Page 3 of 11 FirstFirst 12345 ... LastLast
Results 31 to 45 of 164
Thread: LTE от 4G Мегафон/MTC/Yota (Huawei E392/E398) на роутере Asus
    не работает модем e392 на rt-n16. делал по инструкции от 1fel
    Коллеги,
    выручайте. Все делал по инструкции со скриншотами от 1fel. Рутер rt-n16, прошивка 4251.
    Модем уже активтированный - выходил в Инет с компа.
    Рутер модем видит, но не запускается. В лог пишет следующее:
    Jan  1 03:00:02 kernel: TCP established hash table entries: 4096 (order: 3, 32768 bytes)
    Jan  1 03:00:02 kernel: TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
    Jan  1 03:00:02 kernel: TCP: Hash tables configured (established 4096 bind 4096)
    Jan  1 03:00:02 dropbear[226]: Running in background
    Jan  1 03:00:03 dnsmasq[233]: started, version 2.61 cachesize 512
    Jan  1 03:00:03 dnsmasq[233]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-scripts no-TFTP no-conntrack
    Jan  1 03:00:03 dnsmasq-dhcp[233]: DHCP, IP range 192.168.1.101 -- 192.168.1.254, lease time 1d
    Jan  1 03:00:03 dnsmasq[233]: read /etc/hosts - 3 addresses
    Jan  1 03:00:03 dnsmasq-dhcp[233]: read /etc/ethers - 1 addresses
    Jan  1 03:00:03 miniupnpd[234]: version 1.6 started
    Jan  1 03:00:03 miniupnpd[234]: HTTP listening on port 60563
    Jan  1 03:00:03 miniupnpd[234]: Listening for NAT-PMP traffic on port 5351
    Jan  1 03:00:03 kernel: usbcore: registered new interface driver usbfs
    Jan  1 03:00:03 kernel: usbcore: registered new interface driver hub
    Jan  1 03:00:03 kernel: usbcore: registered new device driver usb
    Jan  1 03:00:03 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    Jan  1 03:00:03 kernel: USB20H mdio control register : 0x80000018
    Jan  1 03:00:03 kernel: ehci_hcd 0000:00:04.1: EHCI Host Controller
    Jan  1 03:00:03 kernel: ehci_hcd 0000:00:04.1: new USB bus registered, assigned bus number 1
    Jan  1 03:00:03 kernel: ehci_hcd 0000:00:04.1: irq 5, io mem 0x18004000
    Jan  1 03:00:03 kernel: ehci_hcd 0000:00:04.1: USB 0.0 started, EHCI 1.00
    Jan  1 03:00:03 kernel: usb usb1: configuration #1 chosen from 1 choice
    Jan  1 03:00:03 kernel: hub 1-0:1.0: USB hub found
    Jan  1 03:00:03 kernel: hub 1-0:1.0: 2 ports detected
    Jan  1 03:00:03 kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    Jan  1 03:00:03 kernel: ohci_hcd 0000:00:04.0: OHCI Host Controller
    Jan  1 03:00:03 kernel: ohci_hcd 0000:00:04.0: new USB bus registered, assigned bus number 2
    Jan  1 03:00:03 kernel: ohci_hcd 0000:00:04.0: irq 5, io mem 0x18009000
    Jan  1 03:00:03 kernel: usb usb2: configuration #1 chosen from 1 choice
    Jan  1 03:00:03 kernel: hub 2-0:1.0: USB hub found
    Jan  1 03:00:03 kernel: hub 2-0:1.0: 2 ports detected
    Jan  1 03:00:03 kernel: usb 1-1: new high speed USB device using ehci_hcd and address 2
    Jan  1 03:00:04 kernel: usb 1-1: configuration #1 chosen from 1 choice
    Jan  1 03:00:04 kernel: usb 1-2: new high speed USB device using ehci_hcd and address 3
    Jan  1 03:00:04 kernel: usb 1-2: configuration #1 chosen from 1 choice
    Jan  1 03:00:04 kernel: usbcore: registered new interface driver usblp
    Jan  1 03:00:04 kernel: Linux video capture interface: v2.00
