Hi
I update while ago to latest transmission 2.42 and it stop working. Here is my syslog part when i start transmission daemon. I try to run same torrent on desktop machine and it works, so it's not ISP fault.
Have no ideas what to do...
tnx.Code:Feb 14 08:14:56 transmission-daemon[2636]: Blocklist "level1.bin" updated with 224596 entries (blocklist.c:420) Feb 14 08:14:56 transmission-daemon[2636]: Blocklist "level1.bin" contains 224596 entries (blocklist.c:115) Feb 14 08:14:56 transmission-daemon[2636]: Transmission 2.42 (13013) started (session.c:718) Feb 14 08:14:56 transmission-daemon[2636]: RPC Server Adding address to whitelist: 127.0.0.* (rpc-server.c:803) Feb 14 08:14:56 transmission-daemon[2636]: RPC Server Adding address to whitelist: 10.*.*.* (rpc-server.c:803) Feb 14 08:14:56 transmission-daemon[2636]: RPC Server Adding address to whitelist: 192.168.*.* (rpc-server.c:803) Feb 14 08:14:56 transmission-daemon[2636]: RPC Server Serving RPC and Web requests on port 127.0.0.1:9091/transmission/ (rpc-server.c:997) Feb 14 08:14:56 transmission-daemon[2636]: RPC Server Whitelist enabled (rpc-server.c:1001) Feb 14 08:14:56 transmission-daemon[2636]: Couldn't bind port 51413 on fe80::: Cannot assign requested address (net.c:365) Feb 14 08:14:56 transmission-daemon[2636]: Port Forwarding Stopped (port-forwarding.c:181) Feb 14 08:14:56 transmission-daemon[2636]: DHT Generating new id (tr-dht.c:309) Feb 14 08:14:56 transmission-daemon[2636]: Using settings from "/tmp/mnt/disc0_3/transmission/config" (daemon.c:488) Feb 14 08:14:56 transmission-daemon[2636]: Saved "/tmp/mnt/disc0_3/transmission/config/settings.json" (bencode.c:1721) Feb 14 08:14:57 transmission-daemon[2636]: Loaded 1 torrents (session.c:1937) Feb 14 08:14:59 transmission-daemon[2636]: Monte.Carlo.2011.SLOSubs.DVDRip.XviD-DrSi Could not connect to tracker (announcer.c:990) Feb 14 08:14:59 transmission-daemon[2636]: Monte.Carlo.2011.SLOSubs.DVDRip.XviD-DrSi Retrying announce in 307 seconds. (announcer.c:999)
