Hi all,
For the last couple of days I've been going completely crazy.
UPNP just doesn't work under Vista Ultimate X64..
I've tried disabling ipv6, didn't work.
Tried original Asus firmware, didn't work.
Tried disabling and enabling a lot of services, didn't work.
I also did the Internet Connectivity Evaluation Tool The strange thing is, sometime it passes the upnp test (it doesn't work though). Sometimes it doesn't pass the test. It never passes the NAT test though (Is this normal for WL-500g deluxe routers?). Even in XP it doesn't pass this part of the test...?
UPNP works perfect in XP btw. But in Vista it just doesn't seem to work.
I have upnptester.exe. It shows all details of the router in XP, but in Vista it says no upnp device found.
MSN the same.. In XP it says "connected through a UPNP port restricted NAT" , in Vista it says "connected through a non-UPNP restricted NAT"
I've been searching on Google for days and I just couldn't find a solution.
Is the WL-500g Deluxe not compatible with Vista x64, or is it a setting on the router? (Did the factory reset)
Is there anyone that has upnp working under Vista Ultimate x64? Could you please let me know how you did that before I throw my PC out the window? :P.