    Jan  1 03:00:04 kernel: usbcore: registered new interface driver uvcvideo
    Jan  1 03:00:04 kernel: USB Video Class driver (v0.1.0)
    Jan  1 03:00:05 kernel: usbcore: registered new interface driver cdc_acm
    Jan  1 03:00:05 kernel: drivers/usb/class/cdc-acm.c: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
    Jan  1 03:00:05 kernel: usbcore: registered new interface driver usbserial
    Jan  1 03:00:05 kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for generic
    Jan  1 03:00:05 kernel: usbcore: registered new interface driver usbserial_generic
    Jan  1 03:00:05 kernel: drivers/usb/serial/usb-serial.c: USB Serial Driver core
    Jan  1 03:00:05 kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for GSM modem (1-port)
    Jan  1 03:00:05 kernel: usbcore: registered new interface driver option
    Jan  1 03:00:05 kernel: drivers/usb/serial/option.c: USB Driver for GSM modems: v0.7.2
    Jan  1 03:00:05 admin: modem with dataport: 2.0 not found
    Jan  1 03:00:06 WAN port: cable disconnected
    Jan  1 03:00:15 admin: modem with dataport: 2.0 not found
    Jan  1 03:00:15 dnsmasq-dhcp[233]: DHCPREQUEST(br0) 192.168.1.207 00:e0:4c:03:a0:a8
    Jan  1 03:00:15 dnsmasq-dhcp[233]: DHCPACK(br0) 192.168.1.207 00:e0:4c:03:a0:a8 ANNA-PC
    Jan  1 03:00:18 dnsmasq-dhcp[233]: DHCPINFORM(br0) 192.168.1.207 00:e0:4c:03:a0:a8
    Jan  1 03:00:18 dnsmasq-dhcp[233]: DHCPACK(br0) 192.168.1.207 00:e0:4c:03:a0:a8 ANNA-PC
    Jan  1 03:00:25 admin: modem with dataport: 2.0 not found
    пугает вот это - modem with dataport: 2.0 not found
    И еще момент - удалось ли кому-то в итоге запустить модем в режиме 4G??
    Где-то читал, что этот модем использует проприетарный режим команд QMI, а в режиме совместимости с AT командами работает только в режиме 3G
    Надо вставить модем в порт до конца, потому-что e392 толстый и упирается в крышку. Или использовать USB-удлинитель.
    Huawei E392
    Quote Originally Posted by dimez View Post
    У меня на rt-n16 4G Мегафон нормально заработал с прошивкой http://asus.vectormm.net/rtn/4177/RT...-rtn-r4177.trx и с использованием USB-удлинителя 10см.
    Рутер модем видит, но не запускается. В лог пишет следующее:.
    Можно попробовать запустить вручную:
    usb_modeswitch версии 1.2.3
    usb_modeswitch -v 0x12d1 -p 0x14fe -V 0x12d1 -P 0x1506 -M "55534243123456780000000000000011062000000100000000000000000000"
    echo "12d1 1506" > /sys/bus/usb-serial/drivers/option1/new_id
    На OpenWrt r31761 без костылей заводиться
    http://www.gsmforum.su/showthread.php?t=85028&page=3
    Вот ещё AT-команды для модемов Huawei:
    Полезные команды:
    ATI – вывод информации о модеме
    AT^HSPA=1 и AT^HSUPA=0 – команды улучшения стабильности связи
    AT+CFUN=1 – перезагрузка модема с перерегистрацией в сети GSM оператора без необходимости
    «передергивать» 3G USB модем (перезапуск всего GSM стека – полный программный сброс)
    Включение / отключение режимов 2G и 3G:
    AT^SYSCFG=13,1,3fffffff,0,0 – режим только 2G
    AT^SYSCFG=2,1,3fffffff,0,0 – режим предпочтительно 2G
    AT^SYSCFG=14,2,3fffffff,0,1 – режим только 3G
    AT^SYSCFG=2,2,3fffffff,0,1 – режим предпочтительно 3G
    AT^SYSCFG=2,2,3fffff ff,0,2 – режим включение 2G и 3G
