Page 1 of 3 123 LastLast
Results 1 to 15 of 45
Thread: WL-500g and USB Webcam problems
    Dec 2004
    Frankfurt / Germnay
    Question Webcam with WDS Client
    Hi!
    I´m using ASUS WL500G as Router with PPPOE Access in Hybrid Mode together with my WL-HDD in Hybrid Mode. On the second device i hooked an USB Webcam. This is working fine internally but there is no access from Outside (WAN). The webcam is working with the WL500G (with dyndns access through WAN) but this is at the wrong place.... I´ve already tried to route the port 7776 to the WL-HDD with no success. Has anyone a solution for this wired scenario?
    ciao,
    JBK
    Sense level and Webcam
    i've plugged on my wl500gw a Philips Toucam pro II.
    all works from WAN, i can see image, but when i want to enable the security mode, i receive a lot of mails with pictures when the sense level is Low or medium and no mail if sense level is High !
    Can i modify this value inside a file with telnat command ?
    thanks
    i have modify both pwcx.o and pcw.o and use mvc (see thread 2420)
    now, i don't know how send a email with an image as attach file
    i think it's possible, because the security mode make this !
    Somebody have a solution ?
    i use sendalarm to send a mail, but i search a command to send a file through ftp to an external web site
    Somebody knows the procedure ?
    thanks
    I have WL-500g 1.9.2.7-6b and Lifetec LT9388 USB camera. I found this camera working on router but unfortunetly only twice. After upgrading software it worked but after reseting completly not working. Camera working OK on win Xp.
    How can I start it manualy on this software.
    Any others ideas?
    When worked I found in log
    Jan 1 00:00:11 kernel: usb.c: registered new driver ov51x
    Jan 1 00:00:11 kernel: ov51x.c: USB OV511+ video device found
    Jan 1 00:00:11 kernel: ov51x.c: model: Generic Camera (no ID)
    Jan 1 00:00:11 kernel: ov51x.c: Sensor is an OV7620
    Jan 1 00:00:11 kernel: ov51x.c: reg read: error -145: NAK (device does not respond)
    Jan 1 00:00:11 kernel: ov51x.c: Failed to configure OV7xx0
    Jan 1 00:00:11 kernel: ov51x.c: OV511 Config failed
    Jan 1 00:00:11 kernel: ov51x.c: Camera initialization failed
    Jan 1 00:00:11 kernel: ov51x.c: reg write: error -145: NAK (device does not respond)
    Jan 1 00:00:11 kernel: ov51x.c: Failed to read sensor ID. You might not have an
    Jan 1 00:00:11 kernel: ov51x.c: OV76xx, or it might not be responding. Report
    Jan 1 00:00:11 kernel: ov51x.c: this to mark@alpha.dyndns.org, joerg@heckenbach-aw.de
    Jan 1 00:00:11 kernel: ov51x.c: This is only a warning. You can attempt to use
    Jan 1 00:00:11 kernel: ov51x.c: your camera anyway
    Jan 1 00:00:12 kernel: ov51x.c: Sensor is an OV7620
    Jan 1 00:00:12 kernel: ov51x.c: reg write: error -145: NAK (device does not respond)
    Jan 1 00:00:12 kernel: ov51x.c: Failed to configure OV7xx0
    Jan 1 00:00:12 kernel: ov51x.c: OV511 Config failed
    Jan 1 00:00:12 kernel: ov51x.c: Camera initialization failed
    Jan 1 00:00:12 kernel: ov51x.c: USB OV511+ video device found
    Jan 1 00:00:12 kernel: ov51x.c: model: Generic Camera (no ID)
    Jan 1 00:00:12 kernel: ov51x.c: reset: command failed
    Jan 1 00:00:12 kernel: ov51x.c: reg read: error -145: NAK (device does not respond)
    Jan 1 00:00:12 kernel: ov51x.c: Device at usb-00:04.0-1 registered to minor 0
    Jan 1 00:00:12 kernel: ov51x.c: v1.65-1.10-mark : ov51x USB Camera Driver
    Jan 1 00:00:13 kernel: ov511_decomp.c: v1.6 : OV511 Decompression Module
    Jan 1 00:00:13 kernel: ov518_decomp.c: v1.3 : OV518 Decompression Module
    Jan 1 00:00:13 kernel: ov51x.c: reg read: error -145: NAK (device does not respond)
