:08
  4. Firmware v1.7.5.9 BETA
    By Gary in forum WL-500g Firmware Releases
    Last Post: 04-06-2004, 21:27
  5. Firmware v1.7.5.7 BETA
    Last Post: 13-05-2004, 00:03