    Включение / отключение режимов WCDMA, HSDPA, HSPA+, HSPA:
    AT^HSDPA=1 – режим HSDPA включен
    AT^HSDPA=0 – режим HSDPA выключен
    AT^HSUPA=1 – режим HSUPA включен
    AT^HSUPA=0 – режим HSUPA выключен
    AT^HSPA=0 – режим WCDMA
    AT^HSPA=1 – режим HSDPA
    AT^HSPA=2 – режим HSPA
    AT^HSPA=3 – режим HSPA+
    AT^SYSCFG=13,1,3FFFFFFF,2,4 – режим только GPRS/EDGE
    AT^SYSCFG=14,2,3FFFFFFF,2,4 – режим только 3G/WCDMA
    AT^SYSCFG=2,1,3FFFFFFF,2,4 – режим предпочтительно GPRS/EDGE
    AT^SYSCFG=2,2,3FFFFFFF,2,4 – режим предпочтительно 3G/WCDMA
    AT-команды модемов Huawei E367, E352, E353, E171:
    AT^SETPORT? – вывод на экран текущей конфигурации
    AT^GETPORTMODE - вывод на экран активного режима в настоящее время
    AT^SETPORT = "A1, A2, 1,2,3,7, A1, A2" – установка конфигурации по умолчанию
    AT^SETPORT="A1,A2;1,2,3" - устройство в режиме Modem (работает быстрее и стабильнее)
    AT^SETPORT = "A1, A2, 1,2,3,7" - устройство в режиме Modem + Network Card
    AT^SETPORT="A1,A2;1,2,3,A2" - устройство в режиме Modem + Card Reader
    AT^SETPORT = "A1, 2,7" - устройство в режиме Network Card + CD-ROM
    AT^SETPORT = "A1, A2, 2,7" - устройство в режиме Network Card
    AT^SETPORT = "A1, A2, 1,2,3,7, A1, A2, 4,5,6, A, B, D, E" - сброс настроек по умолчанию
    http://3g-huawei.clan.su/publ/help_i...uawei/2-1-0-10
    Вполне возможно, что драйверы в цепочке usbserial-option-pppd менее эффективны, чем usbnet-rndis. Но чем посмотреть и проверить - не скажу. Проще всего попробовать переключить этот модем для работы с rndis и проверить.
    Вот, что пишут разработчики прошивки для Zyxel Keenetic по этому поводу:
    ...этот модем работает в режиме как обычный 3G, поддержка в режиме NDIS Ethernet в V.1 не предусматривалась, и скорее всего не будет. ... Разница в том, что через PPP режим максимальная скорость упрется в производительность процессора и USB, скорость будет почти в трое меньше, чем если бы использовался режим NDIS Ethernet, предположительно, в режиме PPP максимальная скорость до 20Мбит, в режиме NDIS Ethernet до 60Мбит. Естественно, даже 20Мбит для многих будет не достижимо, в среднем будет 10-12Мбит на прием и 5-10Мбит на отдачу, как только Мегафон закончит тестирование, ну, а пока, в некоторых местах скорость на прием достигает 70Мбит, что уже не реально прокачать по USB, однако в случае с PPP эта скорость обрежется до 20Мбит, а в случае с NDIS Ethernet до 50-60Мбит, .... Сложность заключается в том, что для работы NDIS Ethernet требуется специальная активация через закрытый QMI протокол, но пока, сколько не бились с этим, мегафоновский E392 на отрез отказывается работать в этом режиме.
    Источник
    Quote Originally Posted by Rusink View Post
    Под скоростью по USB и проца они насколько можно понять опираются на то железо которое в кинетиках стоит, ибо с более современным железом и полноценным USB эти скорости при "идеальных" условиях вполне достижимы.
    Asus RT-N56U firmware: RT-N56U 3.4.3.7-072 DLNA build
    Asus RT-N12U firmware: 1.9.2.7-rtn-r4454
    Asus RT-N65U firmware: RT-N65U 3.0.3.7-072
    Quote Originally Posted by airwalk View Post
    Коллеги, выручайте. Все делал по инструкции со скриншотами от 1fel. Рутер rt-n16, прошивка 4251.
