Results 1 to 2 of 2
Thread: How do I port forward properly? [oleg firmware]
    Hello!
    So I have everything up and running finally on my old WL-500gP router.
    However, I have a problem I get slow speeds with Transmission up to 800KB/s, normally I can get up to 1.5MB/s with the same good seeded torrents from my PC and Transmission also reports that the port is closed.
    I'm going to attach the settings of what I have done so far.
    Thanks in advance.
    Please note:
    In uTorrent I have UPnP and NAT-PMP port mapping enabled.
    uTorrent also reports that the port is closed.
    Also in Transmission UPnP doesn't work, it still reports that the port is closed.
        "alt-speed-down": 50,
        "alt-speed-enabled": false,
        "alt-speed-time-begin": 540,
        "alt-speed-time-day": 127,
        "alt-speed-time-enabled": false,
        "alt-speed-time-end": 1020,
        "alt-speed-up": 50,
        "bind-address-ipv4": "0.0.0.0",
        "bind-address-ipv6": "::",
        "blocklist-enabled": true,
        "blocklist-url": "http://www.example.com/blocklist",
        "cache-size-mb": 4,
        "dht-enabled": true,
        "download-dir": "/tmp/harddisk/transmission/download",
        "download-queue-enabled": true,
        "download-queue-size": 5,
        "encryption": 2,
        "idle-seeding-limit": 1,
        "idle-seeding-limit-enabled": false,
        "incomplete-dir": "/usr/local/root/Downloads",
        "incomplete-dir-enabled": false,
        "lazy-bitfield-enabled": true,
        "lpd-enabled": false,
        "message-level": 2,
        "open-file-limit": 64,
        "peer-congestion-algorithm": "",
        "peer-id-ttl-hours": 6,
        "peer-limit-global": 500,
        "peer-limit-per-torrent": 100,
        "peer-port": 50126,
        "peer-port-random-enabled": false,
        "peer-port-random-high": 65535,
        "peer-port-random-low": 1024,
        "peer-port-random-on-start": false,
        "peer-socket-tos": "default",
        "pex-enabled": true,
        "port-forwarding-enabled": true,
        "preallocation": 1,
        "prefetch-enabled": 1,
        "proxy": "",
        "proxy-auth-enabled": false,
        "proxy-auth-password": "",
        "proxy-auth-username": "",
        "proxy-enabled": false,
        "proxy-port": 80,
        "proxy-type": 0,
        "queue-stalled-enabled": true,
        "queue-stalled-minutes": 30,
        "ratio-limit": 0.0098,
        "ratio-limit-enabled": true,
        "rename-partial-files": true,
        "rpc-authentication-required": false,
        "rpc-bind-address": "0.0.0.0",
        "rpc-enabled": true,
        "rpc-password": "{6f7242c584183be3b79cf89bea7741f9c7f6c904gZwnn/Qb",
        "rpc-port": 9091,
        "rpc-url": "/transmission/",
        "rpc-username": "",
        "rpc-whitelist": "127.0.0.1,192.168.0.*",
        "rpc-whitelist-enabled": true,
        "scrape-paused-torrents-enabled": true,
        "script-torrent-done-enabled": false,
        "script-torrent-done-filename": "",
        "seed-queue-enabled": false,
        "seed-queue-size": 10,
        "speed-limit-down": 500,
        "speed-limit-down-enabled": false,
        "speed-limit-up": 20,
        "speed-limit-up-enabled": true,
        "start-added-torrents": true,
        "trash-original-torrent-files": false,
        "umask": 18,
        "upload-slots-per-torrent": 14,
        "utp-enabled": true
    Firewallrule
    iptables -t nat -A PREROUTING -p tcp --dport PUBLICPORT -j DNAT --to TARGETIP:PORT
  1. New oleg firmware version
    By Lesiuk in forum WL-500gP Firmware Discussion
    Last Post: 13-05-2016, 04:55
  2. Oleg firmware not working.
    By wpte in forum WL-500gP Q&A
    Last Post: 07-01-2008, 12:48
  3. Oleg Firmware: Please a GUI for SAMBA
    By grumpa in forum WL-HDD Custom Development
    Last Post: 15-09-2005, 14:03
  4. Replies: 5
    Last Post: 03-09-2005, 16:05
    Last Post: 21-10-2004, 14:55
