Results 16 to 30 of 45
Thread: WL-500g and USB Webcam problems
    What version of firmware did you have before upgrading? Your camera could be OV519(OV51x+) type and it need special version of OV51x driver. Look at http://alpha.dyndns.org/ov511/download.html. In your log for working camera you can see right driver:
    an 1 00:00:12 kernel: ov51x.c: v1.65-1.10-mark : ov51x USB Camera Driver
    Aug 2005
    Eindhoven, The Netherlands
    Using the latest custom firmware by Oleg:
    WITH CAM:
    Download
    1416.3 KByte/sec (=11330 kbps)
    Upload
    842.1 KByte/sec (=6737 kbps)
    This is the output I get when I enter a 'top' command:
    Mem: 28888K used, 1260K free, 0K shrd, 1096K buff, 15884K cached
    Load average: 1.47, 0.64, 0.24 (State: S=sleeping R=running, W=waiting)
    MEM COMMAND
    2335 admin R 1432 93 93.3 4.7 rcamd
    2358 admin R 436 2357 6.9 1.4 top
    2336 admin S 1432 2335 0.0 4.7 rcamd
    2337 admin S 1432 2336 0.0 4.7 rcamd
    131 admin S 680 1 0.0 2.2 nmbd
    133 admin S 576 1 0.0 1.9 smbd
    2348 admin S 496 1 0.0 1.6 upnp
    129 admin S 464 1 0.0 1.5 stupid-ftpd
    104 admin S 432 1 0.0 1.4 watchdog
    2357 admin S 432 2352 0.0 1.4 sh
    2352 admin S 424 1 0.0 1.4 httpd
    71 nobody S 396 1 0.0 1.3 dnsmasq
    2334 admin S 384 1 0.0 1.2 httpd
    1 admin S 324 0 0.0 1.0 init
    93 admin S 320 1 0.0 1.0 rcamdmain
    123 admin S 280 1 0.0 0.9 udhcpc
    72 admin S 248 1 0.0 0.8 syslogd
    107 admin S 216 104 0.0 0.7 ntp
    103 admin S 216 1 0.0 0.7 infosvr
    WITHOUT CAM:
    Download
    2956.2 KByte/sec (=23650 kbps)
    Upload
    1207.5 KByte/sec (=9660 kbps)
    Mem: 26500K used, 3648K free, 0K shrd, 1096K buff, 15868K cached
    Load average: 0.54, 1.01, 0.63 (State: S=sleeping R=running, W=waiting)
    MEM COMMAND
    2375 admin R 436 2374 6.5 1.4 top
    2368 admin S 496 1 0.0 1.6 upnp
    2374 admin S 432 2352 0.0 1.4 sh
    68 admin S 208 1 0.0 0.6 klogd
    91 admin S 200 1 0.0 0.6 waveservermain
    86 admin S 176 1 0.0 0.5 lpd
    88 admin S 168 1 0.0 0.5 p910nd
    Strange or normal?
    Exclamation Stranger acces my webcam. Is this possible?
    Hi
    I use my webcam with DynDNS. It is work perfectly.
    But i see today in the log file the unknow ip adress acces my cam . The unknow ip can acces my webcam? Is it possible?
    I protect my acces with password. A live in Hungary and the unknow ip from New York. How it find my roter/webcam?
    How can i protect my acces ? It's very important for me, i don't want expose my family anybody.
    Firmware: ASUS 1.9.2.7
    Sep 2005
    webcam not working?
    I just connected my webcam and the system log says "USB webcam: attached" but in fact it's not working. What does this message means?
    I'm using the original Asus firmware, version 1.8.2; the webcam is a Samsung SNC-35.
    Thanks in advance,
    MatB
    Apr 2004
    Netherlands
    Well, loads of other ppl are having (or had) problems with their webcam. Search this forum to see if someone has a solution for you.
    Also, try using the latest firmware from Oleg. It has a much more updated webcam driver, so perhaps your camerachip is now supported.
    If using the lastest firmware doesn't help and the search didn't help either, then post a complete system log here and try to find out which chiptype is used in the webcam.
    webcam tcp?
    Can I connect to my webcam attached to my 500gx using tcp?
    Question USB hub (4ports) pb with webcam
    So I plugged a logitech webcam on the USB port wl500gx (in other there is my USB key). I launched the webcam application (by clicking on preview on the web page) and it works fine.
    But when I plug the hub on the USB port and the webcam on the hub, it doesn't work.
    Oh I have to precise you that the hub has an external supply.
    Do I have to add some nodes in the /dev/v4l directory ?
    Do I need an additionnal driver for the hub ?
    Thanks a lot !
    Webcam password and html files
    I'm using oleg's firmware v1.9.2.7-6b.
    When running the webcam I have to give a user and password to connect.
    These are the same as the one for logging in to the webinterface.
    Is it possible to set a different one for the webcam ?
    The other question is. Can I modify the html(asp) pages used for the webcam and use my own ?
    Thanks,
    Gene
    Webcam, USB, Custom firmware
    Hello everyone,
    I'm using Olegs firmware v1.9.2.7-6b.
    I've followed the instructions on this website to get a working build environment. Now I can compile the complete stuff.
    But I want to change the webcam behaviour.
    I wanna use THTTPD as server for the images. Not using the activeX port.
    And not using the default httpd server.
    Where can I find in the source the stuff to change the behaviour when connecting the webcam to the usb bus ???
    How can I force the system to use my rcamd version when testing it on the firmware and plugging in the camera ??
    Gene
    Czech Republic
    Quote Originally Posted by Goetmals
    Thanks a lot !
    It should work fine without any change. Perhaps there's some incompatibility between webcam/hub. Try to reboot the router with connected webcam. Try to unplug/plug in the webcam while the router is running as well and check what's the matter using dmesg.
    Czech Republic
    Quote Originally Posted by gene_klein
    Thanks,
    Gene
    Please use SEARCH function and you should find it.
    generic webcam compatibility
    Hello,
    Anybody tried some generic (cheap) webcam like the below one on the WL-500G Deluxe ?
    http://cgi.ebay.fr/NEUF-INFRAROUGE-c...QQcmdZViewItem
    Many thanks in advance for all your feedback,
    David.
    Webcam Creative Vista
    Hi, I bought the creative Vista cam which was one of two cams that were listed as "tested" in a list of supported cams in users guide. I´ve chosen the right driver in ASUS menu, but the cam still doesnt work. on the website http://192.168.1.1:7776/ShowWebCam.asp you can only see a message that page can´t be displayed. And if I try in asus menu "preview" - there´s just a margin of a picture but no picture or video inside. There´s nothing more to set up but it still doesn´t work. Do I have to do anything else.... Or am I doing anything wrong?????
    Thanx for answer.....
    Exclamation thttpd - a php site with Webcam??
    Hi.
    I have thttpd/2.25b PHP/5.0.4 starting on port 8081 up and running.
    Q: Can I access the webcam via a php file on my thttpd server?
    This line i thought would display the picture, but it does not!
    <img src="../../../www/display.jpg" width="320" height="204">
    What is wrong with this?
  1. wl-500g deluxe problems
    By majx in forum WL-500g Custom Development
    Last Post: 17-08-2006, 17:03
  2. Wl-500G problems
    By MiRaCL in forum WL-500g Q&A
    Last Post: 13-01-2005, 01:08
  3. Connection problems with WL 500g
    By Mr. Orange in forum WL-500g Q&A
    Last Post: 06-01-2005, 10:48