    Модем уже активтированный - выходил в Инет с компа. Рутер модем видит, но не запускается. В лог пишет следующее:
    Нашел команду: AT^SETPORT="A1,A2;1,2,3,A2" переводит в режим модема. По умолчанию стояло A1;1,2,3,7,A1,A2
    А когда задал AT^SETPORT="A1,A2;1,2,3,7,A1,A2,4,5,6,A,B,D,E" появилось в диапазоне LTE_B38_2600 строка.
    E392 перевел в режим модема (команда AT^SETPORT="A1,A2;1,2,3,A2")
    В роутере прописал APN Internet и номер набора *99#
    Еще в настройках указал тип WAN -Usb модем
    http://forum.ixbt.com/topic.cgi?id=16:42970-2
    # lsusb
    Bus 002 Device 005: ID 12d1:1506 Huawei Technologies Co., Ltd.
    # lsmod
    Module                  Size  Used by
    hw_cdc_driver          27959  0
    mii                     3343  1 hw_cdc_driver
    option                 13394  2
    usb_wwan                7667  1 option
    usbserial              26259  6 option,usb_wwan
    # usb-devices
    T:  Bus=02 Lev=02 Prnt=02 Port=01 Cnt=01 Dev#=  5 Spd=480 MxCh= 0
    D:  Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
    P:  Vendor=12d1 ProdID=1506 Rev=00.00
    S:  Manufacturer=Huawei Technologies
    S:  Product=HUAWEI Mobile
    C:  #Ifs= 7 Cfg#= 1 Atr=c0 MxPwr=500mA
    I:  If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=01 Prot=01 Driver=option
    I:  If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=01 Prot=02 Driver=option
    I:  If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=01 Prot=03 Driver=option
    I:  If#= 3 Alt= 0 #EPs= 1 Cls=ff(vend.) Sub=01 Prot=09 Driver=huawei_ether
    I:  If#= 4 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=01 Prot=08 Driver=huawei_ether
    I:  If#= 5 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
    I:  If#= 6 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
    # dmesg
    usb 2-1.2: new high speed USB device number 4 using ehci_hcd
    usb 2-1.2: New USB device found, idVendor=12d1, idProduct=1505
    usb 2-1.2: New USB device strings: Mfr=3, Product=2, SerialNumber=0
    usb 2-1.2: Product: HUAWEI Mobile
    usb 2-1.2: Manufacturer: Huawei Technologies
    scsi10 : usb-storage 2-1.2:1.0
    scsi 10:0:0:0: CD-ROM            HUAWEI   Mass Storage     2.31 PQ: 0 ANSI: 0
    sr1: scsi-1 drive
    sr 10:0:0:0: Attached scsi CD-ROM sr1
    sr 10:0:0:0: Attached scsi generic sg2 type 5
    usb 2-1.2: USB disconnect, device number 4
    usb 2-1.2: new high speed USB device number 5 using ehci_hcd
    usb 2-1.2: New USB device found, idVendor=12d1, idProduct=1506
    usb 2-1.2: New USB device strings: Mfr=4, Product=3, SerialNumber=0
    scsi11 : usb-storage 2-1.2:1.5
    scsi12 : usb-storage 2-1.2:1.6
    usbserial: USB Serial Driver core
    option 2-1.2:1.0: GSM modem (1-port) converter detected
    usb 2-1.2: GSM modem (1-port) converter now attached to ttyUSB0
    option: v0.7.2:USB Driver for GSM modems
    usbcore: registered new interface driver huawei_ether
    scsi 11:0:0:0: CD-ROM            HUAWEI   Mass Storage     2.31 PQ: 0 ANSI: 0
    scsi 12:0:0:0: Direct-Access     HUAWEI   SD Storage       2.31 PQ: 0 ANSI: 2
    sd 12:0:0:0: Attached scsi generic sg2 type 0
    sd 12:0:0:0: [sdb] Attached SCSI removable disk
    sr1: scsi-1 drive
    sr 11:0:0:0: Attached scsi CD-ROM sr1
    sr 11:0:0:0: Attached scsi generic sg3 type 5
    option 2-1.2:1.1: GSM modem (1-port) converter detected
    usb 2-1.2: GSM modem (1-port) converter now attached to ttyUSB1
    option 2-1.2:1.2: GSM modem (1-port) converter detected
