httр://www.asus.com/Networks/Wireless_Routers/RTAC66U/#downloadAsus AC66U Firmware Version 3.0.0.4.246
httр://dlcdnet.asus.com/pub/ASUS/wireless/RT-AC66U/FW_RT_AC66U_3004246.zip
File Size 22,22 (MBytes) 2012.10.17 update
Fix:
- 1. DMZ and HW accelerator coexist issue.
- 2. Some 3G modem issues
- 3. Can't reset to default through Software Button when AiCloud is enabled.
- 4. WPS related issues.
- 5. VPN dns issue in Android/iOS
- 6. Guest network cannot get an IP address in AP mode.
- 7. Buffer overrun problem. Special thanks to Merlin for his contribution.
Modify:
- 1. Add enhanced interference management option for 2.4GHz
in Advanced settings->wireless-> Professional- 2. Add GRO option in Advanced settings->LAN->Switch control.
Please disable it if there are problems in UPnP and port forwarding.- 3. Add firmware version checking in Quick Internet Setup process.
- 4. Wireless is configurable in media bridge mode
- 5. Add PIN code error alerting for USB modem
- 6. WPS button can be configured as wifi on/off button
AiCoud: (for more information, please refer to http://event.asus.com/2012/nw/aicloud/index.htm)
- 1. Modify web user interface.
- 2. Folder is shareable with shared link.
- 3. The media files can be previewed when received the share link for folder.
- 4. Redirect mp3 https share link to MP3 player on IOS device.
- 5. Fixed the large file renaming problem
- 6. Fixed some UI issues.
http://forum.asus.ru/viewtopic.php?f=4&t=44107Новая тестовая прошивка для Asus RT-AC66U:
httр://www.asus.ru/ftp/NW_TO_TEST/RT-AC66U_3.0.0.4_235.trx
- - Переназначение кнопки WPS на включение/отключение радиочасти.
- - Пункт Disable GRO в настройках свитча.
