try a different channel
for your wireless
Hi there,
just very recently I found, that while connected to the WL500 through wireless interface, the pings fluctuate - see this:
[wl500groot@(none) root]$ ping 10.0.0.12
PING 10.0.0.12 (10.0.0.12): 56 data bytes
64 bytes from 10.0.0.12: icmp_seq=0 ttl=128 time=2.6 ms
64 bytes from 10.0.0.12: icmp_seq=1 ttl=128 time=5019.1 ms
64 bytes from 10.0.0.12: icmp_seq=2 ttl=128 time=4021.2 ms
64 bytes from 10.0.0.12: icmp_seq=3 ttl=128 time=3022.6 ms
64 bytes from 10.0.0.12: icmp_seq=4 ttl=128 time=2023.4 ms
64 bytes from 10.0.0.12: icmp_seq=5 ttl=128 time=1023.9 ms
64 bytes from 10.0.0.12: icmp_seq=6 ttl=128 time=24.9 ms
64 bytes from 10.0.0.12: icmp_seq=7 ttl=128 time=72.0 ms
64 bytes from 10.0.0.12: icmp_seq=8 ttl=128 time=95.3 ms
64 bytes from 10.0.0.12: icmp_seq=9 ttl=128 time=16.4 ms
64 bytes from 10.0.0.12: icmp_seq=10 ttl=128 time=40.3 ms
64 bytes from 10.0.0.12: icmp_seq=11 ttl=128 time=62.7 ms
64 bytes from 10.0.0.12: icmp_seq=12 ttl=128 time=4209.7 ms
64 bytes from 10.0.0.12: icmp_seq=13 ttl=128 time=3212.1 ms
64 bytes from 10.0.0.12: icmp_seq=14 ttl=128 time=2214.6 ms
64 bytes from 10.0.0.12: icmp_seq=15 ttl=128 time=1215.6 ms
64 bytes from 10.0.0.12: icmp_seq=15 ttl=128 time=1217.7 ms (DUP!)
64 bytes from 10.0.0.12: icmp_seq=17 ttl=128 time=10.5 ms
64 bytes from 10.0.0.12: icmp_seq=18 ttl=128 time=22.6 ms
64 bytes from 10.0.0.12: icmp_seq=19 ttl=128 time=47.2 ms
64 bytes from 10.0.0.12: icmp_seq=20 ttl=128 time=70.4 ms
64 bytes from 10.0.0.12: icmp_seq=21 ttl=128 time=93.8 ms
64 bytes from 10.0.0.12: icmp_seq=22 ttl=128 time=4367.8 ms
64 bytes from 10.0.0.12: icmp_seq=23 ttl=128 time=3368.8 ms
64 bytes from 10.0.0.12: icmp_seq=24 ttl=128 time=2382.0 ms
64 bytes from 10.0.0.12: icmp_seq=25 ttl=128 time=1384.3 ms
64 bytes from 10.0.0.12: icmp_seq=26 ttl=128 time=386.2 ms
64 bytes from 10.0.0.12: icmp_seq=27 ttl=128 time=29.8 ms
64 bytes from 10.0.0.12: icmp_seq=28 ttl=128 time=53.5 ms
64 bytes from 10.0.0.12: icmp_seq=29 ttl=128 time=77.3 ms
64 bytes from 10.0.0.12: icmp_seq=30 ttl=128 time=99.5 ms
64 bytes from 10.0.0.12: icmp_seq=31 ttl=128 time=21.4 ms
64 bytes from 10.0.0.12: icmp_seq=32 ttl=128 time=4643.8 ms
64 bytes from 10.0.0.12: icmp_seq=33 ttl=128 time=3644.8 ms
64 bytes from 10.0.0.12: icmp_seq=34 ttl=128 time=2645.7 ms
64 bytes from 10.0.0.12: icmp_seq=35 ttl=128 time=1647.6 ms
64 bytes from 10.0.0.12: icmp_seq=36 ttl=128 time=983.6 ms
64 bytes from 10.0.0.12: icmp_seq=37 ttl=128 time=2.3 ms
64 bytes from 10.0.0.12: icmp_seq=38 ttl=128 time=83.5 ms
64 bytes from 10.0.0.12: icmp_seq=39 ttl=128 time=2.4 ms
64 bytes from 10.0.0.12: icmp_seq=40 ttl=128 time=27.7 ms
64 bytes from 10.0.0.12: icmp_seq=41 ttl=128 time=50.9 ms
64 bytes from 10.0.0.12: icmp_seq=42 ttl=128 time=4712.6 ms
64 bytes from 10.0.0.12: icmp_seq=43 ttl=128 time=3726.3 ms
64 bytes from 10.0.0.12: icmp_seq=44 ttl=128 time=2727.7 ms
64 bytes from 10.0.0.12: icmp_seq=45 ttl=128 time=1728.2 ms
64 bytes from 10.0.0.12: icmp_seq=46 ttl=128 time=730.1 ms
64 bytes from 10.0.0.12: icmp_seq=47 ttl=128 time=73.8 ms
64 bytes from 10.0.0.12: icmp_seq=48 ttl=128 time=10.9 ms
64 bytes from 10.0.0.12: icmp_seq=49 ttl=128 time=34.0 ms
64 bytes from 10.0.0.12: icmp_seq=50 ttl=128 time=58.0 ms
--- 10.0.0.12 ping statistics ---
51 packets transmitted, 50 packets received, 1 duplicates, 1% packet loss
round-trip min/avg/max = 2.3/1322.4/5019.1 ms
There is no problem while being connected through a network cable.
I tried rebooting the router a few times but it didn't help.
Has anybody experienced that before? Could anyone give me a clue about what could cause this problem or how to fix it?
Any clues would be appreciated.
Thanks
Tom
for your wireless
I tried changing that and some other settings but no luck. I'll try flashing the old original WL500b firmware and see what happens.Originally Posted by xlekx
do you have wl500b or wl500g ?
dont use old firmware use oleg cr5 or cr6
Hello,
I´am having the same Problem here with the 1.9.2.7-6a Firmware
AND being connected to a cable.
The Ping hops from 29ms to 1000ms, makes Online-Gaming nearly
immpossible.
Anyone has an idea, how to fix that?
Greets
Christoph