    usb 2-1.2: GSM modem (1-port) converter now attached to ttyUSB2
    http://habrahabr.ru/post/144239/
    Huawei E392
    Quote Originally Posted by McMCC
    Небольшие комментарии и добавления по работе LTE модема Huawei E392 от Мегафона:
    1. Если вы хотите включить режим "LTE Only", отключив все остальные, необходимо в настройках роутера ввести вот такую AT-команду:
    AT^SYSCFGEX="03",3fffffff,2,4,7fffffffffffffff,,
    в конце две запятые обязательны, в этой команде первое значение расшифровывается так:
    00 - Автоматический режим, стоит по умолчанию(приоритеты в порядке очереди - 4G->3G->2G)
    01 - GSM GPRS(2G)
    02 - WCDMA(3G)
    03 - LTE(4G)
    99 - Оставить текущие настройки без изменений
    можно набрать свою последовательность приоритетов в порядке убывания, например:
    AT^SYSCFGEX="0302",3fffffff,2,4,7fffffffffffffff,,
    в этом случае модем будет пытаться в начале подключиться к сети LTE, затем к 3G, исключая работу в 2G, если набрать например так:
    AT^SYSCFGEX="030201",3fffffff,2,4,7fffffffffffffff ,,
    то это будет эквивалентно
    AT^SYSCFGEX="00",3fffffff,2,4,7fffffffffffffff,,
    2. второе значение 3fffffff - частоты GPS и UMTS, в данном случае выбраны все диапазоны этих частот, это значение стоит по умолчанию,
    если хотите сделать свою комбинацию, используйте логическое "ИЛИ" для их набора(представлены не все значения):
    00080000 - GSM 850
    00000080 - GSM системы DCS 1800
    00000100 - Расширенный GSM 900
    00000200 - Стандартный GSM 900
    00100000 - Железнодорожный GSM 900
    00200000 - GSM PCS 1900
    00400000 - IMT-2000, WCDMA
    00800000 - WCDMA II PCS 1900
    04000000 - WCDMA 850 V
    40000000 - Оставить текущие настройки без изменений
    3. третье значение 2 - настройки роуминга:
    0 - роуминг выключен
    1 - роуминг включен
    2 - Оставить текущие настройки без изменений
    по умолчанию там стоит 1, роуминг включен
    4. четвертое значение 4 - сервисы:
    0 - только SMS и голос
    1 - только передача данных
    2 - SMS, голос и передача данных
    4 - Оставить текущие настройки без изменений
    по умолчанию там стоит 2 - включены все сервисы
    5. пятое значение 7fffffffffffffff - частоты LTE, в данном случае выбраны все частоты, если хотите сделать
    свою комбинацию, используйте логическое "ИЛИ" для их набора (представлены не все значения):
    00000000040 - LTE BC7
    00000002000 - LTE ВС13
    00000020000 - LTE BC17
    10000000000 - LTE BC40
    последние два значения, указанные пустыми через запятую, являются резервными и не используются.
    Вы можете посмотреть эти значения в своем модеме, если подключите его к компьютеру и наберете в терминале следующие команды:
    AT^SYSCFGEX?
    или более детальный с расшифровкой частот
    AT^SYSCFGEX=?
    http://forum.ixbt.com/topic.cgi?id=14:55989-152#4762
    Jan 2011
    Нижний Новгород
    [CODE]# lsusb
    # lsmod
    Module Size Used by
    option 13394 2
    # usb-devices
    Надо понимать, что красное уже появилось на ББ? Что это была за система? Хочу такой же дайвер в прошивку!
    Nov 2006
    Это очередной велосипед, краткое обсуждение было на http://www.draisberghof.de/usb_modes...opic.php?t=734
    По любому, придётся ждать пока девайс попадёт в руки квалифицированного человека и он просниффит последовательность usb_control_msg для переключения в режим NDIS.
    E392 & NDIS Ethernet
    Ну вроде уже сам McMCC написал утилиту для переключения модема в режим NDIS ...
