Hi all,
when trying to use nylon proxy with my browser I get the following error message:
[admin@WL500 /opt/bin]$ /opt/etc/init.d/S10nylon start
Starting nylon... nylon: Listening on WL500:socks
nylon: Negotiation failed
Was could be the reason fo this and how can it be fixed?
I am using Oleg´s 1.9.2.7-6b on an WL500g Deluxe and installed Nylon 1.2-4 and libevent 1.0b-1 via ipkg. I am connected to WAN via DSL modem. My nylon.conf looks as follows:
# general settings
[General]
# number of simultaneous connections allowed
No-Simultaneous-Conn=1
# log connections and other information to syslog? 1: on, 0: off
Log=1
# be verbose on the console? 1: on, 0: off
Verbose=1
# store pid file
PIDfile=/opt/var/run/nylon.pid
# server settings
[Server]
# interface to listen to connections
Binding-Interface=br0
# interface to bind outgoing connections to
Connecting-Interface=ppp0
# listening port to bind to
Port=1080
# allowed is processed first, then deny
# allowable connect ips/ranges
Allow-IP=192.168.1.0/32
# denied connect ips/ranges
#Deny-IP=0.0.0.0/255
BTW
Unfortunately the wiki is down at the moment, perhaps someone could fix it. If you call up http://wiki.wl500g.info you will receive following message:
lib/WikiDB/backend/PearDB.php:698: Fatal[256]: wikidb_backend_mysql: fatal database error
DB Error: unknown error
(SELECT * FROM phpwiki_page WHERE pagename='global_data' [nativecode=1105 ** File '/usr/share/mysql/charsets/?.conf' not found (Errcode: 2)])
