Добавлена поддержка LTE и RNDIS девайсов для Asus RT-N56U:
linux kernel: upstream patches for rndis_host,cdc_ether,usbnet
rc: LTE rework code for support any RNDIS modems
remove depricated madwimax
rc: LTE 4G implementation
При этом убрана поддержка WIMAX модемов
http://code.google.com/p/rt-n56u/source/list
Yota One LU150 LTE
Jan 1 00:00:12 kernel: eth3: ===> VirtualIF_open
Jan 1 00:00:12 dhcp client: starting wan dhcp (eth3) ...
Jan 1 00:00:12 RT-N56U: wan down (eth3)
Jan 1 00:00:12 kernel: Initializing USB Mass Storage driver...
Jan 1 00:00:12 kernel: usbcore: registered new interface driver usb-storage
Jan 1 00:00:12 kernel: USB Mass Storage support registered.
Jan 1 00:00:12 dhcp client: deconfig: lease is lost
Jan 1 00:00:13 kernel: usbcore: registered new interface driver cdc_ether
Jan 1 00:00:13 kernel: eth0: register 'rndis_host' at usb-rt3xxx-2, RNDIS device, 00:09:3b:f0:1a:40
Jan 1 00:00:13 kernel: usbcore: registered new interface driver rndis_host
Jan 1 00:00:18 usb modem hotplug: try autorun modem wan connection...
Jan 1 00:00:18 stop_wan(): raise DHCP release event
Jan 1 00:00:19 kernel: eth3: ===> VirtualIF_close
Jan 1 00:00:19 kernel: eth3: ===> VirtualIF_open
Jan 1 00:00:19 dhcp client: starting wan dhcp (eth0) ...
Jan 1 00:00:19 RT-N56U: wan down (eth0)
Jan 1 00:00:19 dnsmasq[379]: read /etc/hosts - 4 address
Jan 1 00:00:19 dnsmasq[379]: read /etc/storage/hosts - 0 addresses
Jan 1 00:00:19 dnsmasq[379]: using nameserver 8.8.8.8#53
Jan 1 00:00:19 dhcp client: deconfig: lease is lost
Jan 1 00:00:19 RT-N56U: wan up (eth0)
Jan 1 00:00:19 dnsmasq[379]: read /etc/hosts - 4 addresses
Jan 1 00:00:19 dnsmasq[379]: using nameserver 10.0.0.1#53
Jan 1 00:00:19 RT-N56U: Hardware NAT: Enabled, IPv4/PPPoE offload [WAN]<->[LAN]
Jan 1 00:00:19 RT-N56U: Software FastNAT: Disabled
Jan 1 00:00:19 dhcp client: bound (eth0), IP: 10.0.0.10, GW: 10.0.0.1, lease time: 300
May 29 12:41:31 ntp client: time is synchronized to pool.ntp.org
http://forum.ixbt.com/topic.cgi?id=14:56853-134