    На Asus rt-n56u с альтернативной прошивкой работает как простой 3G модем. (Заранее на компьютере выбрал режим работы LTE-only)
    Это всего лишь метод подключения, внутри модема встроен PPP RAS сервер, который активируется при обращении к нему через порт модема, это самый простой способ подключения к любому роутеру, планшетнику или компьютеру, предусмотрели, так сказать, на все случаи жизни, но у этого способа есть и недостаток, ограничение по скорости, у данного модема она не превышает 20-25Мбит, слишком высокая нагрузка возникает на процессоре при обработке PPP протокола, поэтому скорости ограничили до этих значений, что бы модем мог справляться с другими задачами, которые крутятся у него внутри. Второй метод подключения, NDIS Ethernet, на этом способе подключения модем может обеспечить скорость до 100Мбит, но главный недостаток в том, что для его активации требуется специальная утилита, которая умеет общаться с модемом по QMI протоколу, протокол закрытый, а в случае с Huawei, есть еще и Vendor Specific дополнения, по которым нет ни какой документации, тем не менее, мне удалось проанализировать этот протокол и написать утилиту на коленке, которая подключает модем к сети и активирует работу NDIS, неудобство пока этого метода вижу в одном, нужно периодически проверять состояние подключения, и в случае обрыва соединения, восстанавливать его вручную вместе с запуском DHCP клиента, по сути, необходим специальный демон, который все это будет делать автоматически, с учетом того, что интерфейс для QMI протокола очень капризный, может подвиснуть в любой момент, то первый способ через PPP RAS, для роутеров, является самым оптимальным и надежным на сегодняшний день.
    http://forum.ixbt.com/topic.cgi?id=16:42970-5#146
    Quote Originally Posted by vvevvevve
    Есть другая проблема: протокол QMI. Это такой специальный протокол Qualcomm, альтернативный системе AT-команд. Я сам на практике не сталкивался с такой бедой, но читал несколько сообщений о попадающихся, в последнее время, версиях модемов с QMI. Да вот, например (в тему), здесь предлагается две версии MC7710 - одна нормальная, вторая с QMI. Главная особенность таких модемов состоит в том, что (по-простому) они совсем не работают без драйвера. Я не имею в виду, конечно, стандартные драйверы USB-COM, которые необходимы для работы с любым USB-модемом. Здесь драйвер выполняет функцию транслятора AT-команд, с помощью которых привычные нам программы или компоненты ОС общаются с модемом, в команды QMI. Это очень неудобно в плане совместимости с разными ОС и диагностики, из-за такой "привязки" к драйверу. Где-то читал о том, что, на самом деле, полноценный AT-интерпретатор в любой QMI-прошивке есть, и AT-режим можно включить с помощью специальной QMI-команды, после чего модем так в этом режиме и останется. Или, в другом варианте, этот интерпретатор подгружается в модем в виде куска прошивки. Подробностей пока не знаю, к сожалению.
    http://forum.ixbt.com/topic.cgi?id=17:45949-20#517
    как мне узнать характеристику сигнала на модеме мегафона huawei e392
    К сожалению, в модемах Huawei нет команды, аналогичной обсуждаемой в Sierra,
    поэтому информацию можно получить только по частям:
    1. AT+CSQ выдаёт два числа, первое из которых отражает RSSI следующим образом:
    0 -> -113 dBm или меньше;
    1 -> -111 dBm ;
    2...30 -> -109...-53 dBm (2 dBm на единицу);
    31 -> -51 dBm или больше.
    То есть, например, число 14 соответствует RSSI = -85 dBm. Кстати, это значение, уже
    в dBm, отображается в поле RSSI в меню Diagnostics/Network Status Mobile Partner_а.
    2. AT^LTERSRP? выдаёт два числа:
    первое - RSRP в dBm
    второе - RSRQ в dB
    3. AT^LTESCINFO? выдаёт 4 числа, второе из которых каким-то образом
    отражает SINR, предположительно, в виде 5 битов со знаком:
    0...15 -> SINR = 0...15
    16...31 -> SINR= -15...-1
    Четвёртое число, кстати, похоже на ширину полосы сети, выраженную в КГц.
    http://forum.ixbt.com/topic.cgi?id=17:45949-17#442
    На всякий случай результаты:
    Huawei E392:
    E392
    +csq: 25,99
    ^LTERSRP:-91,-8
    ^LTESCINFO:31,8,2,15000
    Sierra MC7710:
    at!gstatus?
