Results 1 to 15 of 15
Thread: wireless not working
    Dear all,
    Thanks for the great work here, it shows the power of open source!!!!
    My wl-500b is a very old one, and I tried to upgrade to it to support maybe a httpd or something like that, and I was too happy when I saw this was done already.
    Last night was the first time for me to do the upgrade, I fetched the latest version here and all works until this morning, I noticed that the "Air" LED is not lighted. And all my wireless clients cannot connect.
    Then, I figured out that it should be that the fact I used a v2 firmware, I downgraded using the firmware restoration tool, back to use those for wl-500b without v2 in the file name... now, the "Air" LED light up, but still none of my wireless client can connect. I cannot even detect any wireless network, I've reset everything, and make it an open network, but it won't work too.
    Any hint? Thanks a lot for this great forum, and also those amazing firmwares!
    Oldfield
    Since going back to older firmware does not help much, I moved on to use the latest, everything seems fine except wireless again, I telnet into the box and see the following:
    == BEGIN ==
    Jan 1 00:00:05 kernel: eth0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 3.90.7.0
    Jan 1 00:00:05 kernel: eth1: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 3.90.7.0
    Jan 1 00:00:05 kernel: PCI: Enabling device 01:02.0 (0004 -> 0006)
    Jan 1 00:00:05 kernel: eth2: Broadcom BCM4301 802.11 Wireless Controller 3.90.23.0
    Jan 1 00:00:05 kernel: device eth0 entered promiscuous mode
    Jan 1 00:00:05 kernel: device eth2 entered promiscuous mode
    Jan 1 00:00:05 kernel: br0: port 2(eth2) entering listening state
    Jan 1 00:00:05 kernel: br0: port 1(eth0) entering listening state
    Jan 1 00:00:05 kernel: br0: port 2(eth2) entering learning state
    Jan 1 00:00:05 kernel: br0: port 1(eth0) entering learning state
    Jan 1 00:00:05 kernel: br0: port 2(eth2) entering forwarding state
    Jan 1 00:00:05 kernel: g
    Jan 1 00:00:05 kernel: br0: port 1(eth0) entering forwarding state
    Jan 1 00:00:05 kernel: br0: topology change detected, propagating
    == END ==
    so with my limited knowledge, the device seems working, at least the kernel can detect it (still).
    also, I saw "waveservermain" is active from "ps", I assume it's the process responsible for wireless connection?
    any one can shed some light here? thanks.
    wl.o ?
    is it the problem? but I can't find modprobe....
    [admin@(none) /]$ lsmod
    Module Size Used by
    usb-storage 62144 0 (unused)
    sd_mod 13268 0 (unused)
    scsi_mod 70176 1 [usb-storage sd_mod]
    videodev 8304 0
    audio 50120 0 (unused)
    soundcore 5280 0 [audio]
    printer 12652 0 (unused)
    lp 8628 0
    parport_splink 2956 1
    parport 25664 1 [lp parport_splink]
    usb-ohci 21764 0 (unused)
    usbcore 77224 1 [usb-storage audio printer usb-ohci]
    wl 420904 0 (unused)
    et 34912 0 (unused)
    ipt_NETMAP 992 2
    ip_nat_starcraft 2224 0 (unused)
    Problem solved!
    Finally, I solved the problem, I manually removed that wl module and install it again, it works now... just wonder if I have to do this everytime I restart it... anyway, better than nothing.
    Now, I can try out those new features of these amazing firmwares!!!
    Sounds like talking to myself here, but I hope my problem solving log could help someone else later. :-)
    Have you tried reseting to defaults?
    yes, thanks for your tips.
    wireless led off
    hello oldfieldso the same thing append to me my wireless router is old wl-500b and the only firmware to connect with bigpond is 1.9.2.7.-7c and is working fine but no wireless can you explain me how to fix this problem.
    Quote Originally Posted by oldfieldso
    Quote Originally Posted by pegnin View Post
    same HW same problem, i removed the wl part from inside, reboot, and give it back again but nothing happend, wl still dont work, plz help
    Try to do a reset, and then downgrade the firmware to standard ones, and do a reset again.
    Maybe the difference is due to v2 vs. the oldest hardware.
    Question
    I have the same HW same problem now. I have tried the firmwares as follows:
    wl-500v2 1.9.2.7-7f
    wl-500v2 1.9.2.7-7e
    wl-500v2 1.9.2.7-7b
    wl-500v2 1.9.2.7-6b
    wl-500v2 1.9.2.7-6a
    but the wireless doesn't work all the time. Could anybody help us?
    Thanks in advance.
    Wifi not working
    Hello, I have WL-500bv2. I have upgraded to version WL500bv2-1.9.2.7-8.
    When router boots up, AIR light is on. But wifi network is not found. I have restored default setting a few times.
    In system log:
    Jan 1 00:00:05 kernel: eth0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 4.108.9.0
    Jan 1 00:00:05 kernel: eth1: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 4.108.9.0
    and nothing about wireless adapter.
    When i run: wl up
    wl: wl driver adapter not found
    Can help me someone ?
    How can I reload driver ?
    Thanks.
    Most likely you've original wl500b, not wl500b v2.
    Use wl500b firmware. Flash it with firmware restoration tool.
    I tried to upgrade to wl-500b, WL500b-1.9.2.7-8.trx.
    Result is:
    Firmware upgrade fail. It may result from incorrect image or error transmission. Please check the version of firmare and try again.
    In System Setup - Firmware Upgrade - Product ID: WL500bv2
    Upgraded 2 WL500b's and one WL500bv2, all three do not show any radio
    After downgrading to factory firmware all is OK.
    Finally, it's not possible to use oleg's firmware for this device
  1. ASUS WIRELESS ROUTER (WL-500g) NOT WORKING.. HELP!!!
    By jamespond in forum WL-500g Q&A
    Last Post: 09-12-2005, 18:06
  2. wl-500g wireless partially not working
    By Neighbour in forum WL-500g Q&A
    Last Post: 26-06-2005, 01:02
  3. Home Gateway newbie... Wireless not working
    By Fenni in forum WL-500g Q&A
    Last Post: 05-11-2004, 21:05
  4. Replies: 0
    Last Post: 28-09-2004, 17:30
  5. Wireless DHCP not working in latest firmware?
    By PascalF in forum WL-500g Q&A
    Last Post: 14-09-2004, 16:25
