Originally Posted by sir_lunatic
Could you please try :
http://www.ruc.pt/~seabra/WL500g-1.9.2.7-6b.trx
pwcx module is not included but you can try Toms or mine included in previous firmware
Thanks
Ive sent the patches for Oleg.Theyre not final and for now they only support pwc web cameras.Support for omnivision will be added later.
If anyone wants to test them take a look at:
http://www.ruc.pt/~seabra/wl-500-pwc...-patch.tar.bz2
To save usb bw compression is set to 2.This makes the image a little bit worse than already is but you can change this by hand in services_ex.c
Kind Regards,
João Seabra
Asus Wl500g + Homebrew bi-quad antenna + 80 G 3.5" seagate H.D + Philips ToUCam II - 1.9.2.7-6b-seabra
Thanks
It would be cool if you could add Pan and Tilt to the interface.
Nice work you did jseabra!!!
I would very much like to test the newer pwc on my WL-500gx. Is it hard to upgrade the driver in Olegs 6b-image? Could this be done via telnet on a live router?
I've been struggling a couple of days now with a Logitech QuickCam Pro 5000 - no luck so far. My last (and only hope) now is the pwc 9.0.2. Perhaps someone know about other possibilities?
The ActiveX responds "couldn't connect to server", status LED is dark, camera is proved to be working on a PC and my System Log says:
Jan 1 01:01:05 USB webcam: attached
Jan 1 01:01:11 kernel: pwc Philips PCA645/646 + PCVC675/680/690 + PCVC730/740/750 webcam module version 8.12 loaded.
Jan 1 01:01:11 kernel: pwc Also supports the Askey VC010, various Logitech Quickcams, Samsung MPC-C10 and MPC-C30,
Jan 1 01:01:11 kernel: pwc the Creative WebCam 5, SOTEC Afina Eye and Visionite VCS-UC300 and VCS-UM100.
Jan 1 01:01:11 kernel: usb.c: registered new driver Philips webcam
I'd be grateful for any kind of help and advice.
Merry Christmas to everybody!
I've tested you're firmware : it works great with my Philipps camera. However, like in Oleg's firmware i'm getting a mirrored image...
I also had some trouble with some messagebox :
This is what i get after reseting all default settings and restarting the device.
The Struggle Continues...
Hi.
In my latest firmware this issue was corrected.
Are you sure you are using the latest??
Merry Christmas,
Seabra
Thanks!
You can use pwc.o and pwcx.o and insmod them but its not trivial and requires some tricks.
Anyway you wont be able to get 640x480 without using my firmware.
Merry Christmas,
Seabra
Can you compile it for asus deluxe too please and add this patch too http://mxhaard.free.fr/spca50x/Doc/K...6.patch.tar.gz ?
Also i've tryed to use the ovcam module u provide with oleg firmware and i get:
Using ovcamchip[1].o
insmod: unresolved symbol i2c_detach_client
insmod: unresolved symbol i2c_del_driver
insmod: unresolved symbol i2c_smbus_read_byte_data
insmod: unresolved symbol i2c_smbus_write_byte_data
insmod: unresolved symbol i2c_attach_client
insmod: unresolved symbol i2c_add_driver
Hi!Originally Posted by florin_m
I do remember having some problems about a missing i2c module.I will check that.
I cant apply that patch because its for 2.6 kernel while were using 2.4 kernel.
Sorry, this one http://mxhaard.free.fr/spca50x/Doc/K...8.patch.tar.gz
Is the 2.4 kernel.