    !GSTATUS:
    Current Time:  70               Temperature: 40
    Bootup Time:   1                Mode:        ONLINE
    System mode:   LTE              PS state:    Attached
    LTE band:      B7               LTE bw:      15 MHz
    LTE Rx chan:   2825             LTE Tx chan: 20825
    EMM state:     Registered       Normal Service
    EMM connection:RRC Connected
    RSSI (dBm):    -83              Tx Power:    6
    RSRP (dBm):    -106             TAC:         770A (30474)
    RSRQ (dB):     -7               Cell ID:     0F1E6701 (253650689)
    SINR (dB):      2.8
    OK
    А если хуавеевские драйвера посмотреть? Патч и линк в аттаче.
    Nov 2006
    Не имея модема в руках могу только констатировать факт, что в родном комплекте для переключения в NDIS режим прилагается блоб HWActivator под x86. Как здесь - не знаю.
    ИМХО, для работы с роутером это (переключение в NDIS) - не самое страшное. Можно переключить и ручками командой
    AT^SETPORT="A1,A2;2,7"
    Но, вы правы - без модема теоретизировать бессмысленно. Тот, с которым я экспериментировал дать сейчас не могу - перестал включаться из-за проблем с неправильным напряжением. После общения с Сервисом Мегафона смогу предложить
    Может вот это поможет: Wireshark Dissector for QMI protocol
    Here is the Wireshark dissecctor for QMI (Qualcomm MSM Interface) USB protocol. It allows to monitor QMI requests,
    indications and responses regardless of communication method (cdc-wdm, gobi driver (qcqmi) or VM passthrough):
    services = { [0] = "Control", [1] = "WDS", [2] = "DMS", [3] = "NAS",
    [4] = "QOS", [5] = "WMS", [6] = "PDS", [7] = "AUTH", [8] = "AT",
    [9] = "VOICE", [10] = "CAT2", [11] = "UIM", [12] = "PBM",
    [14] = "RMTFS", [16] = "LOC", [17] = "SAR", [20] = "CSD", [21] = "EFS",
    [23] = "TS", [24] = "TMD", [224] = "CAT", [225] = "RMS", [226] = "OMA" }
    ctl_messages = { [0x21] = "Get Version Info", [0x22] = "Get Client ID",
    [0x23] = "Release Client ID" }
    wds_messages = { [0x01] = "Set Event Report", [0x20] = "Start Network Interface",
    [0x22] = "Get Packet Service Status", [0x23] = "Get Channel Rates",
    [0x4d] = "Set IP Family Preference" }
    dms_messages = { [0x1] = "Set Event Report", [0x20] = "Get Device Capabilities",
    [0x21] = "Get Device Manfacturer", [0x22] = "Get Device Model",
    [0x23] = "Get Device Revision", [0x24] = "Get Device Voice Number",
    [0x25] = "Get Device Serial Numbers", [0x26] = "Get Power State" }
    nas_messages = { [0x2] = "Set Event Report", [0x20] = "Get Signal Strength",
    [0x24] = "Get Serving System", [0x25] = "Get Home Network" }
    qmi_proto = Proto("qmi", "Quallcomm MSM Interface")
    huawie e392 megafon
    У меня вроде получилось запустить модем в режиме LTE, в настройках WAN я указал usb_modem, далее настройки как для стандартного 3g модема, правда я еще добавил команду:
    не знаю на сколько сильно она помогла, но вроде скорость неплохая. Вгетом попробовал скачать дистрибутив федоры, пиковая скорость была 16 Мбит/сек. Хотя не могу отрицать, что модем при этом не мог коннектиться через 3г.
  1. Replies: 400
    Last Post: 24-09-2019, 07:29
  2. LTE от 4G Мегафон/Yota на Huawei E3276 (M150-1)/Quanta Yota EA423 (M100-1)
    Last Post: 22-02-2016, 11:50
  3. Проблема с Huawei E392 от Мегафон/МТС/Yota на роутере Asus
    By bagira in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 05-11-2013, 12:29
  4. WiMax Yota + Comstar (SWC-U200/BCS200) на роутере Asus
    By Frogy_f in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 25-05-2012, 10:13