    Jan 1 00:00:14 kernel: ov51x.c: reg write: error -145: NAK (device does not respond)
    Jan 1 00:00:15 kernel: ov51x.c: reg write: error -145: NAK (device does not respond)
    Jan 1 00:00:16 kernel: ov51x.c: reg read: error -145: NAK (device does not respond)
    Jan 1 00:03:26 USB webcam: Accepted connection from 192.168.1.16
    now its not working and in log I can see
    Jan 1 00:00:10 kernel: ov51x.c: USB OV511+ video device found
    Jan 1 00:00:10 kernel: ov51x.c: model: Generic Camera (no ID)
    Jan 1 00:00:10 kernel: ov51x.c: reg write: error -145: NAK (device does not respond)
    Jan 1 00:00:10 kernel: ov51x.c: Error uploading quantization tables
    Jan 1 00:00:10 kernel: ov51x.c: OV511 Config failed
    Jan 1 00:00:10 kernel: ov51x.c: Camera initialization failed
    Jan 1 00:00:11 kernel: ov51x.c: Error uploading quantization tables
    Jan 1 00:00:11 kernel: ov51x.c: reset: command failed
    Jan 1 00:00:12 kernel: ov511_decomp.c: v1.6 : OV511 Decompression Module
    Jan 1 00:00:12 kernel: ov518_decomp.c: v1.3 : OV518 Decompression Module
    Sorry for my terrible English.
    Dec 2004
    Frankfurt / Germnay
    Thumbs down No idea?
    Hi everybody!
    Who can help me?
    cheers,
    JBK
    Mar 2005
    Czech republic
    Question Creative Labs Video Blaster WebCam Vista Plus
    Support WL-500gx this webcam - "Creative Labs Video Blaster WebCam Vista Plus" ??
    Aug 2005
    Denmark
    Webcam activity alert.
    I have installed a Logitech pro 4000 webcam, and it is working ok except for one thing. When movement is detected, and an email is sent, I cannot open the jpg files that are attached to the mail. In the mail there are 6 small jpg files. Is that right? I would have expected one only.
    Does anybody have experience with this?
    I am using Olegs firmware 1.9.2.7-6b.
    Thanks - Peter.
    Aug 2005
    Eindhoven, The Netherlands
    Webcam makes WAN speed drop
    I have a Philips ToUcamII which works perfectly with my WL500Gx. However, I noticed that the WAN speeds are affected by the cam. When it is connected, my maximum up -and download speeds are half (or worse) of what they should be. My other devices (USB Hub, printer, USB stick, USB HDD) do not cause this speed drop.
    Does anybody what could cause this?
    Nov 2003
    Eindhoven
    Quote Originally Posted by Jethro
    how fast or slow is your connection (kilobyte/sec please) ?
    and how fast or slow is it when a webcam is attached, and is the webcam in use somehow internal or external?
    Aug 2005
    "Before" it is around 3000 Kbyte down and 1400 kbyte up
    "After" it is around 1400 kbyte down and 400 Kbyte up.
    Just plugging it in does the trick
    Aug 2005
    Still the same problem. Any ideas? I have it as well when I use the old and the latest Asus fimware.... just doesn't make any sense...
    same with me.
    as i posted before, the webcam apps causing the cpu use above 60%
    also very high memory usage.
    my (non expert, non programmer) guess,
    that's the cause
    aztech adsl router -> asus wl500g w/ 1.9.2.7-5a fw -> linksys wrt54g w/ dd-wrt & hyperwrt as WDS
    http://www.ngobrol.com
    Aug 2005
    Quote Originally Posted by rexster
    same with me.
    that's the cause
    Hadn't checked that, but could be a good reason indeed...
    For me , my webcam (same logitech) never send me an e-mail when it detect something
  1. wl-500g deluxe problems
    By majx in forum WL-500g Custom Development
    Last Post: 17-08-2006, 17:03
  2. Wl-500G problems
    By MiRaCL in forum WL-500g Q&A
    Last Post: 13-01-2005, 01:08
  3. Connection problems with WL 500g
    By Mr. Orange in forum WL-500g Q&A
    Last Post: 06-01-2005, 10:48
