Hi
I dont use upnp so i habe none of this leftover rules, but i read asus now saves upnp into nvram for next boot. Possible that they dont remove this if you deactivate upnp from the Web (Oleg ?
I think, you can a: Reset to defaults and set it up again, b: use new 1.9.2.7-1 custom FW and delete the nvram parameters by hand.
I looked into my nv space.
do a
nvram show | grep vts_
on the telnet console, this should show you all saved routing rules, for me my self defindet, and hopefully also your upnp-addet ones. you can then carefully delete all entrys which have the number of the rule you want to remove, eg. all which ends with "X3" (use the number here you want).
Example:
vts_port_x0=49152
vts_protono_x0=
vts_desc_x0=Bittorrent
vts_proto_x0=BOTH
vts_ipaddr_x0=192.168.1.10
See nvram commands how to do this.
Greets
